Question about JVC GR-DVF21 Mini DV Digital Camcorder
E04 Error my Jvc digital camcorder model# GR-DVF11U has an error message of E04 on it, don't know what it means or how to correct it. hello i have an jvc gr-dvl30e with the same problem I recording and then i want to see wath i have and i got this e04 message. Can you help me? Greatings Pieter macpluk2scarlet.nl Model # GR-DVF21U. i get the E03 message when i am trying to play or record with or without the battery (i.e. using power directly through adapter). i cannot fix this no matter how many times i have tried. i would appreciate any help.
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Posted on Sep 02, 2009
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Jvc gr-d33 eo1 error in safeguard mode
this is one of many very common problems with JVC camcorders.
maybe one of these wil help you, good luck.
http://www.pechorin.com/m/2004/08/10/JVC_service_or_questions-218073.html
http://www.howtomendit.com/answers.php?id=30228
http://www.greenspun.com/bboard/q-and-a-fetch-msg.tcl?msg_id=00Apdo
for your next camcorder purchase, stay away from JVC products.
Jun 06, 2008 | JVC GR-D33US Mini DV Digital Camcorder
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
HOW!
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
E04 MESSAGE KEEPS APPERING. HOW DO I REMOVE IT AND OPEN THE DOOR
buen dia, por favor , tengo una camara jvc smx-260u, y no poseo el manual de instrucciones, podrian darme informacion acerca de este manual
mi direccion,
laguz77@yahoo.es
Nov 24, 2007 | JVC GR-SXM260U Camcorder
An error message.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA.
Nov 01, 2007 | JVC GR-D290 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
E04 Error
WOW! At first I thought this was a joke but it did work! Thanks.
Apr 16, 2007 | JVC Digital Video Camera
E04 message
Lisa, E04 is an error code which shows that one or both of the reels has stopped during play or record operation. We find that tapes with liquid contamination can stick to internal parts in the mechanism causing this error. Try another tape, if this does not resolve the problem something is defective in the tape transport. Good Luck to you! Joe Weibel customelectronics.org
Feb 09, 2007 | JVC GR-DVM70 Mini DV Digital Camcorder
JVC GR-DVF21 Mini DV Digital Camcorder Logo
479 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
