Konica 3135 error code 41
I have a konica 3135 and there is an error code 41-3. what does that mean? and how do i fix that?
  • wudacat Dec 11, 2008
    What code 41-2. Is it the same as 43-1
  • 168 Answers
41-3 Error Code is an Optical return problem. The Scanner is not returning back to home position like it should.
A common problem with this model machine is a small black gear on the drive motor cracks or ovals out. If you can locate this gear, you can try placing a drop of super glue on it and see if it will hold. This works if the gear is ovaled out. If it is cracked or split then you will need to replace this gear.
Hope this helps a little.
Feel free to post another question if you need more help.
Good luck,
Mac =)
Posted on Jun 26, 2008
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
What's the actual meaning of DTC codes 41, and 58, for this vehicle?
the meaning of codes 41 and 58 is:
DTC - 41 Ignition control error
DTC - 41 MEM- CAL error
DTC - 41 Cam sensor sinal error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 58 VATS System error
I hope this is helpful
Feb 18, 2013 | 1992 Buick LeSabre
Konica 3135 autofeeder F60 error
this error code means the interlock switch ms301 has failed or it could be the radf control board or the harness for ms301 it is almost impossible to find parts for these machines now. they are on the konica obsolete list sorry and good luck
Dec 03, 2009 | Office Equipment & Supplies
How do you fix a F 86 error code on a konica 3135 copier?
This error code not exist .Please tell me precise your problems and your error code.
Dec 02, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3135 Copier Code F 36
Well, I'm sorry to say that you're going to need a tech for this problem. You have a fuser problem...either a blown fuse, heater lamp, thermistor, or something...whatever the cause, the fuser is not heating up. And the code can only be reset within service mode, once the problem is repaired.
Feb 25, 2009 | Konica Minolta Office Equipment & Supplies
Minolta CF900 code C3250
CAUSE: Worn mylar.
SOLUTION: Refer to bulletin 3135 which pertains to the transfer drum joint Mylar.
If you can find a Konica Minolta dealership that can get the part or have tech come out and look at it A VETERAN (NOT MILITARY)Tech you have legacy Minolta now Konica Minolta, CF was first generation color. The mylar is dealing with the Transfer drum the big clear drum next to the drum.
Oct 20, 2008 | Minolta Office Equipment & Supplies
Copier: Konica 3135 p.81 Insert key counter
you have to be in the service mode.To be exact the 25 Mode.To enter turn power off,Hold down the "2"&"5"keys while turning power on.Then press the "p"key.Change the number you see to 57. So now you should see P57in the display.Then change the value from 1 to 0,then press Print.That holds it in memory.Then just turn off and back on.
Oct 16, 2007 | Office Equipment & Supplies
Error 41 in brother 210c
Error 41 means that the printhead is defectiv! You need a new printhead. Sorry, it cant be fixed anymore.
Oct 03, 2007 | Brother MFC 210C All-In-One InkJet Printer
172 people viewed this question
