SOURCE: Problem with stuck magazine....
I have used what Listener85 posted and the advice was spot on.The rubber mounts were tricky getting back on but persistance payed off. Thanks a mil, u saved me £100!!! Dan, Cambridge, Uk
SOURCE: Alpine CHM-S620 CD Changer Magazine
if you open the cage on the unit, you can pop the tray back out of the mechanism by VERY GENTLY turning the load gear on the carriage, be sure to not slip any gears on the drive or the changer will be out of sync and will be garbage unless you have it serviced by an Alpine service center. you are best to turn the 1st. gear beyond the carriage motor, or you can apply power to the motor (which I don't advise) to let the motor eject the tray. if you do choose the power method, be 100% sure of the polarity first otherwise you will damage the carriage and drive gears. the motor has a brass gear and the rest are nylon gears, the brass gear will very easily shred a nylon gear. want to be extra careful? manually turn the load motor gear itself, it will take alot longer to do, but will be the safest. I've been inside these machines quite a bit, hope I was able to help.
SOURCE: cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
SOURCE: Jammed CD & Magazine in an Alpine CHA-S634
Mine jammed after I dropped it, trying to swap it into a new car :-)
Same problem, however. Three of the six CD trays had wandered into the righthand mechanism (which selects and plays one cd at a time). Nothing else at all, most fortunately, was broken.
I removed the cover (3 screws on each side), and the small black faceplate that holds the eject button. The main faceplate came off too, needless to say; no screws, just tabs.
You have to remove the side brackets also, and the angle-adjust spring loaded pins on both sides need to be slid out. Then the body of the cd changer rotates out of its cover.
Now, you can see down into the mechanism. A CD was still stuck in the reader, along with several shifted trays. I could simply remove the CD, and with a small screwdriver, shifted the trays back over so that I could then successfully eject it. I removed and realigned the trays, which had been jammed, and it worked once more! Reassembled and reinstalled ;-)
SOURCE: CDC-3 magazine will not eject nor play, error on receiver indicates magazine error
1998 porchea boxter cdc-3 cd changer, The cd changer keeps on changing tracks as if their are no cd's in the changer. keeps going from 1 to 6 and then changes to radio.
