Question about RCA P56950 56" Rear Projection Television
P56938 Convergence Problem
I have a P56938 with a PTK195S1P chassis. I have done a lot of reading of other posts and have a couple of questions. When i look in the back of my set I only see one fuse (back center) and not 3 as i have read. Is this the correct fuse to check to see if its blown (which it has not BTW). Also right infront of you is a circuit board which is mounted up on the right facing back which contains a single IC on it. I am getting bowing of my picture and also the menu is missing the adjustment sections. Is the board that i am seeing the one that i should change or just change the IC. Also how can i tell if its the board or the amp that has gone. I have taken photographs if it will help in anyway
Thanks in advance
  • Coops599 Jun 26, 2008
    I recieved email saying that I had a solution from Jaile867 and from VOTIT and also a comment. All I see is the solution from VOTIT. How do i see the other solution and comments please.
  • Coops599 Jun 27, 2008
    I got an email saying i had a solution from JASON867 as well. Where do i see that solution
  • RCA Master
  • 6,487 Answers
Check this link it may help you with your problem:
http://www.freelists.org/archives/techassist/04-2003/msg01338.html
Hope that helps........
Posted on Jun 27, 2008
  • 2,071 Answers
The convergence section is using a STK IC ,if you find ic screw in a heat sink that ic has mark stk ,the problem of convergence is the STK and resstor change value this is to be checked, these resistor is associated to the pins of stk and reheating all joints of parts there this necessary to this kind of problem .. find a tv technician to do works for you ... in order to avoid high voltage shock..
http://www.repairfaq.org/sam/tvfaq.htm#tvtvrep
http://home.earthlink.net/~olegfilipov/ConvergenceFix.htm
Posted on Jun 26, 2008
  • 2,296 Answers
I've found some this i nfo that could help you troubleshoot your TV.
Your problem is likely to be in the convergence board power supply
p/n 250868. May not be supplying the - and + 15 volt supply, abd the +45
volt and - 45 volts account shorted diode cr19710. p/n 164590. also replace
cr19709 the one next to it same part #. Also if stk730-130 is bad it can
cause this problem. Also check r 19703 (750k 1/2watt) may be open,
q19700(bc457)or nte123a could have base emitter open.
What is the part number for the convergence fuse?
I not only answer about 300 questions each week here I read answers other experts have posted in the past---here is one that should help you a lot:
http://www.fixya.com/support/r5119668-fix_convergence_problems_rca_chassis
SD TECH
Apr 24, 2012 | RCA HD52W59 HDTV Projection Television
I have a rca tv model # p56938 and it just stopped working and now just makes a beepin sound any ideas on what it ,might b b4 i throw it out
If power light is green and just barely tries to come on you may have a High voltage problem.
On back of set where model number is located is a Chassis number : something like PTK195 ETC. what is that number?
Mar 13, 2012 | RCA Televison & Video
Do I need to remove the entire Sub Deflection Board in order to replace the convergence ICs STK392-040
There are only two ways to do it.
You can try to unbolt the entire chassis and tilt it up so you can get at them OR-
you can unbolt the board(not every wire or plug needs to be undone for this) so you can tilt the board up and get at the chips.
These except for a few models are not the most easy sets to do this repair on.
Are the chips on the middle of the chassis? If so it is either get the entire chassis up or unbolt the board enough to get it up--a lot of work to get the board completely out of the set.
Some of the nicer versions of these sets had the chips on a small board above the main chassis--easy to get out and work on---if they are down on the main chassis--mark every plug you remove etc and you should be able to get the board up without taking all the plugs out.
Let me know if you have questions--I am here to help and have a lot of experience with these and other sets with convergence problems.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 24, 2009 | Samsung PCL541R 54" Rear Projection...
3D Convergence problem
STK 730-020 you should have on 1 on small board if this is the chassis am thinking it is Medium size IC Black with these numbers on it.
Feb 15, 2009 | RCA P46924 46" Rear Projection Television
43UWX10B problem with green
if you have a 2 IC convergence chassis they dont control the green , However if you have the 3 IC chassis the green is controlleed by the third IC these are usually STK4275 or simallar single amp ICs. Which type chassis does your hitachi have? Its possibly related to the digital convergence board if all resistor near the ICs are good. Do you have the service manual? I can post a link where you can get the full service manual if you need one
Mar 29, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Parts identification
I can help you with this,i will get back to you later today its 3am here and i dont have my breif case with me i just order a FBT for a RCA PTK195 .ThankYou for using FixYa. Have a Nice Day.
Feb 10, 2008 | Televison & Video
Rca projection tv serv#p56938yx mod#p56938 serial#c135c50tx chassis#ptk195s16p cant id
Here are some numbers to call for Flyback Replacement
Electronica 1-800-772-5578
Asti 1-800-221-1828
you will need RCA chassis# PTK195s16p - flyback number1541938b.
Feb 07, 2008 | Televison & Video
My toshiba 42h81
Your convergence amplifiers have failed. There are lots of posts on this site for this problem. Take a look at this link:
http://www.fixya.com/support/t261950-43h71
There are a couple of links on this post that you will find helpful if you want to repair this yourself.
If you have more questions just ask.
Dec 28, 2007 | Toshiba 42H81 42" Rear Projection...
RCA P56950 56" Rear Projection Television Logo
96 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
