Question about Logitech Computers & Internet
Logitech Wireless mouse stopped working
The green light is on the black "connect" unit, (the green light to the left)  and the red light is bright on the wireless mouse, but it doesn't work.  I am desperate.
I put in new batteries, I turned off the laptop 3 times, but to no avail. what can I do?  I pressed connect on the little black unit that goes under your desk.  ALl to no avail.
 Will someone please help me.
Thank you, Ruth
    Scholar:
  • 51 Answers
Logitech cordless devices are designed to always achieve at least 4 feet of good signal. Generally speaking, if you ahve the green light on the connect unit and the batteries are good on your actual mouse then it should work when you perform the synchronization procedure in the manual.
If it is still not working after you re-perform that you should consider relocating your laptop to try again from another environment (any electronic or electrical devices like zip drives, cd drives, etc can cause interferance). try it on a non metallic surface and if possible even try elevating the connect unit a few inches.
If it's still not working, uninstall and reinstall the drivers for your mouse and try again. If after all that it is still not working it's probably a hardware problem and you should contact logitech support for a possible warranty item replacement.
Posted on Jun 30, 2008
  • fitnessequip Feb 27, 2011
    When my Logitech wireless mouse stops working, I press the reset button located on the underside of the unit. It works every time.
    S. Doran
I have a Logitech K350 Black USB 2.4 GHz Wireless Ergonomic Keyboard. For some reason the battery light is flashing red and green (alternating, one red, one green). And it's not working. What's...
This is a common issue with the Logitech K350 and there is no simple fix for it. It is simply a defect. On the plus side, this keyboard has a 3 year warranty. The best course of action for anyone who is having this problem is to contact Logitech customer support to get a replacement.
Sep 21, 2011 | Logitech Wireless Access Duo Optical...
Logitech wireless mouse not working
Go to logitech's website and navigate to support/drivers/downloads and look for the exact model of your mouse. You may have to temporarily use a P/S-2 mouse which would have a green connector on it in any case, it would plug into the tower or laptop at the green connection port. The purple one would be for keyboard. If can't do, then borrow someone else's pc and download the driver to a CD or flashdrive then use it to install driver.
Install the driver using the old mouse for now, then just after you give the command to reboot, pull old mouse or the P/S-2 mouse out and plug in the USB wireless device for your wireless mouse at this time. Reboot and should fix.
Your issue is either driver related or defective mouse IR no good (infrared)
I'll point you in the right direction but can't help any further without the exact model# of your w-mouse.
http://www.logitech.com/index.cfm/support_downloads/downloads/mice/&cl=us,en
Jan 02, 2010 | Logitech Cordless Mouse
Wireless mouse PID LZ639A6 just stopped working. What can I look at. I chnaged the batteries on the mouse. The wireless connect item does not show a green ''on'' light.
If its a logitech go to their web site put in your product in the product # and download their software pretty fast and works real well should solve your problem.
Dec 20, 2009 | Logitech Computers & Internet
My Logitech cordless mouse just stopped working. The Logitech connect device is plugged into the laptop and the batteries in the mouse are working as the green light is on.
Replace the batteries anyway.
It does not take much battery power to light that LED.
Whenever a wireless mouse STOPS working for no reason.
I immediately suspect the batteries.
You can first try switching to another USB port.
This often causes system to Wake UP and realize a new devise has been detected.
Does this happen in one spot?
There could be some device close by that is interfering with the signal.
Hope this helps.
Oct 04, 2009 | Logitech Cordless Desktop EX110
Wireless laser mouse stopped working. KB OK. Tried Everything
Under the mouse near the optical lens there should be a small connect button, press that and the button on the receiver too.
Also make sure the batteries in the mouse are new or fully charged.
Good luck
Jun 28, 2009 | Logitech Cordless Mouse
My wireless mouse has stopped working......noticed red light was blinking continually for the last couple of days. Have changed batteries with no success
Make sure that after you change the batteries that you re-sync the mouse with the receiver using the 'connect' buttons on each.
Hope this helps!
Mar 29, 2009 | Logitech PS2 BLACK OPTICAL WHEEL MOUSE...
Flashing red light
Most wireless mice will hibernate after a short period of inactivity. If something bumps the desk or moves the mouse it will start scanning again. If you don't like the light, you could try a laser mouse (no red LED flashing).
Feb 08, 2009 | HP Wireless Optical Mouse
My logitech mouse has a blinking orange light one it
had a similar problem. i took the new batteries out again and WAITED about 20 seconds before putting them back in. the red light stopped blinking.
Jul 21, 2008 | Logitech MX 600 097855036162
Computers & Internet Logo
2,116 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
