Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Internal and external commands
I would like to know what are internal and external commands. and difference among those.
1 Hanging problem.
2 Incomplet Booting not crosing to destop
Posted on Jul 01, 2008
Tip
How to find your Router's IP address
The easiest way to know your Routers Internal IP address is by using a little command line tool called ipconfig. This command line is built in with Windows Operating System and is being used for various networking solutions. To use this, you need to click Start and find the run command. Click the Run command and you should see a little run dialog box after.
In the run dialog box, type in cmd and either press ENTER or click the Ok button. You should see a black window with white text and this is referred to as the command prompt.
At the command prompt type in ipconfig and press enter. That should display three major information. The IP Address, Subnet Mask and Default Gateway. The IP address in line with Default Gateway is your router's Internal IP address.
Each Router has Internal and External IP address. The internal IP address is what you use to talk to your router. Use this IP address to login to your router setup page and configure it for things like port forwarding. External IP address is what the rest of the world uses to find you on the Internet.
Hope this helps.
on Apr 20, 2011 | Computers & Internet
Windows 8.1 not running hping3 at command prompt
It is not correctly installed.
It is not accepted a windows command, so is not in the windows path, which is why you are getting the error.
Mar 07, 2015 | HP Computers & Internet
How do I diable my in-camera flash and still be able to use my external flash unit as a slave?
How to use the internal flash as a commander is in the manual from page 189. The manual is online.
There follow 10 pages about all different settings for the remote flash mode. I could not find how to use the internal flash as a commander and switch of the commander itself. On my Nikon, I can use the light as a commander and when the picture is made the build in flash does not fire.
You always see the internal flash fire, before the picture is made, because it has not only to tell each group what setting it should use, but it also has to trigger the external flash groups. If you want to use the flash as a commander while photographing persons, you can use a Infra Red filter (little one) in from of the internal flash, so the subjects won't close their eyes. Look for the Nikon SG-3IR filter. I think Canon must have filters like this.
Nov 03, 2014 | Canon EOS 600D Rebel T3i Digital Camera
How do i locate my web address
Internal or External IP?
External IP: go to a website called www.ipchicken.com and it will tell you what it is at that moment.
Internal IP: open a command prompt and run ipconfig and it will give you your current local IP.
Mar 27, 2014 | Computers & Internet
I have installed ubuntu on my iMac as I couldnt install windows or boot Mac os I have a external drive that has Mac os and recovery partion but I can't boot with it but in ubuntu j can read the disk I...
You could copy the contents from the external drive to the internal one. Boot from an external CD or DVD with the Ubuntu installation image on it. Doing so will allow you to write over the internal drive. Learn the dd command (start with "man dd" from your Ubuntu terminal window. An example might be "dd if=/dev/sdb of=/dev/sda"
"if" is short for "input file", but can represent the whole device (drive), which is what you want. "of" is short for "output file". You can use Ubuntu's Disk Utility to examine all your drives and figure out which one is which.
This is a very powerful command and nothing else I can think of can wipe out a disk you meant to keep any faster or more thoroughly, so be very sure you figure out which (sda sdb, and so on) is input and which is output. The "dd" command produces no output until it's done, just quietly working away on gigabytes as ordered.
Feb 03, 2014 | Computers & Internet
Need to know wat ip number is and port is
IP stands for Internet protocol.
It's represented by numerical code, which is assigned to each device like computer, printer, phone.
IP's are two types. There are Internal IP, External IP
Internal IP means that your system ip address.
If you want to know your system ip address follow these steps:
Start--->run-->Type cmd
Then command prompt will display.
type ipconfig
then it will display your system ip address
External IP address means that your network IP address. If you want to know your Network IP address then visit IP-Details.com here it display IP address, ISP,location, Longitude, latitude and so on.
To find your port number follow these commands:
Go to start--->cmd---->type netstat -a
Feb 02, 2014 | Televison & Video
How do i change my ip adress on netbook
First you can find your internal ip address of your netbook by using these following steps
Goto START> RUN> Type CMD> Command prompt open here Type " ipconfig/all "
You can change your internal ip address
Again go to command prompt
  1. Type "ipconfig /release" (without the quotes, on the command line by itself).
  2. Type "ipconfig /renew" (without the quotes, on the command line by itself).
If you want to know your external ip address Just visit the site Ip-Details.com
your external ip address assign by your internet service provider. if you want to change this do the following procedure
  1. Log into the router's admin console. (Often http://192.168.1.1/)
  2. Release the IP address. (Method varies by router manufacturer)
  3. Turn off router, ethernet hubs/switches, and the cable/DSL modem.
  4. Leave off overnight.
  5. Turn everything back on.
Jul 04, 2012 | Computers & Internet
IP Address
What ip address you need and on what operating system ?
For windows, press the "windows key" (the one with a flag) then type "cmd" and press enter. At the command prompt that appears, type "ipconfig" and press enter. You will find your intrernal ip address there.
If you need your external ip (as seen from internet), open your web browser an go to www.whatismyip.com .
Your external ip will be displayed there.
May 07, 2011 | Computers & Internet
Netopia NAT
I know that most Netopia's I've worked with have been able to port forward single or ranges of ports to numerous internals from numerous externals.
Address Translation needs to be on.
IP Passthrough has to be off.
Then in NAT Easy Servers, setup port forwards and specify the external IP, internal IP, and ports (can forward all).
Dec 21, 2009 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
77 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
