Question about HP Computers & Internet
Can not conect to internet because of norton internet sercurity
    Novelist:
  • 150 Answers
1) Open up the Norton's firewall settings,
disable the firewall altogether
2) Try your WEB browser to see if you get Google.
3) Disable the Windows Firewall, try again.
(Chose only one fire wall, never run both.)
4) Norton's is ****-ware that also scans your computer
for known pirated software, and uploads this information
to Symantec, who share this info with Microsoft
and others, including law enforcement.
This information was confirmed by a telephone call
to Symantec Canada tech support.
Their security software is also horribly slow and taxing,
(resource pig) so I would never use it.
I recommend AVG, with the WEB and link scanner
disabled (these also really slow down your machine).
For secure WEB browsing, I prefer Fire Fox, with
the Finjan and NoScript plug-ins.
5) Once all your security-ware is disabled, try the
Internet again.
6) If it still doesn't work, go to the DOS-like command prompt,
and type IPCONFIG /ALL
a) check you IP address, make sure it is NOT all zeros
b) type: IPCONFIG / release
IPCONFIG / renew
IPCONFIG / all
if you IP address is still zeros, your TCP/IP /network
stack is damaged, run the Windows network setup wizard!
if the IP address is OK,
type: ping www.google.com
to test the DNS settings.
if there is a problem, again run the network setup wiz
Once your TCP/IP stack is working,
and you can get to Google with your
WEB browser,
Re-enable your security ware one at a time
to see what is causing the problem.
If the firewall blocks your communications,
uninstall and re-install it, then let it auto-detect
all your applications during setup.
Once your WEB browser is working with the firewall,
you may also need to setup exceptions for each additional
internet applications, and for the TCP and/or UDP ports
that they need.
This is done within the firewall settings. You need to follow
the instructions that came with your firewall and your
apps.
It is also possible to setup the firewall to ASK your permission,
every time you run a new application, so that the firewall will
LEARN on the job.
Once again:
1) I don't like Norton's
2) The best firewall is a hardware residential router,
for about $50. E.g. Cisco, SMC ... etc.
The router let's you setup who and what can access the
Internet or the router itself, and block everything else.
It also allows you to share a single Internet connection
among several computers through network address
translation or NAT. Some even offer WEB site
blocking or parental controls.
The router will stop all hostile incoming traffic.
3) To stop outgoing (spyware) traffic from unsavory applications
or home-sick software like Microsoft & Adobe, install the
AVG anti-virus-firewall from Grisoft.
It is far superior.
Hope this helps,
Please rate my answers,
Martin
Posted on Jun 26, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
Try to disable it for a while and check if it is really the cause of your problem . Restore service once connected and check norton settings to allow connection
2 Suggested Answers
  • 108 Answers
SOURCE: NORTON INTERNET SERCURITY 2009 3040, 20001
I recommend removing norton and not using it. Use www.avast.com 's Home Edition - its free.
If you are unable to uninstall norton. There are norton removal apps with a simple search on google.
G'luck
Posted on Oct 24, 2008
Code key for nortons internet sercurity?
You have to purchase it before you are given the key code.
May 07, 2014 | Microsoft Office 2010
How can I get administrative permission to download new version of my Norton Sercurity?
It sounds like you are clicking the 'run' button. I would suggest you download it first. Once downloaded, right click on the file and select 'run as administrator'. That should sovle the problem.
Sep 24, 2011 | HP Pavilion zd8000 Notebook
Norton sercurity is not responding on my computer it does not start up and called my Internet provider they said norton my be blocking my Internet access by the firewall please help
You can easily disable firewalls in your computer however what I would suggest doing first is ensuring firewall is turned off for windows, If using XP: Go to Start/Control panel/Firewall and choose off Not Recommended
For Vista/Win7 Go to Start/Control Panel/System and Security/Windows Firewall/To the left hand side Turn Windows Firewall On or Off turn off.
If this does not help Here is a direct link,Just read Forum. Hope this helps http://www.techspot.com/vb/topic109836.html
Oct 02, 2010 | Symantec Norton Internet Security 2009
Dept ed new DER laptop connects to internet at school. Detects wifi unsecured home network, signal is excellent but little orange warning signal appears above connection bars and it won't connect to...
contact your internet supplier how can help with a lot of the sercurity problems.also your internet setup might be wrong for wireless as it may be only set for your broadband.you can check by checking start,control panel,internet options,connections,if broadband there should be nothing in box,if is remove,next press lan settings and see if the automatic detect settings box is ticked.next close, go back to internet options in the control panel, select security,click on local intranet and put a tick in the box.(enable protection mode).click on trusted sites and tick box(enable protection sites)check the restricted site and do the same. do this before contacting supplier. then go back to start,control panel and look for sercurity center this looks like a shield,double click , open and check all sercurity features are switched on.go back to start.and try internet explorer.
Dec 12, 2009 | Lenovo IdeaPad S10e Netbook
I cant update my NORTON 2008
That happened to me as well go to a person who fix computers to fix that is what i done.
Aug 05, 2009 | Symantec Norton AntiVirus 2008: Windows
NORTON INTERNET SERCURITY 2009 3040, 20001 error
G'luck
Oct 24, 2008 | Computers & Internet
Cannot conect to internet
hi dkk my suggestion to you would be to use the system restore feature,
1. click the start button, go to all programs, accessories, then system tool choose system restore, then restore it to date before you unistalled nortons.
2. go to this website and follow the instrustions on the removal of norton's
http://service1.symantec.com/SUPPORT/tsgeninfo.nsf/docid/2007080716240739?Open&docid=2005033108162039&nsf=tsgeninfo.nsf&view=docid
let me know if you can't connect after that or if you still have the problem after the restore.
Oct 08, 2008 | IBM ThinkPad 600E 2645 Notebook
Installation of anti-viruses..???
Yes, you can download multiple anti-viruses with no problem although you don't usually need to. They can bog down your computer if you have numerous applicaitons scanning your drives at the same time, etc.
If you are looking for something free...there are decent options out there like basic ZoneAlarm and some others.
If you don't mind paying for it, Symantec's Norton Anti-Virus and Internet Sercurity Suite is what I use. They are very good and constantly update their virus definition files.
Hope this helps,
Genie-Us IT
Jun 26, 2008 | Internet K50-00001 Natural Multimedia...
Conectivity issue
Norton internet security in some cases blocks anonymous requests for internet access. (your laptop) There are several ways to fix it.
1. If you go to Norton's configuration, you can select things that norton will unblock and allow.
2. Call Belkin and ask them what type of ports would need to be forwarded in order for your laptop to work.
Apr 07, 2008 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
