Question about Mitsubishi VS-60603 60" Rear Projection Television
Mitsubishi VS45603 Is my mitsubishi VS45603 HD compatible?
  • Mitsubishi Master
  • 8,617 Answers
No the VS45603 is a standard TV not HD
Posted on Jun 26, 2008
Is this Tv HD? Molel # VS-45607 Mitsubishi
I am sorry to say that your set is not compatable with HD.
Although you should still get a good picture.
I hope that this helps.
asnowman
Jul 22, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Tip
Mitsubishi VZ5 Chassis VS45603, 50603, 60603 & 50604 ill not power up
The mitsubishi VZ5 chassis that will not power up often is the result of a leaky diode raising the voltage on IC700. A quick check is to check pin 4 of IC 700 for
0 Volts DC. If pin 4 has any voltage replace Diode 980 on the main PCB it is leaky and the set should power up. This tip relates to all VZ5 chassis mitsubishi's
on Feb 23, 2008 | Mitsubishi VS-60603 60" Rear Projection...
I have a Mitsubishi Model VS45603. We lost power
You will have to select the TV Menu (on the remote), go to NET COMMAND, and reassign all your devices and inputs again. You may even want to go to SETUP first to be sure the screen, video, audio, color, is what you want before assigning devices to inputs.
Aug 11, 2009 | Mitsubishi Televison & Video
Mitsubishi model no. vs45603
ok, then you'll need to call a tech for that.
May 14, 2009 | Mitsubishi VS-45603 45" Rear Projection...
Light defusion filter for vs45603
Yes the 45603 and 45607 will interchange screen component not electronic parts but screen assemblies are the same
May 12, 2008 | Mitsubishi VS-45607 45" Rear Projection...
HDTV COMPATABLE
the hd sat box is your converter and is compatible to your tv (1080i only). if you are asking about local braodcast (over the air) this set doesn't have an ATSC (digital) tuner so you would need a box for that. but your sat company may be giving you your local broadcast in HD.
so if you are presently using an aeral antenna for your locals yes you will need the box.
if your locals are already being supplied by your sat company no the sat box is your converter.
note: some sat boxes have ATSC tuners built in so your antenna can be used by the sat box as well.
Feb 29, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubshi vs45603
Do a self diagnosis test first and find error codes
Dec 17, 2007 | Mitsubishi VS-45607 45" Rear Projection...
MITSUBISHI TV CODE NUMBER FOR SONY RDRHXD870
i started at 00 and worked my way up the list and found a code which made the dvd contoller work on my LG tv. got to 06 b4 it worked.
Oct 05, 2007 | Mitsubishi HD-6000 DTV Receiver / Video...
Televison & Video Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
