The red lamp light started blinking yesterday, and now the tv won't come on. whats the average price for this part ?
  • aromano69 Aug 25, 2008
    the red lamp light is blinking what do I do?
    Genius:
  • 2,035 Answers
TRY THIS.......
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Certainly, I can help you. I would recommend going to the following link and getting the service manual so he can see first hand disassembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 26, 2008
My Sanyo tv is not working. The power light comes on and then starts blinking red.
I myself had a 55 inch hdtv ready projection tv and the lamp went out in it. It cost me $104.00 plus shipping to replace it. Check out discount replacement parts but remember that if it is a projection tv, it won't last but approximately two years and you will have to do it again.
Aug 25, 2012 | Sanyo SELECT PLC-XP45 Rear Projection...
Green light stays on red light blinks set won,t go on but bulb does not look blown also fan does not run after tv is shut off like it use to before and tv shuts itself off after a while when it does work...
With a dim picture even if lamp looks ok I would make it suspect number one---going to have to decide if you want to buy a new lamp to find out--average life is 1-2 thousand hours.
Apr 23, 2012 | Toshiba TheaterWide 52HM84 52" Rear...
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
My sOny tv KF-42WE610.. Won't turn on.. I just
Please let me know how many times it will blink to determine where the exact fault came from.
Jdvillanueva
Jun 17, 2011 | Sony Televison & Video
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv not turning on
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
Mar 19, 2009 | JVC HD-56G657 Television
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Mitsubishi Wd-52525 HDTV Stutis light constant red
Here is the link to the manual if you need it; http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf page 97 states that the lamp is the problem -(the flashing green just means startup - page 11) 14 months sounds about right for a new lamp if you use it a lot - that would be an average of 5&1/2 hours a day if the lamp went to 4000 hrs - although these lamps are more dependable than normal lamps, they can still fail anytime especially if they have been touched on the glass by accident while installing or cleaning, or if the tv is often switched on and off. The fact that there was no message on screen may mean that the lamp has not gone past the warning trigger number of hours - sorry i haven't found what that value is. page 95&96 gives all instructions how to replace lamps and where to get spares - if the price seems bad then search around - prices often vary a lot on these lamps. It is a little disappointing that mitsubishi where not able to diagnose this - please let them know that their technical service is poor in the hope that they try harder. I hope this helps :) Hope this helps :)
Mar 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
