Question about Gateway 500GR PC Desktop
Gateway 504 GR No Power.
I was wondering if u can help me I have the sane problem as u no power on my PC just a green light on the MB.
Please let me know how u fixed it I cant figure it out.
Thank You,
Anthony
a_lazzara38@hotmail.com
I had the same problem. Turned out to be a bad power supply unit. Once it was replaced, machine was back to normal.
Posted on Dec 23, 2008
My Gateway 504 GR won't play WSOP or most Reel Slot games. How can i play newer games on my pc? 2002 version Windows XP Home, 915 chipset, Intel proc. 4 cpu 3.00GHZ 512mb 3000mhz. Thanks
Hello there,
The image below indicates the minimum and recommended system requirements of WSOP most probably you will be able to play the game. The problem might be your Adobe Flash Player or your Internet Explorer version. If your Windows Xp Home is genuine you might consider updating or download a Mozilla Firefox.
The links for Adobe and Firefox are located below the image.
Flash Player
Mozilla Browser
From what I know Windows XP by default have an Internet Explorer v.6.0 that is why you need to update your Windows. by the way you have to download Flash player if you have Internet Explorer v.7. if this does not work try the step below
1. Download the Mozilla Firefox browser and install setup 5.0.1exe. 2. Download Flash Player it will automatically update your Flash.
Hopefully this information helps.
Thank you for using FixYa.
Aug 04, 2011 | Gateway 504GR PC Desktop
I have a Gateway 507gr pc. Pushing the power supply button the fans turn the cpu light turn on and the pc does nothing else.
you'll need a good power source.replace the old one ; remove all conection from hdd ,dvd's etc..make sure you have a speaker on MB.remove all the ram you have and power on the pc ;you must here a long beep folowed by 2 short one's;if you don't hear it your MB or CPU are gone.But if you do hear then put back the ram and remove your video card and power up the pc again , you must hear a long beep folow by 3 short one ; if you don't hear your MB or CPU are gone but if you hear that means the power supply was the problem.
Apr 21, 2010 | Gateway 507GR PC Desktop
MB green light on but won't start
your power supply must be exact and both power connections to the motherboard must be connected. the green light will come on if voltage is supplied but will turn on a low voltage alarm which is a buzzing sound. or it just wont do anything
Jan 25, 2010 | E-Machines T3624 PC Desktop
I have a Gateway 504 GR and my brother got a few viruses on it. I tried to delete them in Safemode but failed. I then got our Windows Disk and reinstalled the OS. In doing so we lost all of our Drivers....
I assume you have copied the downloaded files to the Gateway computer.
When you click on the various downloaded files it unzips and creates a folder for each unzipped file and then the expanded the files are placed into this folder.
To install the various drivers, open each folder (one at a time) and run the SETUP file or INSTALL file that is in this folder.
Dec 21, 2009 | Gateway 504GR PC Desktop
System wont power on unless mb power connector on mb is reset
by mb pwr connector do you mean the swich on the pc case that you press to turn it on or do you mean the large block connector form the power supply ?
If you mean the case switch then you have a faulty one that is sendinga constant signal and locking up the power supply
Jul 17, 2009 | HP Media Center m7060n PC Desktop
E-Machine PC with only a green LED on MB on Boot attempt
We have repaired many of these systems. The board was damaged when the power supply shorted. You can get replacement motherboards at www.barebonekit.net click on the link on the left side for motherboards and look for Emachine.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Same problem - green "power" LED on the MB but no activity
This series of machines is known for this issue. You can get a replacement motherboard for your pc from a website at www.barebonekit.com they boards run from $35 to about $65 plus shipping. This is much cheaper than you can get them most other places. We order from them on a regular basis and have had no problems. I hope this helps, if so please rate the solution.
Thanks,
Buddy
Jun 17, 2009 | E-Machines T2893 PC Desktop
Gateway 700XL, yellow light only when power is pushed on.
You are on the right track. First, swap out the power supply. That normally is the issue. If that's not the issue, verify that the power switch indeed is working. You can do that by determining which color wires are for the power switch, then hold a multimeter set to resistance on the ends of those two wires. When the button is pressed, it should go to zero. If not, then the switch is fautly. That is an unlikely scenario, however. If the new power supply fails to work and the switch is okay then the problem is the motherboard.
Thanks and please take a moment to rate as fixya.
Dec 12, 2008 | Gateway 700 XL (700XLDFM) PC Desktop
Gateway 500GR PC Desktop Logo
185 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
