Question about Cameras
The color balance of the video output from my Sony DCR-PC100 is off, especially in the green/yellow range. Color balance looks right on the LCD screen, but when output to tv or PC screen, color balance is as mentioned above. Otherwise, camera seems to be operating fine. What would you suggest be done? Thank you
  • blittlejohn Jun 26, 2008
    Thank you for the quick reply. I will try changing resolution and see if that helps. If not, will remove battery, wait 30 minutes and then replace.
    Removing battery did not fix the problem, nor replacing battery with a new one.
    Any other suggestions?
    Guru:
  • 859 Answers
Can you do a manual white balance by shooting at a while board to set it? and then check the output.
Should you have done this and there is no change then a chip is failing on your camera board.
If you are in warranty you're in luck, but if not, you need to have service. Some white balance oddities can be corrected in software with your application program, but if auto equalize, auto adjust, etc. is not working either then you don't have much choice.
I thought through whether a firmware update would do it for you but you would have to talk to the maker. My guess is no. Relying on firmware updates for all our fixes is a crutch we lean to heavily on.
Sorry there is no easier answer than this. Maybe another tech has an answer. Well, have to see. Sorry for the bad news.
Worldvet
Posted on Jun 26, 2008
  • 1 more comment
  • Glenn Rogers
    Glenn Rogers Jun 26, 2008
    Good on ya. Glad its fixed.
  • Glenn Rogers
    Yes, you will have to call the manufacturer and explain the problem and the troubleshooting you've accomplished with our help.
    Sorry, but your white balance chipset is failing and can only be serviced at the factory.
    Regards,
    Worldvet
  • Glenn Rogers
    BTW, since AJKILL's solution did not work for you you will want to remove the Fixed rating you gave and give him a helpful at least or whatever you choose it is your choice. The person who gets a fixed rating will be the one who is credited with a, four dollar payment.
    Genius:
  • 1,226 Answers
In this issue found no issue on the tv and in the sony. You can try fixing the cable connection from the sony to the tv may it was lessen projecting bad image. Or maybe replace the cable if found erroneous.
melnavz
    Genius:
  • 2,035 Answers
Choose different resolution and try play if you face the same problem please remove the battery and wait for 30 min and replace the battery and try to using it ,as it hard reset .................
Sony Trinitron's colors have turned green yellow
Only yellow color denotes the absence of Blue color. Check it. Check its video output card for any loose solder terminals at the blue color output section circuits.
Jan 12, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
1) I have a Sony KV-32FS13 that has a green tint in the picture. Does any oneknow how to access the service menu for this model? I tried other adjustments and I can't get rid of the annoying green...
Code 5 is "AKB error". AKB, or auto kine bias, is a cicuit that monitors the three color guns of the picture tube (red, green and blue) and tries to adjust them for proper color balance. If it can't, the picture is blanked (usually) and the timer/standby light blinks 5 times. When the color drives aren't balanced, you see a color tint in the picture like you're describing.
There might be a problem in the AKB circuit, or the picture tube may just be old enough that the AKB circuit has run out of adjustment range. If the tube is at fault, you should consider replacing the set. A new tube will cost nearly as much as a new 32-inch LCD TV, and you'll need to pay someone to install it and set it up. There are special tools required to perform the convergence which gets the color guns aligned with the face of the tube so they hit the right colors.
If you'd like to try tinkering with the service menu adjustments, this site explains how to access the menu and gives a list of settings.
Jan 02, 2011 | Sony KV-32FS13 TV
Sony Bravia 40'' LCD 240Hz TV can't get video signal from DVD
Are you absolutely sure you have it wired up right? Are the Cable RIGHT wires color to color, is the "Correct Input" selected? Remember you do NOT use "Channels" but an AV, AUX, or External.input. Most DVD etc, use AV, IE: Yellow, (Video), Red, (Audio), White (Audio) for the OUT connections. These go color to color at TV end. And uses 3 Cables. The "Other" type of Output/Input is Component Video. This is ALL Video, Red, Blue, Green, these go color to color as well. BUT you MUST also send the Sound, Via the AV, IE: The Red & White, AV, Audio IN/OUT connections, So you in this case would have 5 cables/connections in all.
Feb 13, 2010 | Televison & Video
LCD screen is only displaying the color green
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. Good luck
Meggita
Jun 26, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
My camcorder
If you are not getting good color picture then I would advise to perform white balance adjustments in service data with help of concern service manual.
This kind of adjustments required service data handling tools, reference color charts, proper and up to date service manual etc.
Please contact nearest Sony service center for proper fix.
Oct 07, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Color balance of video output
an estimate of repair is pointless it would cost less just to get a new camera.
Jun 26, 2008 | Sony Handycam DCR-PC100 Mini DV Digital...
LCD screen all blue
i think it probably happened because either you let it be under direct sunlight, that can screw it up
or, your not pressing play
or, you color setting for your lcd screen is messed up and all the red and green colors were taken out, change it menu
check the color, if not try pressing play, or its messed up have sony repair it
Mar 25, 2008 | Sony DCR-DVD602E DVD Camcorder
TVR-350 A/V JACK OUTPUT IN BLACK AND WHITE ONLY
under the lcd is ? an . . . s - video connector ( color is separate there ) if color looks ok out of the s - video , there may be a loose composite video connector cable inside camera ( warranty is void - if you open it to check ) ;
Sep 11, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
Cameras Logo
42 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
