Question about Microsoft Zune JS8-00001 Digital Media Player
Charger where you charge the zune is broken so how can i fix that or i have too take it too a repair center.
  • Anonymous Jun 26, 2008
    my zune 30GB wont connect or charge
  • 8,596 Answers
Check Zune's website for troubleshooting. Here is a method that they don't have:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
I want to know if the Zune 120gb can be fixed will not charge and wont power on
When you can't charge it, it can't power on. Check the charger, but also the cable and cable connectors. Perhaps you even can borrow a charger with a cord to check what is wrong. The charger to the player.
Oct 07, 2014 | Microsoft Zune 120gb 80gb
So my friend gave me her broken zune hoping I could fix it. I've fixed psps, cameras, all her broken stuff before so she's hoping I can fix this too. She doesn't know what happened, she had let her sister...
You need the cord. Get her to mail it to you. Follow the reset protocol form zune support and reinstall the software. If that doesn't fix the code5 then it is the hard drive. They run about $80 on ebay.
Jan 28, 2011 | Microsoft Zune JS8-00001 Digital Media...
My zune dont charge i that be fix
Hello
Yes, it is a common problem for some of the Zune players. The charging unit in the player self might be broken.
Have you checked the charging cable?
Something else you can try is to hold down the play/pause button for a while, this will restart the unit.
If this does not work, click on the following link, where you will be directed to Microsoft's zune support page. They will be able to let you know where the nearest repair centre is located.
http://www.zune.net/en-GB/
Hope this can steer you in the right direction.
Kind regards
Andrea
Dec 23, 2009 | Microsoft Zune JS8-00001 Digital Media...
120GB Zune wont turn on
Please try to hold Back, Center and Left at the same time to restore the zune,
Jun 02, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I have Zune 30GB mp3 player. When I try to charge it using computer or wall charger, it tries to turn on and makes some clicking sound and turns off again. It does it repeatedly but can not charge it.
the zune does this if the battery doesn't work (needs a charged battery to power on). battery is either defective or disconnected. there is a zune repair guide that shows you how to fix it
Apr 22, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune won't charge
It's likely you have a motherboard issue. In some cases the dock connector is physically broken (pins get bent or break off), in other cases the charching circuitry becomes defective.
The only way to get it up and running again is to replace the logic board, the part is readily available on ebay. There are zune repair guides that will show you how to replace the logic board or have a tech savy friend do it for you.
Jan 17, 2009 | Microsoft Zune JS8-00001 Digital Media...
Unresponsive (and dead battery) zune o' saddness
Power sources that are supported loadTOCNode(2, 'moreinformation'); To charge the battery in your Zune device, you must connect the Zune device to one of the following supported power sources:
  • A computer’s USB port that you can connect to by using a Zune Sync Cable.
  • A Zune AC Adapter that you can connect to by using a Zune Sync Cable. Note The Zune AC Adapter is sold separately.
  • A Zune Car Charger or a Zune FM Transmitter/Charger. Note These items are sold separately.
  • An Xbox 360 console's USB port that you can connect to by using a Zune Sync Cable.
  • A “Designed for Zune” mobile battery pack
http://support.microsoft.com/kb/927348
Nov 09, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune
There is not a repair service for such a thing - the product will have to be replaced. Normally, I would say call the manufacturer, but MicrobeSoft might charge you for the call.
May 04, 2008 | Microsoft Zune JS8-00001 Digital Media...
Broken screen on zune. Is it worth fixing?
Look to the repair centers and get a price for a new screen.
Otherwise if you're feeling courageous you can always look on eBay for another Zune to part out for the screen.
Apr 17, 2008 | Audio Players & Recorders
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
