Question about Ricoh Aficio 2022 All-In-One Laser Printer
Operation of Duplex through computers
We have a Ricoh Aficio 2022 (2004) - we are able to use the duplex for photocoping, but it will not allow us to use the duplex through the printer option. We were able to about 6 months ago but some thing has changed and we can't now.
Your help would be most appeciated
Email address
Go to "start" then "printers and faxes" ( If XP). RIGHT click on your default printer ( Ricoh 2022) select properties, at the top of the screen you will see a tab that says Accesaries" hilight that tab and down on the page that says "duplex" place a check mark where it says duplex. CLICK APPLY or it will not change when you exit.
hope this helps.
Posted on Jul 28, 2008
Setting the duplex printing for RICOH Aficio MP 3351
You just need to go to printing preferences and set the tab duplex. (Opens a tab and you chose which one you want.)
If you want to put duplex by default, go to:
Start - printers - click on the right on your mouse - properties - Printer preferences - and Change the duplex. In the end just click on "apply".
Feb 24, 2011 | Ricoh Aficio MP 161 Black and White Copier
Ricoh Aficio 2035 wont duplex, displays error message error: Duplex unit is not set. Set it properly
there is a sw on the duplex unit that tells the copier it is closed my guess is that its broke
Nov 04, 2010 | Ricoh Aficio 2035 Copier
How to install Duplex mode on PC for Ricoh aficio 2027
If you go into the print driver settings (Control Panel > Printers & Faxes > right click on the Ricoh 2027 and select Properties) there is a list of the available accessories under one of the tabs (I think it's either Accessories, Advanced, or something similar). Depending on the specific driver you have, you can either check the option for the duplex unit and then click Apply, or you can click the Update Now button to have the software itself check to see which options are installed on the copier.
Either way, you should be able to print duplex copies once you've done of those two things (assuming you actually have a duplex unit installed on the copier, of course).
Jul 09, 2010 | Ricoh Aficio 1085 Laser Printer
How do we get this machine (ricoh aficio MP 2000) to duplex print?
There are certain models that can duplex and certain models that can't. Generally if a Ricoh copier can duplex it has a D after the name (like 2018D). If there is no option for duplexing on the screen or the ops panel, that model doesn't support duplexing.
Apr 30, 2010 | Ricoh Aficio MP 2000 Black and White...
How do you print via computer double side print automatically with duplex on a Ricoh 1232C copier printer.? (also know asc Aficio DSC, Gestetner R032C, Infotec)
First you need to enable the duplex option in the accessories tab.
Go to printers, and sellect properties(right click) and accessories.
Feb 25, 2010 | Ricoh Aficio 1232C Color Copier
RICOH Aficio 1013F coping
Check if your copier has DUPLEX unit installed, the Duplex unit is a optional component for copiers, seems that you don't have that option installed.
Feb 15, 2010 | Ricoh Aficio 1013F Copier
Ricoh aficio 1045 jams on duplexing
there could be multiple reasons for it to be jaming on duplex, just depends where in duplex it jams. most common for the age of the copier rubber rollers in duplex getting dirty or hard. like swan34 said try some type of rubber cleaner.
Feb 07, 2010 | Ricoh Aficio 1035 Copier
Need to Double Side
press the "duplex" button on the operation panel
Jul 23, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Copying using the Duplex function
Press on duplex button and scan your originals one by one on the platen mode (exposure glass). You cannot use the ADF for this function.
After every scan press the Start button.
After the last page please press the enter button as displaying in the display.
Then the copier itself can finish making duplex copies as you wanted.
Good luck and please rate me, thanks.
Nov 27, 2007 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 2022 All-In-One Laser Printer Logo
264 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
