Question about Polaroid FLM-2601 Television
FLM-2601 will not power on
The orange/red light is on, but the TV will not power on. The TV is only 1-1/2 years old. When the problem started, I had to press the power/on button several times to get it to turn on. Now that does not work. I read one comment that stated to fix the problem you need to replace the 1000uf 35v Capacitor with a High Temperature capacitor. I do not know if this will resolve the problem. I also read that another part is required. PLEASE HELP!!!!!
  • 7 more comments
  • Anonymous Sep 26, 2008
    red light will not turn blue
  • detail911 Oct 14, 2008
    same problem
  • kmanj4 Nov 14, 2008
    Same problem, tv wont power on, just the red light and Polaroid is of no help, take no responsibility for their clearly DEECTIVE product. Filing complaint with BBB and also would like a class action suit filed
  • whateveritta Nov 18, 2008
    My TV just died no power where can I get the power supply part
  • Lamont3000 Dec 26, 2008
    I replaced two of the caps with 1000@60V that I seen posted here but cant find no more. Now all I hear is a noise like a bomb is going off
  • Anonymous Feb 08, 2009
    how do i know if they ae not swoolen? I have the tv had the ppower supply in hand and I couldnt see anything swellied up.
  • preludedez Feb 16, 2009
    which caps am I looking for? I had the ps in hand and didnt see any swoolen caps
  • kherzer Mar 06, 2009
    FLM-2601 is one and a half yrs old. One evening veiwing it started to make a poping, clicking noise then the pitcure and sound flickered then it shut down. I tried to power up and got the same result. Now it will not respond the red standby indicator light stays red..
  • locksopen May 18, 2009
    best buy no longer carrys the power supply, i ordered and 6 weeks later said it was no longer made,uggh
I have a 2-year-old FLM2601 that all of a sudden refused to power up, total black out. I searched the web and found the power unit seems to have a lot problems one form or the other. To keep it simple I decided to replace the whole power supply assy. I got the replacement part from "Best Buy Partserach". Part number: 6LM00220C0 (or Advent 667-L27M6-20C), about $90. I swapped the power board assembly, and everything work fine now, only hope this time it last more than 2 years…
It took a while to dismount the back panel, you need to get all the screws off, including those holding the bracket for I/O ports, the RF will remain connected by wire, but you can wiggle it through the opening when back panel comes off. I Also took the TV off the stand.
Posted on Sep 27, 2008
Hi there, greeting from Colombia, excuse me my bad english
In fact if you can see two electrolitcs bads, this is not all the cause. The power suply is ofering more voltaje that indicated. Due to one electrolict bad in the hot ground. The frecuency of work is too low and the voltaje in the cold ground is very high.
I prefer to change all the electrolicts in the power suply.
Posted on Feb 26, 2009
    Sergeant:
  • 280 Answers
Bad caps is often the problem but they can be difficult to replace since they are soldered on both sides and you have to get the polarity correct. One mistake and you fry the board.
But if you try the Caps to us are 1000@63v. you up the voltage and they will not fail again. and there is usualy at least three of them. look for the ones that are puffed up at the top.
Posted on Jul 10, 2008
I went ahead and replaced the whole power supply 5 days ago, so that fixed that problem.
Now today I had trouble getting a picture but had sound I had to turn it on and off like 5 times
Posted on Jan 13, 2009
    Problem Solver:
  • 3 Answers
1000µF 50V 20% Axial-Lead Electrolytic Capacitor is the highest Radio Shack carries , Would these work ?
Posted on Aug 16, 2008
Polaroid FLM 2601 flat panel TV won't turn on
Power supply board is dead.Replaced the power supply board.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 18, 2010 | Polaroid FLM-2601 Television
No power just dead, even when using the remote and the t.v. power button
ya bad transformers in these models sad to say cost around 200 local tech shop take it in these are the cheaper line know for having bad power
Feb 04, 2008 | Polaroid FLM-2601 Television
Polaroid flat panel tv will not turn on. the red
you have a blown cap in the power supply it will be puffy on top replace them or have it done
Sep 19, 2009 | Polaroid FLM-2601 Television
Power cycles when turned off
repeair your power supply again,change some of capacitor or diod and through soldering
Aug 28, 2009 | Polaroid FLM-2601 Television
Need code for flm 2601 to program direct tv remote
need code for flm 2601 to program direct tv remote
May 07, 2009 | Polaroid FLM-2601 Television
No Power Supply for FLM-2601
Try these two links below, e-mail me and I'll see if I have this particular pwr-supply in stock. Send me the serial number of the tv....
http://www.partstore.com/Default.aspx
http://www.73.com/a/0121.shtml
Jan 06, 2009 | Polaroid FLM-2601 Television
Doesn't turn on
Pretty good chance the power supply board is bad. A number of capacitors will become leaky and you lose all power. Some techs still know how to do component Laval service but most just change the board $$$$
Jul 10, 2008 | Polaroid FLM-2601 Television
Polaroid FLM-2601 power supply board
The part number is 6LM00220G0 and is priced at $80.54 at circuit city repair. It is easy to install once you remove the cover from the back of the TV and the housing for the power supply.
Mar 23, 2008 | Televison & Video
Tv won't come on
chech ur line trasiformer frist of all check the collector voitage if it is ok
Jan 20, 2007 | Polaroid FLM-2601 Television
Polaroid FLM-2601 Television Logo
2,141 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
