Question about Dell Dimension 4700 PC Desktop
Monitor goes grey.
After a while of use, my monitor just goes grey. Sometimes on start up it will be grey. We'll be using it and it will just go grey. We can hear the sound and still type. when i adjust the monitor, it shows the main menu for the monitor, so I'm not sure its just that. Can you help?
    Novelist:
  • 148 Answers
It sounds like you have a faulty plug. Here are some things to look for Look in the plug itself for bent or (this ones the biggie) Pins that have been pushed in to the plug, Make sure they all line up evenly. On some monitors there is a setting for "Degausing" try that one. If you are plugged into a External video card meaning one that is not attached directly to the motherboard, Open the computer and make sure the card is seated properly. If it is a plug that is directly on the motherboard check to see if there are dust bunnies or dirt around the socket. A lot of household lint and dirt have metallic salts and can cause problems. Clean it only with aerosal air and nothing with any liquid cleaner. Good luck... Be mucho blessed...Mark
Posted on Jun 26, 2008
My monitor is about 6 years old. Some weeks ago, when I powered on, a grey streak started appearing and moved top to bottom before the normal image came on. Lately, the monitor blinks on and off when I...
2003 is the first one made, 14 years old it sure can be.
new to you sure,.
all monitors, from 2000 to 2010 year, are backlighted with
crude CCFL maps, that last for 2 years (shortest life full time)
the all go bad, ever one , if USED, lots.
they all: endup soon.
1: dim
2: yellow tubes.
3: flicker ands strobe (not the data just the back lamps)
4: dead.
5: totally interminttant.
just like the forecent lamps im garage and for the same reasons.
6: the osd goes dead to when above happens. menu key on monitor front, but not data seen with flash light trick.
learn when 4 happens, above, do this.
http://pcdied.com/monitors.html#flashlighttest
manual.
https://www.manualslib.com/manual/30069/Hp-F1523.html#manual
buy monitor 2011 and newer, and this pain above goes byebye
at the introduction of wonderful, LED backlamps.
Oct 16, 2017 | HP Compaq FP 7317 17" Flat Panel LCD...
I have fp567s monitor\r\nit often goes silver while starting and it needs monitor off button to be pressed (sometimes twice/thrice) for windows / boot screen to come alive i have re-installed the driver...
The silver hwite/grey screen means that the LCD panel is not getting the signals, 5vdc from the logic board. Try reseating the connections between the logic board and the LCD panel first.
Also check the power supply caps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Dec 13, 2010 | BenQ FP567s 15" LCD Monitor
Monitor no longer working after latop connection
Assuming that you are using Windows Vista, and the monitor is plugged in and connected correctly (with power on!), right click on your desktop, and select Personalise, and then Display Settings. You will see the second monitor greyed out. Right click on the greyed out monitor and select "Attached". Click Apply. The monitor should now be activated.
Sometimes, there are specific graphics card programs loaded on laptops, such as NVIDIA etc.. which may also control the settings.
Dec 09, 2008 | Dell Vostro 1500 Notebook
Sony Laptop Screen goes Grey
1.What I need you to test is...When laptop monitor go grey try plug external monitor and see that it work fine or not ??
2.Incase it work fine try to give a little tap behinde the laptop monitor and see that any changes...keep try and harder and see
3.Incase if you gave a hard tap also and its still the same but external monitor work fine then....I think you have problem with your LCD monitor coz there are chips that control the LCD crystal and maybe when it goes hot it behave this way....in this case you can't change the chip...you have to change the LCD.
takecare.
Jul 18, 2008 | Sony VAIO VGN-FS640W Notebook
Sound problem on TV monitor L 2010
What are you using to connect to the monitor? Have you tried replacing the cable, sometimes cheaper HDMI cables can cause this issue
Feb 07, 2018 | LG L2010B (Grey) (Gray) 20.1" LCD Monitor
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Apple 30 inch monitor
No, this is not normal. This could be one of two problems. 1) internal connection to the "Y" array is somehow been compromised either through some defect in manufacturing or simply a loose connection. 2) The LCD converter board in the monitor is defective. In either case it's internal to the monitor and would have to be serviced. Have you checked with HP to see if the device is still under warranty? It just might be If not, you can try opening the unit and checking the connection on the left hand side towards the area you mentioned. But beware that the monitor does contain leatal voltages.
Nov 20, 2007 | HP vs15 15"LCD Flat Panel Monitor
Monitor Goes Black
Try to start in safe mode and check if you can change some of the video settings (resolution, refresh rate, etc). Maybe one of these settings is such that the monitor cannot handle properly. To get into Safe Mode, press F8 as soon as you see the Gateway logo on the screen while booting the PC.
Aug 08, 2007 | Gateway FPD2275W LCD Monitor
Sounds like a possible bad pixel. I would power the machine down, reseat the graphics card, reconnect the dvi link, and reset the PRAM.
Keep me posted.
Nov 14, 2006 | Apple Cinema HD 30" LCD Monitor
Dell Dimension 4700 PC Desktop Logo
Alun Cox
