Question about Maytag SkyBox MBV1976A Beverage Dispenser
Skybox will nat cool below 40 degrees
My skybox used to keep beverages around 32-34 degrees but now will not go below 40. Any suggestions?? Also, do you know where I can find a service manual? Thanks, Dave
  • 221 Answers
The likely cause is a heavy frost and ice buildup on the internal evaporator plate behind the dispensing unit. Unplug the unit and open the door for 24 hours. Plug the unit back in, reset the thermostat to the 11:00 position.
Posted on Apr 27, 2009
Why did my unit stop cooling beverages?
my skybox run but my beverages is not getting cold,can you tell me what i need to do,or where i can i take it to get fix?
Nov 15, 2012 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox stopped cooling Skybox stopped cooling. Sounds like the relay will kick on briefly and then click off. Everything else works. I took the back panel off and could hear the relay clicking on...
The relay on your box is damaged.. You have to get it replaced.. Not to be tried by a novice but if you have some experience in electronics it can be fixed by you. The relay costs around 75$. Good luck!
Mar 26, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Beverage-Air KF48-1AS not coooling, fans not running
some thing wrong with the evaporator fan motor. make sure the motor turns freely. your going to need service .
Jun 19, 2009 | Carrier 44.9 cu. ft. Upright Freezer...
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from skybox
Maytag never offered a replacement compressor for the SkyBox units. It was not a cost effective repar to make. If you are sure the thermostat is supplying 120VAC to the compressor, you can install a Supco URCO410 relay/capacitor/overload kit. This part should only be installed by a qualified service technician.
Feb 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox stays at 50 degrees all the time
The SkyBox was built for Maytag by a company in China. Production stoppedabout 2 1/2 years ago, and Maytag purchased ALL available service parts available at that time. As inventories are depleted, there will be no more parts available.
An issue with the SkyBox involved a build up of frost and ice on the evaporator plate built into the wall behind the dispensor assembly. This build up insulated the product from the evaporator coil. It also caused the circulation fan to stop running. Unplug the unit and leave the door open for 24 hours. Plug it back in, set the thermostat indicator at the 11:00 position and close the door. See if this brings the temps back down to the 36 to 42 degree range, I hope this helps.
Jan 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
good to hear another skybox lives...thanks for the kind words. alex
Dec 10, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox won't cool enough.
you might need the compressor checked for freon level
when the compressor stops cooling entirely - the products will stay room temp.. when this happens -- the relay overload switch is the problem -- most sites tell you to change the capacitor and transformer -- this is expensive and not the problem -- its like changing the starter and alternator on a car -- before checking for a bad battery
Nov 18, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
106 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
