Question about Whirlpool GGW9200L Gas Dryer
Dryer not drying
I have a kenmore dryer that heats the clothes & they are tumbling. But they are not drying, only getting hot. What could be wrong?
  • paxilkat Jun 27, 2008
    Thanks so much. I'll try taking the back of the dryer off so i can get to the airway. Which i see alot of wires & screws to take it off. Is there an easier way to get to the airway?
  • 246 Answers
Sounds like you have a ventalation problem. The clothes heat up, but without airflow, the moisture remains. First check the hose from the back of the dryer to the wall. Is it plugged, kinked, or restricted? No? Turn your dryer on and remove the hose. Do you feel pressure coming from the back of the unit? No? You need to take it apart and clean the internal airway. If you do feel pressure, reconnect it to the wall and start your dryer. Walk to the outside of the house. Do you feel a fair amount of air coming out? No? There are companies that will clean your vent in the phone book. There are also vent cleaning brushes you can buy at hardware and appliance part stores.
Posted on Jun 26, 2008
  • Toby Norton
    Toby Norton Jun 27, 2008
    Actually, from the dryer you've selected, you should actually go in from the front. The tube that goes from the front to the back of the unit, usually remians fairly free of debris. You can however reach in from the rear vent and pull out any minor build up. But for the most part, here's how you clean the major area of conjestion. Unplug the unit. Remove your lint screen. There are 3 1/4" screws on the botom of the lower front panel. Remove these. You may see lint once you drop your panel and even a few coins. Next, you will see an enclosure in the lower front center just underneath the panel you removed. There are 2 1/4" screw at the top corners of this enclosure. Remove these. Depending on the model, there may be another 1/4" screw down a bit lower on the left hand side. Other models will have a black clip on the bottom center. You can loosen the 1'4" screw on it or just bend it slightly down. Now the whole lint chute will come out. Once it is out, vaccume it out making sure to remove the lint on the "channels" on the right and left sides at the top. Underneath the lint chute you will see a fan in there. Make sure to vaccume this out as uneven build up on the fan blades can cause uneven wear and can ruin your motor bearings over time. Re-assemble in the reverse. However, while you have your lint screen out, take it to a sink or outside to your hose. Apply a small amount of soap on the screen and scrub it with a tooth brush. Over time a clear film from undisolved detergents can build up causing poor airflow.
Put the cloths in the dryer like usuall and waited for peep to let me know its dry. but when i heard the peep assumed the cloths will be dry, the cloths were just like i got out of the washer, wet. it is...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | LG DLGX8388 Gas Dryer
My 80 series Kenmore Dryer is heating up, tumbling, but my clothes aren't drying. It's taking 6-7 cycles to get anything dry, I have checked the vent hose and everything. All seems to be checking out ok....
You need to check your vent, or your vent system in your dryer. You also need to check to see if your clothes are tumbling. If not then your belt could be broke. Good luck!
Aug 21, 2010 | Dryers
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Kenmore 64672 dryer gets hot but clothes still wet
you have a clogged wall vent or clogged dryer vent or a clogged lint trap,you are trapping all the hot wet air in the dryer and that's why it's taking so lont to dry-mike
Apr 22, 2009 | Kenmore 64672 Electric Dryer
Whirlpool GGW9200L Gas Dryer Logo
147 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
