Question about JVC AV-65WP74 Rear Projection Television
Troubleshooting AV-65WP74 It appears to be a "CONVERGENCE" problem right now but I want to be sure. I had the TV off and before that, everything was fine. Then about 40 min later I turned it back on and now I'm getting overlapping objects. -And I tried CONVERGENCE but my red line graph WILL NOT line up. Please help if you can???
  • DUDE-13 Jun 26, 2008
    Hey Thanks Slinteriors for your advice. I will definitely check up on those parts you mentioned. Thanks! I have another problem as well. When my convergence problem appeared, my TV volume also took a dive. I have to put it at a level of almost 40 to hear it decently. Any answer is appreciated. Can anyone help???
  • JVC Master
  • 8,617 Answers
You need to replace the two Convergence amp ICs they are both STK392-110 thats a easy reapir on that model , But dont remove the rear panel with the power cord plugged in you will destroy the digital circuits. the Ics are up front behind the speaker grille. You can get new replacement Ics at the following link with free instaltion instructions with pictures. Here's the link,
http://servicemanuals.vstore.ca/
Posted on Jun 26, 2008
Tv has started making red ghosts that go 2 the right of the screen, what is this problem?
Thats a convergence issue which is common for all rear projection models. The AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com will usually solve convergence issues. The kit contains both ICs and the associated resistors and the CD with repair instructions.
Sep 15, 2011 | JVC AV-65WP74 Rear Projection Television
I have a jvc model av-65wp74. my green convergnece wont align at all
Convergence ICs and resistors need replacement. Very common issue. The AV48WP74 -AV65WP74 convergence repair kit from www.tvrepairworld.com has the 2 ICs and associated resistors plus the CD with repair instructions.
Aug 16, 2011 | JVC AV-65WP74 Rear Projection Television
I have a JVC HDTV model AV-65WP74, i had my tv on overnight, woke up this morning i found the colors on the tv kind of funny and the tv is also showing double images. Please help. What to do?
The convergence ICs have failed. You can get the JVC AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com which has the ICs and resistors plus the CD with detailed repair instructions.
Nov 08, 2010 | JVC AV-65WP74 Rear Projection Television
My tv the JVC AV-65WP74 the tv works its just the colors are split in half one is blue and other red like if it was 3d tv
hi, needs convergence ic`s replaced, possibly a couple of precision resistors, it needs a tech, this is not an easy job for a non tech, here in central fl. it runs $256, hope this helps, video-tek
Jun 04, 2009 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 convergence problem colors won't line up
did you replace the convergence feed resistors? If not they could be out of tolerance or one may have opened which would cause that symptom
Mar 27, 2009 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74
Hi, sounds like your convergence IC`s have failed if one of the colors doesn`t adjust either up/down
or left/right. If you have soldering equipment and are very proficient at soldering you can replace them. if not you definitely need to call a tv tech, if you need more info ask away, video-tek
Jan 26, 2009 | JVC AV-65WP74 Rear Projection Television
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
PCB's when available,are expensive.Replace convergence IC(s),
re-adjust and you are good to go!
Oct 12, 2007 | JVC AV-65WP74 Rear Projection Television
Green shadows and curved picture
the convergence apms ic"s need to be replaced
Aug 16, 2007 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 Rear Projection Television Logo
117 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
