Question about Cameras
My R967 got a little moisture on my last fishing trip to canada, so I took the battery out and memory card and blew it with a blow dryer, it had blue stips in the monitor and I kept it on the charger for a day, it got better but the monitor, when i view a picture I took is real grainy and bright, I tried reseting it... what can I do...thanks...Bob
  • 1 more comment
  • papazona Jun 28, 2008
    I still have the same problem.....
    i have the same problem
  • 859 Answers
You have to wait this out form some time and even then it may not resolve but can.
Put your camera sans battery, mem card and everything open, into a paper bag. A large one. then close the top by just cruching down the area 1/3 down from the top until you create a chimney of sorts.
Put this in a area that gets direct sunlight for a good hour or two. This natural oven will assist in drying out the residual moisture, but you don't want to over do it and warp the plastic so keep a close eye on it and even put an instant meat thermometer through the bag so you can monitor the inside temp.
The bag as an oven will draw moisture into the paper. However, this process releases ethelyne gas from the bag. Good for ripining fruit but without an adequate chimney to keep the inside temp around 150 degrees or just less you will over stress the plastic and only do this for an hour or so and for a day or two, then let room temps dry it out. This may take quite a few days.
A camera shop will do much the same thing before they start replacing parts. If in the long run your monitor is still trashed, you will have to have that serviced and tell the techs everything you've done so far.
Let us know in a few days how it went. Once you are satisfied, you need to restore factory defaults all the way around and then make adjustments to your screen to suit you. If it won't respond you have to have the screen replaced by the more important parts may be good to go from there.
Posted on Jun 28, 2008
  • 497 Answers
I agree with johnychel...u better take it to ur service centre..
Thanks for using Fixya
  • 1,011 Answers
Dear Sir,
This is the problem of Firmware version. U just uninstall the driver and update the latest driver with firmware version. try it...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} HP Photosmart R967 Digital Camera Firmware 3.04.06 Manual.
This is a manual firmware update (firmware 3.04.06) and requires a SD card and the dock that shipped with the camera for the update or a PC with a SD card reader slot.
If you do not have a SD card or if you have the HP Photosmart software (either Photosmart Premier or Photosmart Essentials) installed on a Windows PC, you should instead download the HP Photosmart Automatic Firmware Update utility for your HP Photosmart camera.
Firmware version 3.04.06 includes the following improvments:
· Improvements to charging a rechargeable battery that has very low voltage..
1. Define your HP Cameras and MP3 Player device model.
2. Define your operating system to install your HP Cameras and MP3 Player device
3. Search Cameras and MP3 Player driver category
4. Find HP Cameras and MP3 Player driver
5. Select HP Photosmart R967 Digital Camera Firmware 3.04.06 Manual
6. Download HP Photosmart R967 Digital Camera Firmware 3.04.06 Manual
7. Install HP Photosmart R967 Digital Camera Firmware 3.04.06 Manual
8. Restart or reboot your computer to finish your driver installation.
Go this link for driver.....
Good luck
Don't forget to rate the solution
Posted on Jun 26, 2008
  • Asfiya Ahamed
    Asfiya Ahamed Jun 28, 2008
    Dear Sir/Madam,
    Avoid getting your digital camera wet. If you're going to the beach
    or expect it to rain, carry along some plastic ziplock bags to place
    your camera in and to protect it from the elements.
    Damage to a
    the lens and other digital camera parts can be caused by prolonged
    moisture and humidity. This should be even more of a concern when a
    camera is stored and won't be used for a long time.
    In spite of
    your best efforts, if condensation forms on your digital camera, remove
    the batteries and memory card. Wait about an hour or until moisture is
    no longer present. If this is not enough, store your camera with silica
    Silica gelSilica gel acts as a shield of dry air in
    an enclosed storage area such as a camera bag. It is a blue colored
    "desiccant" that adsorbs moisture and condensation. The color changes
    to white or pink when the gel has absorbed the maximum amount of
    When silica gel has absorbed the maximum amount of
    moisture, it can be reused after drying it out. The gel is
    "regenerated" by placing it in the sun or heating in a microwave or
    conventional oven.
    Silica gel can be purchased in packets,
    canisters and cartons. Keep a few bags of silica gel in your camera bag
    and each time you store it. The more equipment you have, the more bags
    or canisters you should pack when storing it.
    A word of caution:
    if you drop your digital camera in the water, it may be damaged beyond
    repair. Contact your camera manufacturer immediately for advice.
    Good Luck
    "Don't forget to rate the solution"
  • 796 Answers
Actually the moisture must have entered the leads of the display...
the leads should be removed and then it should be dried so take the moisture off..
better take it to a service is risk to manually operate the sensitive parts inside and you could end up damaging the display
1991 jimmy 4x4--canada
If the windshield is still leaking use a water hose and run it over the outside till you find the leak, and seal it with windshield adhesive. Moisture is bad for the fuse box. You may want to pull the fusebox out and inspect for damage behind it-melted or burnt wires, terminals, or connectors.
Sounds like you're on top of it. Just stop the leaking and clean up any damage and you should have it. Good luck.
Jan 10, 2012 | 1991 GMC S-15 Jimmy
I dropped my phone in the tolit and i took the battery and sd card. i dried it. all 3. then i used a blow drier. then put it in rice. will it work?
Yes it will work, since you have taken out a great quantity of water from it using the blow drier.
The steps to get it to work are:
  1. Remove the back cover,
  2. Then remove the sim card and the scan disc memory card,
  3. Then try to open it up by using a torx screw driver,
  4. then slide an object around the edges of the phone to remove the front cover,
  5. Then blow dry it for a while,
  6. Take note not to get the blower too close to the screen to avoid damages,
  7. Reassemble the phone back together and turn it on.
It will work perfectly fine. Since you have done most of the job, just carry out the rest and turn it on.
Take care and good luck
Dec 22, 2010 | Cell Phones
Looking for 2 GB memory card for HP camera- R967
The R967 uses standard SD cards. You should be able to purchase them at any department, electronics, or office-supply store. You may also see them at many drugstores and supermarkets.
Dec 15, 2010 | HP R967 Digital Camera
As soon as i switch on the power the power is tripped
What exactly is tripping out? Most kitchens now have GFI recepticals. There is a small red button that pops out if the circuit detects moisture inside the electrical parts of the coffee maker. If that is tripping you may be able to simply dry out the coffee maker by turning it upside down and then blowing the switch and electronic controls with a hair dryer for a few minutes. Try the coffee maker is a receptical in the bedroom. If it doesn't trip there it is probably moisture caused by spilling a little water on the machine when you were filling it. If it trips the bedroom breaker, it is most likely a dead short in the machine. Normally it is not worth the labor and parts to repair this machine.
Sep 13, 2010 | Keurig B100 Coffee Maker
My olympus sw 1050 got wet in the inside. please help..
A cell phone and a camera has the same solution.
Your camera can be saved.
You will need
1. A plastic container with a lid.
2. Blow dryer.
3. Towel
4. Two silica gel packs
STEP 1. Remove your camera's battery
STEP 2. Remove your memory card.
STEP 3. Clean the camera with towel roughly.
STEP 4. With your blow dryer, dry your camera with warm or cool.
STEP 5. Place your camera, battery and memory card into a plastic container with silica gel packs. Allow this package to leave for at least three days for preventing your camera from moisture.
STEP 6. After three days remove your camera from plastic container. Try to use it with its battery. If it does not work. Then try to use the camera with a charger or with a DC adopter. If it works then you will need to change your battery with a new one.
You can see these steps in a video use the link below.
I hope it is helpful.
May 09, 2010 | Cameras
Broken battery /memory card door. Just need a new
Sign in to ebay auction, type and click onto digital camera parts and buy a nonworking camera like yous for parts.
Nov 25, 2009 | Cameras
My camera fell in the water will it still work after it is aired out? Will me memorie card still be good too?
It's hard to really say. I guess it depends on how much water it took on and whether the camera was on at the time. Either way, I would suggest you immediately open the battery and memory case and take out the memory card and battery. Then get the good ole blow drying out and blow warm air inside the camera for a few minutes in the hopes of drying out any water or moisture that might have gotten into the camera. Next, leave all the covers open for a few hours or more (Patience is key! A whole day would even be better) and then put the memory card and battery back in. Then, turn the power on and hope that it works.
I Can Fix It
Aug 14, 2009 | HP Cameras
LG VU screen doesn't work after water damage
I was cleaning the pool when my LG Vu took a dive. I fished it out in about 2 minutes...should have jumped in and it would have been in only seconds.....anyway. Dried it off with my shirt and pushed the lock button to unlock and see the was on but said Emergency Download. I took the battery out and dried it off also took out the SIM card and memory card. Shook the water out; some drips here and there, fortunately it wasn't water-logged. I let it sit for about an hour and got on the internet to find a remedy. I took advice to put back the memory and SIM cards and plug in to charger....the screen directed me to put in the far so good. The screen said the battery was charging. I waited patiently for that to finish. When complete, unhooked the charger and hit the unlock button again....what do you know the screen came up! I was estatic! But....the touch screen would not work!! Back on the internet for advice. Decided to do the hair dryer trick. I set the dryer on cool setting and let it blow on the screen. I also opened up the chargers portal and let air blow in there. I took the cover off the back to the battery and let it blow on there....being very careful not to let the battery fall out and not let the phone get hot. I did this for about 30 minutes. There was some fogging of the screen so I focused more on drying the screen with the dryer. The fog cleared up and when I touched the touch screen the top of the screen started working first...bottom still not responding...a little more of the dryer and all worked!!! Screen fogged again in about 20 minutes...dryed it again with dryer and it has been dry ever since. I have gone to every application, etc. on my phone and everything works just like it did before it took a dip! Hope this helps some of you! Key is patience, and some drying with TLC! Best of Luck!
Apr 29, 2009 | LG Vu CU920 Cellular Phone
Spilled onto Acer Aspire laptop
I suggest you download for $6 the service manual for your laptop here
You take it appart and clean everything electronic board component side and wired side with alcool (not beer, something like 90%), you wash the plastics, and build everything back together.
Before pushing the power button, pray a little bit ;)
20mn was too short anyway , next time it's two days min. by hot days.
Good luck and don't forget to vote,
Jan 03, 2009 | Gateway CX2608 Notebook
When i insert the memory card the camera freezes.
It sounds as if either the file allocation table or some data on the card has become corrupted.
Have you got access to another camera (friends or family) that you could try it in?
Have you got a card reader on your PC? If so, you should be able to re-format the card using Windows. (Go to My Computer, right-click on the card reader icon and select format)
Hopefully this will cure the problem. If not, you should be able to change it if it is new.
Feb 27, 2008 | HP R967 Digital Camera
Cameras Logo
105 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
