It appears my JVC AV-65WP74 has a CONVERGENCE problem. When I try to line up the red lines on the graph, they stay kind of bent on the right hand side of the screen. When you look at objects on the screen, they appear to have a shadow to them. Any suggestions???
  • Anonymous Jul 14, 2008
    • i have the same problem whats the price for the ic for this jvc model av-65wp74
  • Anonymous Jan 13, 2009
    I cannot align the red on top of the green plus sign and it give the appearance of 3d.
  • 8,617 Answers
Replace both convergence Ics you can get replacement ICs here with free instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Jun 26, 2008
I have a JVC HDTV model AV-65WP74, i had my tv on overnight, woke up this morning i found the colors on the tv kind of funny and the tv is also showing double images. Please help. What to do?
The convergence ICs have failed. You can get the JVC AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com which has the ICs and resistors plus the CD with detailed repair instructions.
Nov 08, 2010 | JVC AV-65WP74 Rear Projection Television
Blue lines arc down from the top of the screen on JVC IART TV model number AV-65WP74. Is it worth fixing? Thanks
Yes it is worth fixing . You can fix it yourself for about $ 21 . You need to replace the convergence I.C. chips , The part # is STK392-310 . you need two of them . You can get them from bluestar-online.com . They are about 6 bucks a piece and about 10 for shipping .
May 13, 2010 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 convergence problem colors won't line up
did you replace the convergence feed resistors? If not they could be out of tolerance or one may have opened which would cause that symptom
Mar 27, 2009 | JVC AV-65WP74 Rear Projection Television
65 jvc iart model 65wp74 ,have a convergence problem,how do i get front panel off and where is circuit board located.Thanks
you need original jvc remote for this to work. Do not open anything until you. Go to menu on your remote find convergence and press the volume button to the right go to manual and press right again. you should see a bunch of rectangles, now you should also see a set of red cross heirs press the #2 to move cross heirs up and eight to move down numbers 4 and 6 will move left and right and 5 will place the cross heirs back to the center once you have chosen the selected section to adjust line up the magenta with the other colors using the channel and volume buttons these move the lines up down left to right adjust all lines until they are white. i do not know how to switch from magenta to green or blue but this should get you started on the right track with out having to replace anything. good luck! if you figure out how to switch from maqgent to green or blue please post it so that I may adjust mine as well tahnks
Feb 23, 2009 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74
Hi, sounds like your convergence IC`s have failed if one of the colors doesn`t adjust either up/down
or left/right. If you have soldering equipment and are very proficient at soldering you can replace them. if not you definitely need to call a tv tech, if you need more info ask away, video-tek
Jan 26, 2009 | JVC AV-65WP74 Rear Projection Television
Troubleshooting AV-65WP74
You need to replace the two Convergence amp ICs they are both STK392-110 thats a easy reapir on that model , But dont remove the rear panel with the power cord plugged in you will destroy the digital circuits. the Ics are up front behind the speaker grille. You can get new replacement Ics at the following link with free instaltion instructions with pictures. Here's the link,
Jun 26, 2008 | JVC AV-65WP74 Rear Projection Television
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
have pts rebuild the board which will cost around $130, www.ptscorp.com, or replace the stk392-110 x 2 located on the convergence panel.
Dec 08, 2007 | JVC AV-48WP74 48" Rear Projection...
PCB's when available,are expensive.Replace convergence IC(s),
re-adjust and you are good to go!
Oct 12, 2007 | JVC AV-65WP74 Rear Projection Television
Green shadows and curved picture
the convergence apms ic"s need to be replaced
Aug 16, 2007 | JVC AV-65WP74 Rear Projection Television
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Electro Med Services...
