Question about Samsung YP-K3 MP3 Player
Doesnt work
I tried plugging it in to computer and its not working.i tried charging it but it still not working. i also tried resetting it but that's not working either
  • lisafrank1 Jun 26, 2008
    I tried and it didn't work. It wouldn't turn on at all.Should i try doing the same thing on different computer?
  • Anonymous Jun 30, 2008
    Exactly the same problem. I've downloaded some files to K3, turned it off, and now I cannot turn it back on. When plug the USB cable (tried on different computers), it does not turn on either. The last time it was plugged in, the display said that it was fully charged. I bought it 7 month ago!!!!
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
  • Corey Knoettgen
    Corey Knoettgen Jun 26, 2008
    Definitely try a different computer - it's a good way to see if there is some issue with your own USB port(s). That was precisely how i fixed a Sansa Clip that I was about to give up on.
My dualshock 3 controller wont charge when i plug it in it doesnt do anything until i hit the PS button. then it will work fine but doesnt charge. i tried resetting it but it doesnt work. when it it...
First, try hitting the reset button on the back on your controller - it's located just to the right of the screw located just above the label describing the FCC information about the controller. The button can be pushed with a paperclip, toothpick, or pen. If this is unsuccessful, then try plugging your controller into a USB port on your home computer or laptop. Other than that, I would recommend trying to return your controller, it may have been constructed wrong and the warranty should cover it. Good luck!
more information:
http://www.ehow.com/how_5510542_reset-ps-controller.html
May 19, 2011 | Sony DUALSHOCK3 Wireless Controller...
I HAVE A TOUCH SCREEN COBY IT DON'T WANT TO TURN ON.
try to reset the unit this doesnt work plug it in the computer and let it charge. If it still doesnt want to turn on or work try to format the mp3 player
Feb 24, 2010 | Audio Players & Recorders
My upstage wont charge and keeps flashing on and off
Try reseting phone, if that doesn't work you will have to take it into sprint. This phone has alot of bugs.
Mike
May 10, 2009 | Samsung UpStage SPH-m620 Cellular Phone
My ipod menu button doesnt work so i cannot reset my ipod, and since i cant do that it doesnt hold a carge.. my computer doesnt even regonize it, it says its charging but when i take it off its not ev
With hardware issues like this you will most likely want to get the unit serviced or replace it. If the buttons are bad, then basically the whole ipod is broken as well
Apr 24, 2009 | Audio Players & Recorders
Wont turn on.
restore your computer it will fix the problem
Aug 11, 2008 | Philips GOGEAR SA6045 MP3 Player
Broke!
Try manually reseting the player:
press and hold the Select button while pressing the Volume Up (+) buttons simultaneously.
Also, after doing so, try connecting it to the computer, and leaving it for about 5 mins to see if you can get a charge. Then turn it on, if that works, you just need to charge your battery.
if that doesn't work, return and exchange it since you just bought it.
Mar 28, 2008 | SanDisk Sansa MP3 Player
Doesnt work
ok well first u hold the rest button for 10 seconds then let it charge on a diffrend computer for 4 hours
Mar 24, 2008 | Samsung YP-K3 MP3 Player
I have a GoGear device that won't charge
Hi, I had the same problem with my SA31xx, when I plugged it into my PC it made the normal usb sounds and then a flash symbol appeared over the battery on the screen. It would not charge at all, I replaced the usb cable and it now works perfectly. Hope this helps.
Oct 03, 2007 | Philips GOGEAR SA6045 MP3 Player
Ipod nano 1st gen sync/charge problem
Try these options i got them from apple when my ipod dident work trying a new port and reinstalling itunes worked for me 1)Reset your iPod. 2)Retry with a different USB or FireWire port. 3)Restart your computer and make sure you have the latest software updates installed. 4)Remove iTunes software and then reinstall iTunes software from latest versions on the web. last resort 5)Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide.
Aug 24, 2007 | Apple iPod nano
Samsung YP-K3 MP3 Player Logo
44 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
