Question about Friedrich QuietMaster Deluxe RS12L10 Air Conditioner
Window A/C Air Filter is Soaked
I have a 4 year old window Friedrich A/C that has work flawlessly until now.
The unit runs continuously without cycling on and off.
Upon opening the front inside grill, the replaceable foam air filter is soaked with water. There is no visible obstruction either inside or outside of the unit.
Obviously, this is cause for concern. We called the local store and it may take a few days to get service. But a second opinion and information on what to look for would be greatly appreciated.
    Novelist:
    Champion:
  • 230 Answers
There is a drain tube that usually runs to the outside that is suposed to carry the water away from the unit. It may be plugged. You could use a shop-vac from the outside to pull it through. If you have compressed air you can blow the obstruction out to the inside. Be aware this could make a mess on the inside! After clearing the drain line I would leave the unit off for an hour or so just in case there was any frost building. Then turn the unit back on. If it continues to get wet then the unit may not be leveled correct, or maybe it is low on refrigerant causing the frost on the inside.
Posted on Jun 30, 2008
How do I turn off the check filter light on my Friedrich SQ08 window unit?
Friedrich window units should reset by pressing both the up & down temp buttons simultaneously. Had this issue for a while until I finally called the help center. For some reason couldn't find this info anywhere online. Hope this helps !
May 18, 2014 | Frigidaire FAC127S1A Air Conditioner
Friedrich A/C not draining properly
Yes i have in the past just unplug it to be safe. There might be dirt or bugs blocking drain hole or some of the coils might be freezing then thawing. Make sure there's an angle for it to drain.
Aug 13, 2012 | Friedrich Heating & Cooling
My 9 year old 17,500 BTU wall mounted window Unit is freezing over with little air coming out. New filter & clean coils still have same problem.
Sounds as though the indoor fan is about to give up the ghost.. 2 choices . 1 start looking for a newer more effecent unit. 2 replace the fan motor.. sorry but it does not sound good..Wiat I just thought It just might have a run capasitor ?? Not sure.. But it could be going bad as well .. Justa thought on that one. either way you can call a tech or buy a new unit.
Aug 08, 2011 | Friedrich Heating & Cooling
I have an older Friedrich- maybe 8-10 years. It drips so much water that it needs a towel underneath, which becomes soaked. The filter, which I removed, has fallen apart. I ordered a new filter which I...
If this is a window or thru the wall unit, the problem you're having is caused by 2 things.
1. The drip pan's drain hole near and under the rear of the unit is clogged and needs to be cleared.
2. The rear of the unit is not tilted down enough. 1/4" to 1/2" is the general rule of thumb. This allows the water in the drain pan to flow to the rear of the pan, where the drain hole is located.
Hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | Friedrich Heating & Cooling
Hi. My 2 year old Friedrich CP10E10 window unit is not cooling the room like it should/like it has. I followed obvious troubleshooting steps per the operation guide, including thoroughly cleaning filter....
Check the OUTDOOR coil... it sounds like it is clogged up and the system is cutting out on high pressure...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Friedrich CP10E10 Thru-Wall/Window Air...
Fan noise on Friedrich Model # CP12F10. Less than or about a year old.
Remove the shell of the unit and see if there is a obstruction in the fan,most likely is,if not look at the fan blades to see if they are tight on the shafts,if not,that is the problem.
Jun 09, 2011 | Friedrich CP06C10 Wall/Window Air...
Ac works but not cooling. The thermostat dosen't work properly.
open unit an check the thermoprotector on the compressor thats the problem
May 16, 2010 | Friedrich CP12C10 Wall/Window Air...
White dust
if the unti working good and cooling then change the filter it may be too old.
Sep 05, 2009 | Friedrich CP12C10 Wall/Window Air...
Friedrich QuietMaster Deluxe RS12L10 Air Conditioner Logo
171 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
