Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Disc tray wont eject or open I try to get my DVD player to eject but it won't open. The door flap comes down the DVD holder won't eject out?
  • cburtchett Jul 13, 2008
    I have the same problem .My Tray will not open , any help ???????
I have a sanyo vrc and dvd combo and I haven't been able to open the dvd slot except for 2 times in years. HELP, Katherine
Katherine, Sounds like the carriage is corroded, inside. Not a Field replacement item. That can happen when/if it's not used too much. Maybe you will consider replacing the whole unit? And that's a VCR/DVD combo, right? What's the model number?
Feb 11, 2008 | Televison & Video
DVD-VR375 Disc Tray Won't Open
The disc ejection mechanism may have failed.
Apr 13, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
LG v181 won't eject - it tries to load even when there is no disc and won't slide out the tray at all.
It's likely a belt that drives the tray has snapped or come off! If you take the top off you might well see it!
Dec 23, 2012 | LG V181 DVD Player/VCR
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
JVC Model DR-MV99 tray door keeps opening and closing when trying to insert a DVD disk
This problem was driving me crazy, until I found a solution.
This is what you need to do.
When the tray is open grab the flap door that goes up when the dvd goes in. Hold it down as you the DVD tray goes in. (Its spring loaded) This allows you to have direct access to the front of the tray even when the DVD goes all the way in. Hold the tray in with your finger by pushing in firmly on the far right corner of the DVD tray. The DVD tray will try and come out, continue to hold it in while pressing the eject button on the remote. If you are firmly pressing in on the right corner of the tray it should only take a few times of pressing eject when you see the Disk symbol on the screen and you will here the DVD start loading. When you know that it is starting to load release the front door flap. You can then use the DVD player as normal.
Unfortuntely you will need to do this each time a DVD is loaded.
Jan 24, 2011 | JVC Televison & Video
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
DVD tray won't open.
Opening a CD or DVD drive to retrieve a disc
  • Use Windows to open the drive door:
    1. Double-click the My Computer icon on the desktop (or click Start and My Computer in Microsoft Windows XP).
    2. Right-click the CD, CD-RW, or DVD drive , and then click Eject .
  • Restart the computer and press the EJECT button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD drive. Try shutting down or configuring any programs that write discs or monitor the CD drive.
  • If the door still will not open, do the following:
    1. Close all programs and shut down the computer.
    2. Unplug the PC from the power outlet and remove the battery.
    3. Locate the manual release hole in the front faceplate of the optical drive tray. This is a small hole under the door that is a little bigger than the diameter of a paper clip. The location of the manual eject hole will vary.
    4. Insert a straightened paperclip into the manual release hole until resistance is felt.
    5. Once the resistance is felt, keep pushing the paper clip until the drawer comes out about a quarter of an inch.
    6. Remove the paper clip and gently pull out the drawer until the disc is accessible.
    7. Remove the CD and turn on the computer.
May 21, 2009 | Daewoo DVG-3000N DVD Player
Dvd player wont open
on this unit for home dvd player, you might have to open the unit up to see inside and connect the power, then you turn on and hit the button eject and push down the dvd tray or holder down a little bit see it can be open. i have the same problem that what i did and it work.
Jul 02, 2008 | Sanyo Televison & Video
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
939 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
