Question about Xerox DocuColor 3535 Copier
Error code 010-348
You had told another user that you would send them info on resetting NVM location. Any way I can get that instruction from you also? I'm in a real printing bind with major deadlines. Printer was running a job just fine, ten suddenly the fault requiring restarting. I've restarted several times with no luck.
  • Anonymous Jul 18, 2008
    010-348 error on my xerox 3535
Hi go to system settings and then go to NVM location then type 744-003 and then change the value in the lower field to 0.
Posted on Nov 19, 2008
    President:
  • 2,072 Answers
I wish I could. I no longer have documentation for those machines. So Sorry, I would love to help.
Posted on Jun 27, 2008
WHAT IS THE NVM RESET FUSER CODE FOR THE XEROX 7545 COPIER\
Have a look at the following link:
http://www.enxmag.com/2013_months/aug2013/WorkCentre7425StyleFaultCodeList_82013.htm
It has a list of fault codes and also tells you how to reset NVM counts. Look in the bottom right of the page for the instructions. Hope this helps.
Jul 16, 2014 | Xerox Workcentre 7545/P 7545P Color...
Send me sumsung champ all secret codes ....??? m nt getting exact codes pls help me soon
General Diagnostics: * *#0*# - LCD Test Menu. * *#06# - Show the IMEI number. * *#367# - DB Profile Setting Menu. * *#1234# - Displays the Firmware Version * *#9324# - Phone Monitor. Press up and down to display more. * *#0228# or *#9998*228# - (BAT) Battery statistics. Press up and down to display more. * *#0289# or *#9998*289# - (BUZ) Buzzer test. * *#0638# or *#9998*638# - (NET) SIM network ID. * *#0746# or *#9998*746# - (SIM) SIM Information. * *#0778# or *#9998*778# - (SST) SIM Service Table. Press up and down to display more. * *#0782# or *#9998*782# - (RTC) Real Time Clock Display. Press the "#" key to refresh * *#0842# or *#9998*842# - (VIB) ******** test. * *#1111# or *#9998*1111# - Displays the Software Version. * *#1234# - Displays the Firmware Version. * *#2222# or *#9998*2222# - Displays the Hardware Version. * *#4357# or *#9998*4357# - (HELP) Code help screen. Press up and down to display more. * *#4777*8665# - GPRS Test and Configuration Menu. * *#5002*8376263# - Additional handset information. Press up and down to display more. * *#9998*76# - (PN) Production Number. * *#9998*377# - (ERR) NVM error log. Press up and down to display more. * *#9998*667# - (MMS) MMS Debug. * *#9998*968# - Yamaha test. * *#9998*982# - Edit IM settings * *#9998*2576# - (BRKN) SIM Error. * *#9998*3323# - (DEAD) Forced Crash. * *#9998*5282# - (JAVA) Java Profile Menu. The "Install MIDlet" password is "235282′ * *#9998*5646# - (LOGO) GSM Logo set. Press up and down to set.
WAP Configuration: * *#82# - Display WAP User Agent. * *#92782# - Edit the WAP User Agent. Default setting is "SEC-SGHD807/1.0 TSS/2.5′ * *#827# - Display WAP UA Profile. * *#927827# - Edit WAP UA Profile. Default is setting "http://wap.samsungmobile.com/uaprof/d807_10.xml"\
Digital Audio Interference: * *#3243948# - Digital Audio Interference (DAI) OFF (Resets Phone) * *#32436837# - Digital Audio Interference (DAI) ON
Bluetooth Configuration: * #*3888# - Bluetooth test mode * *#232337# - Displays Current Bluetooth MAC address * *#7263232337# - Changes Bluetooth MAC address. A random number is chosen and you will lose all your previous bluetooth connections. Use with caution!
Reset Codes: Data in the phone will be deleted! * *2767*3855# - Full reset * *2767*2878# - CUST reset * *2767*927# - WAP reset * *2767*667# - MMS reset * *2767*36245# - Email reset
Feb 28, 2011 | Cell Phones
Error3-315 when machine on error come in most times
3-315 Fault Code indicates that a communication failure
between the IOT PWB and the Post IPS PWB was
detected.
You may be able to enter diagnostic mode and reset:
Entering Diagnostic Mode: First of all... to enter the User Interface (UI) Diagnostic Mode: Turn on the power... then while holding down the '0' button, press 'Start'. The screen will prompt you for an "Access Number"... use the keypad to enter '6789' which is the Default Access Number. This should bring you to a menu of options to choose from:
NVM Reset (Non Volatile Memory) / NVM Initialization
NVM Read / Write (memory adjustments)
Component Control (for testing sensors, motors, etc.)
Print (for running Test Patterns from Diagnostics)
Subsystem Check (for fuser nip measurement check out, and developer unit check out)
Max Setup (for setting up copy quality)
If reset does not work, you need service on the unit.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 11, 2011 | Xerox DocuColor 12 Printer
Hello, after a NVM reset my ADF stop working and color where in wrong places. I resolve the color problems but ADF is not working is this activated by a NVM code? Regards, Hugo
How did you resolve the color problem? I am having the same issue on a Xerox Workcentre 24. After initializing the NVM, the auto-feeder does not work and the colors are off. How did you resolve the colors being offset?
Feb 02, 2010 | Xerox DocuColor 3535 Copier
I'm trying to reset the altimeter and sea pressure but the watch. I've followed the instructions but the watch more often that not reverts back to default settings or does not respond to the calibrations...
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
If you continue to have problems with your watch, and the instructions in the user manual don't resolve your problem, you may have to return the watch to Suunto.
Your watch must be registered with them, you'll need the serial number of the watch, which is located on the back case. You'll have to get an RMA from Suunto in order to send it back to them.
Here's their warranty info: http://www.suunto.com/en-us/Support/Warranty-information/
Oct 11, 2009 | Suunto Vector Wristwatch
Error-9-354
User Interface (UI) DIAGNOSTIC ENTRY:
Turn on the power… then while holding down the ‘0’ button, press ‘Start’.
The screen will prompt you for an “Access Number”… use the keypad to enter ‘6789’ which is the Default Access Number.
• NVM Reset (Non Volatile Memory) / NVM Initialization
• NVM Read / Write (memory adjustments) you will need to know which codes do what
• Component Control (for testing sensors, motors, etc.)
• Print (for running Test Patterns from Diagnostics)
• Subsystem Check (for fuser nip measurement check out, and developer unit check out)
• Max Setup (for setting up copy quality)
Set NVM to 776-060=0 and 776-372=0
Hope that helps
Mike
Sep 23, 2009 | Xerox DocuColor 12 Color Copier
Sanyo 4370 - Unable to find GPS
Make sure your GPS is not blocked. Try to acquire sattelite signals in an open and clear area. From Main Menu, tab Sys Info. and tab GPS Reset. After this, wait for a few minutes and check GPS Status again. Sometimes it takes a while depending where you are located.
Feb 14, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
9-358 error is there a reset nvm
no! there isnt, you need to replace this in order to reset the info inside, you can refresh the nvram but the info is still there
Sep 13, 2008 | Xerox DocuColor 12 Printer
536 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
