Question about Frigidaire FGF326AS Gas Kitchen Range
Fridgidaire gas range oven not working
I have a 2 yr old range and the oven does not work. the broiler is ok and the oven ignitor works. I am assuming it is the electronic controller for the oven. Is this right? and is this a big problem to replace?
  • thedibos Dec 28, 2008
    I have a Frigidaire gas range/oven and the range works fine - but the oven does not ignite. I can see that the ignitor element is on - but there seems to be not gas coming thru the burner orifice. What would cause this?
I have a gas range that is approximately 4yrs old and the oven will not ignight
Posted on Nov 17, 2008
Whirlpool gfg461lvs broiler won't light
Hello. How old is the range? The broiler ignitor might be worn out. The part number you might need is 8054129. The ignitor for the bake is 9758079. I hope this helps you.
Sep 12, 2015 | Whirlpool GFG461LVS Stainless Steel Gas...
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
heatman101
dfasfdas
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Me GE Gas oven is not working, but broiler and range do ?
I am working with model JGBP26WEH1WW GE Gas range: You do not need to remove the back or even turn over, just remove the storage pan at the base of the unit and disconect the two plugs (unique plugs). You will need to splice your old conectors to your new igniter. Yes you have the correct igniter for that model.
Apr 06, 2010 | GE Profile JGBP79 Gas Kitchen Range
Oven wont lite. broiler is ok. why? is this something i can fix myself?
Hello- Gas ranges have ignitors that light the burners. The lower burner is accessable by removing bottom pan in oven. Ignitor is held in place by two screws. Connector is plugged in behind bottom drawer. Check resistance of ignitor - should be 4ohms or higher. Sometimes they just break. New part available thru local app. parts. 50-75$. Be careful installing new part- ceramic ignitors are fragile. Take your time- toughest part is reaching in to do work. Hope this helps.- Thanks- ED
Feb 28, 2010 | Kenmore 72002 / 72004 Kitchen Range
Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Oct 02, 2009 | Kitchen Ranges
Burners and broiler work, but oven doesn't
If the broiler is working then the element is good. The T-stat controls the oven temp. Have you checked it?
Jul 03, 2009 | GE Spectra JGBP35 Gas Kitchen Range
No oven baking function
You need to replace the oven ignitor. The ignitor has to draw enough current to open the gas valve. Your ignitor is either broke or not working properly, so the ignitor will not lite the oven.
Jan 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire FGF326AS Gas Kitchen Range Logo
190 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
