Can't get reciever audio to come out of my surround sound dvd player??? Keeps saying HDCP Not Compatible. I've tried A/V cables, Optical cables, and HDMI cables. Can either use 1 or the other Dvd Surround sound or sattleite, but not both. What's the deal??????
srry but the tv is not capable of sending hdmi audio through its outputs the dvd player audio must be run through rca red and white or black if you have digital audio out to the back of the receiver on its own channel
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
go to the DVD screen and hit home button, scrool to the "EZ" icon and it will say AUX or OPTICAL. Chose OPTICAL and swich back to cable and you should have sound. This will work, and no the manuel does not tell you this and most techs have no idea. Best luck
S-Video is a media type that only carries video. Unfortunately the LG unit was designed only to be a self contained surround sound unit. There are only video outputs to the television on this unit. Because of the unit having surround sound capabilities, LG felt that their wasn't a need for audio output. You would need to buy a new DVD player to allow audio from the DVD to your new Yamaha unit. Good Luck!
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
1. cable box video out to video 1 in on the lcd , audio out to reciever input 1 ( tv, vcr , or what you want it on )
2. dvd s-video output to lcd video 2 s-video input , dvd audio out to reciever dvd/cd audio input , and add the optical or coax cable digital audio for dolby digital surround sound
there will be a subwoofer pre out( needs to be amplified) or if it don't have subwoofer pre out you will have to send the audio out to a stereo reciever that has inputs for the optical ( digital audio signal )( to a stereo or surround system that has 5.1 or higher has full surround sound ) and of course L and R audio inputs and the subwoofer pre out , then the subwoofer pre out will have to be amplified by a reciever , subwoofer amp , surround sound , ect
