Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Loud noise at end of spin cycle
Washes fine, but at the end of spin cycle the machine vibrates and makes loud banging noise until spin stops, also leaking small amount of water on the floor from bottom during the process
  • 9 more comments
  • cbrat68 Jun 26, 2008
    Thanks so much. You took alot of time to explain all of that and I really appreaciate it. I was expecting it to be the drive block from what I had found researching so far. I will let you know how this comes out, and will definitely refer back to you if we have problems with the fix. Again, thanks a million...I envy the woman who has a fix it all man!
  • ash08 Jun 30, 2008
    I have what sounds like the same problem.  If I spin the basket even when the basket is empty, it makes a loud metallic (metal on metal) banging or clunking sound at every half turn. I spoke with Whirlpool and they suggested replacing the clutch spring. I did this and it did not help at all.  I have checked all the wear pads and plates and they are all in good condition. The shipping pins were removed as well. I have checked all the springs and made sure that the washer was level too. It does seem like the basket drops a little every time it makes the banging sound.  Also when you refer to the drive block, are you speaking of the drive motor or gear case?  I had the entire lower drive system apart today to replace the clutch spring and didn't notice anything out of the ordinary. Or at least anything that jumped right out at me.  Anything you can tell me would be a great help.  I was close to taking the entire top end apart before I came across this posting.  Thanks  Josh
    Also I don't know if this makes a difference but my model number is LSQ9010PW6.   Thanks
  • Anonymous Jan 09, 2009
    My washer makes a really loud vibration when it's stopping the spin cycle and going into rinse. When it's making the noise and slowing down, the water has already started to fill before it's stopped spinning. There used to be a delay between the spin cycle stopping and the water filling for a rinse.
  • whyatt_paul Jan 19, 2009
    I have the same problem - Whirlpool Ultimate Care II, loud baning at the end of each spin cycle. There used to be a delay to the start of the water being added, appears it maybe starting before the end of the spin cycle.
  • Anonymous Mar 15, 2014
    banging, screeching and clanging at the end of each spin cycle
  • Anonymous Mar 17, 2014
    Bush washing machine after the end of the process of Spinning the intervention of water
  • Anonymous Mar 20, 2014
    Loud noise end cycle
  • Anonymous Mar 22, 2014
    Water arrester, which is connected to my washing machine, is making banging noises when in use.
  • Anonymous Mar 23, 2014
    My hotpoint Ultima wmd960 keeps making loud banging noise when reaches end of cycles
  • 246 Answers
The most common cause of the symptom you are describing is a bad drive block which has probably ruined your basket drive as well. Let me give a quick explination. The weight of the basket you put your clothes in is supported entirely in the center of the washer underneath your agitator. It rests on an aluminum block called your drive block. So that the basket will move back and forth while the washer agitates, there are two tabs on the drive block that lock your basket drive underneath in place. Once the drive block wears out or round down these tabs, the basket will raise slightly and "skip" across the top when the spin cyle is stopped. To verify this, you can check one of two things. First (and easiest) is put a heavy, large load in the washer, get it wet then spin it out. Once the washer reaches the maximum spin speed, open the lid. The washer should snap to a halt when functioning properly. What I belive you'll find is that even with the lid open, the basket will continue to spin. The other method to verify this is take the top of the agitator off. Next remove the bolt in the middle of the agitator and lift the agitator off. In the middle, you should find a large flat metal colored nut.In the middle of that nut, you should see two tabs across from one another. There should be two straight pieces of metal coming up from the bottom which have nice, straight sharp corners. Again, if I am correct, you will find they have been rounded off and there may even be shavings of metal visable.
To replace a basket drive and drive block, you will need to purchase the parts and also a specialty tool from removal and instalation. These will probably run you around 125-175. If you are interested in giving it a go, reply back to me and I will get you some step-by-stpe instructions typed up.
Posted on Jun 26, 2008
  • 2 more comments
  • bob_by Oct 07, 2010
    i found that if at the max spin speed and I open the lid it make the banging noise and it didnt stop for a while. So it seems what is the problem is the basket drive and drive block.
    I need an instruction to try replacing my self. Could you give me the instruction.
    Thanks a million
  • gary_hall_1
    gary_hall_1 Sep 17, 2012
    mine does this thing with or without a heavy load it in. can you give me the instructions? please email to butch0829@att.net
  • Angie Harbert Oct 15, 2012
    can you please send me the instructions as well. We already tried replacing the clutch & it did nothing. Would really appreciate it. Not sure if this matters, but is a whirlpool with the model # LSR8010PQ2.
  • Russ Mills Dec 23, 2012
    Toby's solution was perfect. I ordered the drive block and basket drive online, along with the spanner wrench. Next, I followed two YouTube videos that explained the repairs in great detail. The YouTube videos are: http://youtu.be/lsgl6PSQwtc andhttp://youtu.be/AyVxl8ONW2c. I almost never post comments, but Toby's explanation and the videos were so good that I wanted to share them.
Kenmore 400 make loud banging noise at end of the spin cycle
It sounds like the drive block may be stripped out. To check it, you will need to remove the agitator to see if it is bad. Below is a video to show you how to access the drive block. Here is the part to order if you should find it bad.
If the drive block is good, post back to me and we will continue the diagnostics on the unit.
Regards,
Richard Roth
http://appliancecafe.com
Nov 15, 2012 | Washing Machines
Maytag Centennial washer makes loud bang and the end of cycle.
I don't think it would be the bearing, as no sounds abnormal occur during it's wash cycle. I think it's at the end of the spin dry cycle, that a "brake" is applied which stops the drum from spin drying, but is being applied overly hard, which causes the drum to "BANG", stop abruptly by the brake. Only a washer repairman could deal with that problem, but, it's NOT dangerous to the washer, IF that's what the problem is. Contact a washer repairman in your area, and they'll probably be able to tell you if it's THAT or something more serious, which I doubt. The reason why the washer moves a bit when at the end of the cycle is probably because the brake which causes the spin dry cycle to come to it's end, does so very fast, which displaces the centrifugal energy abruptly towards lateral motion. Not really dangerous either.
Sep 19, 2012 | Maytag Parts Washing Machines
MAKES A LOUD BANGING NOISE AT THE END OF SPIN CYCLES. WHEN IT IS SPINNING SLOWER, NO PROBLEM. IT IS NOT A PROBLEM OF BEING LEVEL.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 17, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
My LG Intellowasher M-1480FHD has started making a loud banging noise on the final spin. It also wouldn't end the spin cycle at the end of the 30min wash
the banging noise while in the spin cycle will more than likey be worn shock absorbers and will need replacing.
Aug 31, 2010 | Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Kenmore Model 925 75 110 washing machine makes loud noises when the spinning cycle ends (as it stops spinning). Any ideas? Ease of repair ?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There is also an excellent PDF document from Whirlpool describing how Direct Drive washers work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
We has the same basic problem with a Kenmore direct drive washer. At the end of the spin cycle we heard a loud noise as the brake stopped the drum from spinning.
Sometimes, what can happen is that the brake will grab the brake drum, like a brake on a car suddenly locking a wheel.
The brake is supposed to slow down and stop the drum without locking.
We were able to spray a small amount of silicone spray inside the brake drum, which allowed the shoes to more gently grab the drum.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Remove the cabinet and look at the drum directly above the silver colored clutch assembly.
Using an spray can of silicone spray, and a directional tube, spray a very small amount into the brake drum.
Sep 25, 2009 | Kenmore 22422 Top Load Washer
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
4,332 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
