Question about Fisher and Paykel IWL12 Top Load Washer
GWL10 US won't finish cycle
Started out with an out of balance load. Wife repositioned load and restarted. Became out of balance again. She came to get me because it was beeping every sec. I opened the top and it was over full of suds and half full of water. I removed the clothes and unplugged for 60 secs, then retried the wash. The same thing happened. It runs through the cycle, then stops at the end just before spinning with half a tank of water. Then it starts beeping every sec with the last light in each cycle lit up. I've tried leaving it unplugged for a full day, but no change in the pattern. The machine is about 4 years old.
  • vmaxrdr Oct 14, 2008
    I have a simular problem. The washer works fine during the first and second spin cycle. After stopping while the water drains it acts like it wants to start up again but stops, beeps and flashes the control panel lights. I haven't been able to determine if there are any codes and unplugging it for a short while did'nt help. Any ideas? Thanks.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 22 Answers
Had similar problem with not draining and then motor burned up. Took motor off bottom (see my issue "eco smart won't drain, smells hot" for how to remove motor--very easy. Found husband's sock in very bottom of drainage area and pulled it through quarter-sized hole where motor unit attaches. I couldn't see this sock when looking from above between the tubs.
Posted on Oct 21, 2008
  • 30 Answers
I would say that your washing machine has a blocked pump??
Posted on Aug 03, 2008
Hi Mate, I had the same problem and then looked on the web to find that all I need was a $40 out of balance switch. Although the old one looked ok it had corrosion inside, bought a new switch and installed it myself, easy, ask the F&P parts supplier if you are not sure.
Cheers,
Dan
Posted on Jul 24, 2008
Fishwe&Paykel GWL10 won
It could be the out of balance switch faulty & need replacing.
Nov 17, 2012 | Fisher Paykel EcoSmart GWL15
Maytag Neptune Top Load Washer will not spin and water will not drain at the spin portion - the laundry becomes un-balanced. I have checked to ensure the machine is level per manual - once you reposition...
If your machine ius a FAV6800A LED console or FAV9800A LCD console then take a look at this post Clutch Fix if you want to DIY.
I will help you through the process. Your looking at $300 to $400 for a repair if you don't DIY. See if the DIY process is for you if so let me know I have a few additional questions......Rich
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Out of balance on spin cycle (machine is level)
The balancing straps that hold the drum in balance could be broken or the springs could be wore out.
Jan 11, 2010 | Washing Machines
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
detection and correction
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
washer will make several
attempts to restart the spin
cycle. If an imbalance is still
detected, the washer will stop
and the error code will be
displayed.
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
Kenmore HE3 stuck in rinse cycle
my wife was doing laudry with he3 and when it quite the door would not open.tried to restart a new cycle and it would not start.I unplugged the washer and let sit for 2 min.replugged it in and it started to work.I hope this helps you.
Apr 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Washer will work at all. It acts dead
a small run of these actually had an out of balance switch and fuse assembly that cut power to the machine if it went way out of balance ,check and see if yours has one and replace the fuse at first but you may have to replace the entire assembly
Feb 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
The spinner gets off balanced make knocking sound
Ok first is it a top load or front load and I need the model number inside the lid or door.
Sep 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore elite quite pac-II heavy duty
We have not heard back on this in about a week. I'm presuming It's been repaired?
Feb 16, 2008 | Kenmore 22422 Top Load Washer
Loud noise thourghout the cycle
I would have the counter-balancing system checked for proper motion.
Jun 07, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
124 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
