Messed up screen..please help
My screen is black now but 20 mins ago the screen had a blue and green line crossing the screen horizontally. the blue and green line was about 9 inches tall. once when i turned it on the screen was black with a thin blue line crossing the screen. this line was about 3mm tall and it spanned the whole width of the screen just like the last blue line. the speakers only work about 30% of the time and when the speakers have worked the screen is 100% black. the picture that was apparent with the blue line was not a signal in was just undistiguishable clolors. note: there is no antenna...could that be the problem? also the coaxial jack on the back has come loose from the shell of the tv but is still attatched inside. there was also alot of dust inside the contraption. does anyone think that they could diagnose this problem...if not my friend's step-father owns a tv repair shop. as a last resort i will take the television there for a diagnostic and repairs.
  • 1 more comment
  • Dionysos Jun 26, 2008
    Hi!,
    I have a television Sharp model CU27FS51. The problem is that I have no image on the sreen but in the same time I have the sound on each chanel that I choose. What's going on? I have a courant on the tube cause I have littles lights on it.
    Thank you for your help.
    Denis Tetu
    denistetu@videotron.ca
  • Anonymous Jul 04, 2008
    line down center of screen. otherwise black screen. after sitting for awhile off, picturee returns for approx. 10 minutes
  • Anonymous Jul 19, 2008
    Hi!
    I have a DVD player Electrohome DVD816E and the power supply is out of order. The fuse is burned and the isolation transfo is burned to. I don't think that I have other problem. How I can fix that?
    Thank you.
joust
  • 7 Answers
SOURCE: thin horizontal line
Thats almost definately bad solder connection. look at solder joints for cracks around teh lead. better yet, suck outold solder and put in new on any connections that have anything larger than a standard resistor lead. yoke plugs, tuner, etc
Posted on Jan 24, 2007
nfandres
  • 168 Answers
SOURCE: Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Posted on Mar 10, 2007
  • 1694 Answers
SOURCE: Toshiba 36A40 36" TV / Chassis No: TAC 0011
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
Posted on Oct 24, 2007
  • 1030 Answers
SOURCE: Thin black horizontal lines on JVC PD-42WV74 EDTV
horizontal line is an idication of a bad board known as a x driver board. Their may be a slight possiblitliy it can be a small ribbion cable that runs from the driver board to the plasma panel. Another possiblility it can be a bad panel... but from the symptoms you describe i would first have to look at that driver board. and the sympton that getting worse makes me lean toward a bad ribbion cable.. if that could be reseated....well that the first thing as a technician i would try. Carefull Television generate dangerous voltages.
Posted on Jan 04, 2008
Cybertech
  • 149 Answers
SOURCE: TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Posted on Apr 01, 2008
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Vizio VO370M LCD TV screen is mostly black with green/blue horizontal stripes at the to. How can I fix this?
Most likely you are looking at a defective LCD panel, but I would recommend getting a proper diagnosis.
Sep 07, 2012 | Vizio VO370M LCD TV
Horizontal blue and black lines
Based on your information given maam, I can say that your LCD is not working well but sometimes it happens that there is a problem on its connection to circuit board..This is usually I encounter maam as a most experienced technician.Thanks.
Dec 23, 2011 | Mintek MDP-1770 7 in. Portable DVD Player...
Red screen, horizontal lines, 2'' black vertical bars both sides
it looks to me that you are not a technician becouse you are measuring at the wrong places risking a hazard shock if you have a little experience get the service manual and check your power supply and the h v capacitors near the horizontal output if not please take it to your service center
Dec 16, 2009 | Televison & Video
43H71 43 In Projector
Use Toshiba STK392-110T X 2 for exact replacement..........T.
Nov 21, 2007 | Toshiba 43H71 43" Rear Projection...
Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
PT 47 convergence IC's? box? both?
Always suspect the IC's first, digital convergence prblems are actually pretty rare IC's go everyday. I'd check partsore .com Generics usually work fine, they are probably STK392-110's but check to make sure.
Apr 16, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
