Question about Yamaha RX-V661 Receiver
Lightning Damage? My satellite was struck by lighting tonight. My HDDVR is connected to my V661 via HDMI cable. TV is connected to V661 via HDMI. When it happened a loud sound came out of my speakers and the receiver shut off. Now when I turn it back on I get no video from my receiver via HDMI. Concequently my HDMI port on my TV is not working either. Is there any hope that it's not completely fried?
  • 1 more comment
  • Anonymous Mar 15, 2014
    no audio to speakers, connected everything via hdmi
  • Anonymous Mar 17, 2014
    I have connect a HDMI Cable with 10m on a Samsung TV at the HDMI2(ARC) and on the RXV 1800 at HDMI Out. Ive no Sound at the Speakers?? Any Solution??
  • Anonymous Mar 24, 2014
    hdmi sound video
    President:
  • 624 Answers
First let me say I am sorry to hear this has happened to you.
I have been repairing these type of units since they came out on the market.
Yes there is a small ray of hope, but it doesn't sound good.
Unplug all of your equipment for about 3 hours and then plug it all back in again. I would not expect this to fix the problem, but it is always worth trying. It will reset all of your equipment and you can rule out the possibility that resetting anything will work.
Then make sure all the settings are right for the inputs they are connected to. When using these type of receivers, you must assign the inputs to the proper digital device you are using, in this case the HDMI.
Because you heard the loud pop in the speakers, you do have a problem in the receiver. Most likely it is in the digital board that the HDMI plugs into. These are very costly boards and in many brands they do not offer them as a replacement part. They are extremely difficult to troubleshoot and repair at board level also.
Even though this may sound bleak, if you have home-owners or renters insurance it should be covered. I have repaired and replaced many peoples audio/video systems covered by the home-owners or renters insurance for this exact reason. Lightning damage is a very common problem. Even most of the equipment protected by a surge protector can still be damaged.
But it is still a good idea to have the best surge protector you can get.
Contact your agent and find out about your coverage, and it is likely that you will be told to have all of the equipment in your home checked and then taken in to a repair center.
Once again I am sorry you have such a difficult problem.
If I can be of any further help, don't hesitate to ask.
Posted on Jun 26, 2008
  • Dave DeGain
    Dave DeGain Jun 26, 2008
    One more thing you should know, sorry I did not metion this before.
    If this equipment is under the manufacters warranty still, and you are not going to be able to claim it on your home-owners or renters insurance , DO NOT tell them the problem was caused by a lightning strike.
    Most manufacters do not cover things like lightning strikes.
    They only cover manufacturing defects.
    If you use your insurance to cover this, you will most likely have a deductable you have to pay. This is not a feasable way unless you have more than just the Yamaha affected by the lightning.
    So I repeat because it is important to know "DO NOT" tell the service center it was hit by lightning if you are using the manufacters warranty.
    Dave
    Genius:
  • Yamaha Master
  • 1,689 Answers
The ports are most likely damaged. It is also possible that there is deeper damage. The units should be properly checked and tested by an experienced tech who has the proper facilities to do the diagnostics and testing.
Jerry G.
Video drop
Try to isolate the offender. Start with one device and see if the problem remains. After a period of use, add in another component and see if the problems reoccurs. Once it does take out that unit and add in others, in the same manner, to see if others cause problems or the number of devices is an issue.
Jan 07, 2014 | Denon Audio Players & Recorders
Samsung tv lightning strike reset
It is likely the ac fuse which the power cord goes directly to got hit.
back would have to be removed and fuse checked.
Mar 18, 2012 | Samsung Televison & Video
We think that the t.v. may have been struck by lightning, but it turns on. However we don't see anything but the static screen, and don't hear any sound.
I would check your connections first. If I tune my 2006 Sony TV to static there is no audio also. I would go through and check all the connections. If you are connected via HDMI cable you can try replacing that cable with a new one. If still no luck you can always return the cable. Hope this helps!
Jun 17, 2011 | Televison & Video
CABLE BOX HDDVR IT's NOT WORKING WITH HDM1 in put. I have to use av1 source with 3 wire cable. Comcast tech saying it is tv problem.
I am not with Comcast, but rather a much smaller family owned cable company.
You can check the user settings of the box to verify it is in the HDMI mode. Depending on what type of HDDVR you have that is.
For Motorola 62XX and 64XX models follow these steps to check.
1. make sure that your HDMI cable is connected to both the TV and the cable box.
2. Turn TV on, and verify it is on the proper input.
3. Turn cable box off.
4. Press menu button on remote or front of cable box.
5. A user settings menu will appear on the screen.
Note: if it did not appear you may have to connect another type of cables to continue.
6. Information displayed should be set to what your TV set is capable of. Most HDTV's will be set to the following:
16:9
1080i
480i
7. If you see additional HDMI settings as the forth item your TV and cable box are communicating across it, if not try unplugging both the TV and cable box and/or replacing the HDMI cable. Enter the additional settings by pressing the right arrow on the remote.
8. Change DVI to HDMI.
9. Press power to exit the user settings menu.
10. Turn cable box on, and switch TV to HDMI input if not already on it and see if the picture is coming in now.
Note: if you think that you messed up in the user settings you can always restore default settings by following steps 1 through 4 then press up arrow once and right arrow once.
I hope this helps you cable customers, as we appreciate your business unlike Dish and Direct!
Cheers!
Jun 18, 2010 | Philips 47PFL5704D 47 in. LCD TV
The picture on my TV flickers on and off when I use my DVD player. The problem remains even when I switch to another DVD player. I think the problem may be the HDMI cable on my Yamaha rx-v661. Please...
You cannot run HDMI from any source thru the Yamaha to the TV. The V661 is 1st generation HDMI headache. Version 1.1 which basically is useless. Don't blame Yamaha, it's not their fault, it's HDMI. All manufacturer's receivers prior to 09' series use either 1.1, 1.2, or 1.2a. and they all have issues. So, here's the skinny, run your audio to your receiver via optical or digital coaxial. Then run video directly to the TV via HDMI if you wish. The problem arises when you have more sources than inputs on your TV. Depending on the size of your TV can make a big difference in how you wire it. If your TV is 50" or smaller, just use component, the human eye cannot differentiate between 720p and 1080p and that's a fact. second fact, most TV shows are broadcast in a native resolution of 720p, the only real 1080p programming is on HDNET, Discovery,National Geographic and The NFL.
What I mean by that is the camera used to take the actual picture is a 1080p camera. Major money! so, that being said, if your tv is larger than 50", and it's 1080p not 1080i yes, you can see a difference. If you post a comment and list all your product, I can give you the best possible way to put it all together. I feel your pain and aggrivation! I am a Yamaha, Marantz, Proceed, and Adcom Dealer. I get it from all sides! If there's anyway I can make it easier for you, I will. Hope this helps
Jun 24, 2009 | Yamaha RX-V661 Receiver
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
Setting up Cable with HDMI
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
May 13, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V661 Receiver Logo
555 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
