Question about IBM TravelStar 40GN 20 GB Hard Drive
Dell laptop with no cdrom and travelstar HDD
Dell laptop with no cdrom .i want to take ibm 20gb travelstar out of dell laptop,with a foxcon plug and make ide adapter and install OS xp on to hdd via a standard PC mother board.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 62 Answers
In this case you would have to...
1) preformat the drive
2) make it bootable in DOS
3) copy the CD contents to the drive
4) boot the target computer with the drive and run WINNT.EXE in the I386 directory to start the install.
*OR*
2) copy the CD contents to the drive.
3) put the drive in the target computer and boot it from a DOS bootable floppy.
4) run WINNT.EXE in the I386 directory to start the install.
Posted on Jun 26, 2008
I need a new a new cable (fits an unusual 5-pin socket) for an ibm travelstar external hard drive
the dearlership should know what you need. the reason the socket is so different is to let you know, the stuff in which contained in this part is very sensitive and could major problems if you are not sure what your doing
Apr 13, 2012 | IBM TravelStar 40GN 20 GB Hard Drive
Computer not picking up IBM Travelstar hard drive
The warranty on any '20GB' disk-drive ended _years_ ago.
It is time to "retire" that disk-drive -- take a hammer to it, so that any data files on it will _never_ be able to accessed by the F.B.I.,
and buy a new disk-drive.
Oct 31, 2010 | IBM TravelStar 40GN 20 GB Hard Drive
I HAVE LAPTOP IBM THINKPAD T30 AND I WANT TO CONNECT HARD DISK 80GB OR MORE
  • Supported HDD thickness:
    • 12.5 mm for systems without the touch pad
    • 9.5mm for systems with the touch pad
  • Standard 20GB, 40GB, 60GB HDD sizes.
    Note:
    • The 60GB HDD orderable as marketing option part number 08K9688 has a height of 12.5mm and will not fit in the HDD slot of the systems with the touch pad installed. For these systems, it is only supported via the ThinkPad 2nd HDD Adapter for the Ultrabay 2000.
    • The 60GB HDD orderable as replacement service part number 08K9833 is 9.5mm.
  • Supports one additional HDD which can be used concurrently to offer expanded storage utilizing the Ultrabay 2000
  • S.M.A.R.T technology to issue an alert if a hardware failure is pending
  • ATA Bus Interface
  • 4200 or 5400 rpm
  • Although you can upgrade the HDD, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay 2000 HDD adapter is designed to provide this flexibility with a second HDD in the Ultrabay 2000 IBM says. I say if the OS recognises it and so does the BIOS, you're good. good luck, hope this helps.-jmattes p.s. I found this info on: http://www-307.ibm.com/pc/support/site.wss/MIGR-42218.html
Oct 17, 2009 | IBM ThinkPad T30 2366 Notebook
WINDOW NOT INSTALL
Take your computer to a qualified technician.
She/he can solve your problem, when you give more details about the problem(s) that you are experiencing.
May 31, 2009 | Hitachi IBM HARD DRIVE 20GB 2 5"...
Thinkpad T20 2647 HDD problem
on restart enter setup or bios and set to default settings
then restart and press f7 choose option to boot from cd
then press enter should boot.
if not then this is the site i use for bios updates www.wimsbios.com
don't forget to rate me
thanx
Feb 02, 2009 | IBM ThinkPad T20 2647 Notebook
Lost power lead
Sorry we do not sell parts here nor do we have a sure fire way to locate them for you from someone else. I personally have found eBay carries every kind of cable made of if you know what to look for.
Jun 28, 2017 | Hitachi IBM HARD DRIVE 20GB 2 5"...
T30 cant find os
when you start does it come to point where it shows xp and ibm
Jan 17, 2009 | IBM ThinkPad T30 2366 Notebook
Getting files off an old IBM TravelStar 20 GB Hard Drive
You can buy an adaptor that will connect your hard drive to a pc.
Ribbon cable from your secondary drive on pc goes into the adapator. Adaptor also coonects to laptop harddrive.
You also need to change from being a master driveto be a slave drive . see linkbelow.
http://www.hgst.com/hdd/support/tva/tvajum.htm
You can then copy file to pc a usb memory stick.
Oct 13, 2008 | IBM TravelStar 40GN 40 GB Hard Drive
Acer Travelmate 291LCi problem
how much free space left on hard drive? also check virtual memory settings and finally run scandisk and defrag on hard drive.
Jun 07, 2007 | Acer TravelMate 290 Notebook
IBM TravelStar 40GN 20 GB Hard Drive Logo
223 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
