Question about Vacuums
How to I replace the belt on a Bissell Cleanview?
  • cooks22 Jun 26, 2008
    The belt on bissell proheat powersteamer is broken, I have a new one, how do I replace it?
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=708100
Generic problem for all Vacuums
How to I replace the (by 2 users)
Posted by bobklein on Jun 26, 2008
Have the same problem? Click Here X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by cooks22, posted on Jun 26, 2008 The belt on Bissell ProHeat powersteamer is broken, I have a new one, how do I replace it? Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Most of the Bissell’s the belt is changed from the bottom or the top is removed and you service it from the top. There are usually screws, clips or levers to remove the bottom plate or top cover and once that is removed then the belt change. If the belt is a flat belt the recommended belt change is every 4 to 6 months and id it is a geared belt then you would change it once a year for the best cleaning. If you have questions, refer to the owner’s manual in the trouble shooting section, if you don’t have an owner’s manual then you can contact the Bissell Factory cust serv listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 26, 2008
The turbobrush for my cleanview helix 22c1 is not working
It's probably either just dirty, or the belt is broken. If it's dirty, you can just take the cover off (two Phillips head screws on the bottom) and clean everything off the brush.
If the belt is broken, you can tell by turning the large gear at the back of the brush -- if the brush turns when you spin the gear, the belt isn't broken -- then you'll need to replace it. You can buy a new belt online, or you can buy a replacement Turbo Brush directly from Bissell ($24.99).
Hope that helps!
Jan 10, 2011 | Bissell CleanView Helix 22C1 Bagged...
How do i change the belt on my bissell powertrak
Give this a try.
http://www.ehow.com/how_2320063_replace-drive-belt-bissell-cleanview.html
Sep 05, 2010 | Bissell 3594 CleanView PowerTrak Bagless...
New Bissell Cleanview Helix is aking a high
It most likely is a worn drive belt. Here is a link to the belt you need and the manual:
Bissell Cleanview Helix Belt and Manual
Nov 24, 2009 | Vacuums
Makes too much noise {high pitchs] like the motoris spinning the belt to fast.
That noise usually means that the belt is worn or stretched and its slipping on the motor shaft. Replacing the belt is easy to do and you can get the belts for this model here:
http://vacbelts.com/bissell-style-7910121416-belt.htm
Oct 18, 2009 | Bissell 3590 CleanView Bagless Upright...
Bissell cleanview vacuum poor suction
The next thing that you need to do is replace the belt. Even if it's not cracked or worn, many times it's too loose, and it won't turn to rotor efficiently.
Believe it or not, just replacing the belt may be all that you need to do!
Jul 07, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell roller question
You need to replace the brush roll, part # 2032013, I would also put a new belt on as well, 2031093, style 7 belt.
Most vacuum repair shops should have these or can get them for you.
Aug 27, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell Velocity Vacuum brushes stopped
The brush bearings wear out on these things. I know I replaced mine twice before buying new carpet. I've had it for 10 years,
You can order these parts on the Bissell website:
http://www.bissell.com/Products/p/CleanView+Brush/product.aspx
http://www.bissell.com/Products/ak/replacementparts/p/CVPT+II/product.aspx?%23=Detail#Detail
http://www.bissell.com/images/UserGuides/35934_804.pdf
Mar 29, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
220 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
