Fujitsu 18RC Air Conditioner
Problem for Fujitsu 18RC Air Conditioner
Condensation from wall unit
By howlou on Jun 26, 2008
excessive water from the indoor unit at relatively low humidity (68)
Solution #1
posted on Sep 19, 2008
Not Rated)
kiwikim
Rank: Apprentice
Rating: 0%, 0 votes
Try making sure the filters are really clean. Blocked filters cause insufficient airflow and the inside coil 'over cools' icing up.
Was this helpful?
Yes
No
Solution #2
posted on Aug 14, 2008
Not Rated)
suswoods
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem.  Does anyone out there have a solution?
Was this helpful?
Yes
No
Popular Solutions for Fujitsu 18RC Air Conditioner
Questions and Unsolved Problems for Fujitsu 18RC Air Conditioner
Do you recommend Fujitsu 18RC Air Conditioner?
Answer
Answer
select knob for friedrich heat and air unit switch from heat to air .greensboro,nc27403
Answer
Works fine on cool; on heat it puts out hot air for a minute or two and then gets stuck in a... (More)
Answer
how to set time and timer on ar-je5 remote control for fujitsu air conditioner
Answer
Serial signal reverse error code. Model ASTA09LCC. Unit was installed and ran for approx. 2 hours... (More)
Answer
How do I set the timer on a AR-JE5 unit I have lost the manual
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 18RC Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
