Question about ASUS P5RD1-VM Motherboard
Seagate 500 gig HD found in bios but not in my computer
Dell demension e510 currently running seagate 150 gig hd
    President:
  • 2,351 Answers
Once windows has been updated to SP2 & all it's updates, than windows should show the correct drive size.
Mike
Posted on Jun 26, 2008
  • Mike Peluso
    Mike Peluso Jun 27, 2008
    I say this to so many people who have a problem with the bios reading the correct drive size but windows not. You need to go to the manufacture's web site for you're 500GB drive. One register you're drive there online. Two, download their bootable floppy disk software or their bootable CD software & use that software to setup the FAT. (File allocation table). Use the software & choose the cluster size you want & format the drive. Than reinstall winows. Do not over write windows, do a freash install & do not use windows to format the drive. That will fix you're issue.
    Mike
Hi, My Seagate Freeagent 500GB Go HD (Hard Drive) has switched to Raw format. I want to convert it back to NTFS so I can retrieve my data. The drive shows up in My Computer or Computer, but I can not...
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Sep 19, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi!, I'm trying to install a brand new WD 500 Gb HD on a Dell Optiplex GX260. The problem is that even though I can see the HD on the BIOS Setup I can't get pass the Message... Press F1 for help or F2 (For...
boot to BIOS
turn on caps lock, scroll lock and number lock,
Press ALT+E (Should get a Single Beep) Press ALT+F (Another Beep) Press ALT+B (Reboot)
Make sure you have Windows CD in Optical drive and once it reboots it should start the OS load
If you don't have the most current BIOS, you may need to install old HDD, Download and install latest BIOS then repeat steps above.
Sep 02, 2010 | Western Digital 500GB My Book Pro-External...
I have an acomdata external HD enclosure with an 80 gig seagate HD. I plug it in to my dell inspiron 1300 laptop running windows xp pro and it recognized the hardware the first time I hooked it up but I...
Have you been able to access the drive in the past? If so it might have become corrupt so do a reformat of the drive and format it to NTFS. You can also uninstall and reinstall the drive for your HD before doing this. Pretty much a last resort.
Dec 15, 2009 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
I replaced my hard drive with a new Hitachi 500 GB and it only reconizes 32 GB.
What format did you use? it must be at least FAT32 to recognize more than 32Gb.
Check BIOS settings too.
Sep 17, 2009 | Dell Dimension 2400 PC Desktop
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
How to install seagate ata IV hardrive
The easiest way to upgrade from your old HD to the new 40Gb HD is to clone the old to the new. Do a google for "hard disk clone" freewares. Personally I use Partition Magic and have had very good results.
Hardware wise, you need to install the 40Gb as a slave to the old HD by connecting the same IDE cable as that of the old HD (you may have to remove your CD/DVD temporarily). You also have to temporarily remove the single jumper of the 40Gb to allocate it as a slave to the primary master (old HD). Plug in likewise the 4 wire power connector. On power up go to your CMOS/BIOS setup to verify that your PC autodetect the 40GB (you may have to do a manual detection). Boot your PC and go through the normal boot sequence. Thereafter download your clone software choice, install and run. Follow on screen instructions. You may need to reboot. After completion, use Windows Explorer to verify that everything has been copied. Power down, remove the old HD, relocate IDE cable connector of the old HD to the 40Gb, reconnect your CD/DVD, and place back the jumper of the 40Gb. On popwer up go again to your CMOS/BIOS to verify that the 40Gb & the CD are detected. Save & exit, reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 18, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Internal hd ata
If I am right on this one the 4600 can only take a 250gig hd But I was wondering if you could partion the HD to 236.7 gigs twice so the computer only recognizes the 236.7 gig hd you will see two drives in my computer once you do just format both partitions unless you have another hd and then you will see three drives just do the ones you installed or you may loose your operating system, I don't even know if that will work, but I think it is worth a try seems you already have the 500gig drive, can't hurt to try, I sure hope this help some what.,
Dec 22, 2007 | Dell Dimension 4600 PC Desktop
ASUS P5RD1-VM Motherboard Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
