Toshiba satellite A215-S5818 bios password
Turned it on the other day, and all of a sudden it wants a password as soon as I power it up. It won't let me into the bios or setup. We never had it set up to ask for a password before, Don't know why it's asking now, and can't get into the laptop at all. Please help TOSHIBA SATELLITE A215-S7437,
I WENT TO TURN ON THE LABTOP AND CAME ACCROSS A SCREEN THAT ASKED FOR PASSWORD? BIOS?
  • 1 more comment
  • Anonymous Jul 11, 2008
    just today had the same thing happen. I called Toshiba, and they said to update Bios on the Toshiba web site, haha, I said don't you understand my computer is useless without the password, so I gave up and made a call to the nearest (20miles) service center and its a free fix still under warranty. I guess this is a big problem with Toshiba. The last thing I am going to do is pretend I am a computer tech and tear apart a $1000.00 laptop. Take it to the pros, if they screw it up, you get a new one for free.
  • Would you believe it my Toshiba Satellite A215-S7437 just had the exact problem. I never went into the BIOS, but a password that was not there is now there. Can anyone explain how that happens? I am a little scared to try Mark's solution. Has anyone tried it and was successful? Please let me know. Thanks
  • Anonymous Apr 29, 2009
    the correct answer it the second soluition, remove ram bay door, find solder points marked by XXX, short and power up. wala unlocked!
This should be able to be solved by opening the Ram bay and shorting out two solder points. Usually marked with a "xxx". The notebook should be started with these solder points shorted. Once the pc is on, it should go through the normal process without asking for a bios password. Once the pc is restarted, the CMOS password should disappear.
Posted on Feb 05, 2009
  • matole343 Jun 11, 2011
    Your solution works perfect. God bless U and keeps your brain always in shape.
IT WORKS!!!! Solution #2 is the way to go. I soldered the 2 XXX points together and it started up like a charm. Thank you.
Posted on Jun 10, 2010
    Novelist:
  • 148 Answers
If in fact there has been a password entered in the bios start-up or boot of the computer and it was not there before and all of a sudden it popped up you got a virus in your bootlog! The only way to access this is to locate the cmos battery toshiba generally locates this under the keyboard. This battery like most that are installed are soldered in place and resemble a large hearing aid battery. Here is the trick,Unplug the ac adapter and remove the power pack battery before you start If you can get a ground strap and secure it so as to prevent static discharge do so. If you are skilled enough to unsolder it that is the best way just remove one lead and let it stand for five minutes to enable the internal capacitors to discharge. If that is not your cup of tea you can momentarilly short the battery for no longer than five seconds, It is very low voltage and I have never had a problem doing this.When you reconnect the battery replace the power pack battery first then the ac adapter. When you power up the cmos will re-establish itself and go to your settings to make sure you have no password. Then exit saving you settins to the cmos . In some cases you may have to flash the bios but this should br done by a tech as it could permenently damage it...Good luck, Be mucho blessed ...Mark
Posted on Jun 26, 2008
I see the one solder marked xxx. Where is the second one? Do you just short the one to ground?
Posted on Jul 06, 2010
I have a Satellite A215, but have been lucky enough to not have experienced this problem yet.
I checked out the Toshiba support website and found a support bulletin on this issue. Toshiba has a bios update for people to use who have not yet experienced this problem.
For those who are locked out of their computer due to faulty bios, they will repair the problem under warranty until December 31, 2010.
Incorrect power-on password prompt -- with older BIOS versions
Document ID:
98082632 Posted Date: 02/11/09 Last Updated: 02/24/09 Operating System: Category: BIOS Distribution: Public
Posted on Jun 12, 2010
I have a Toshiba A215-S7413 and the same problem has happened to me i.e. suddenly the BIOS password got set.
I tried all these suggestions i.e. shorting the two solder points under the RAM and as well as try to short the CMOS battery. But it still keeps asking me for a password. Even though shorting the CMOS battery (while the machine is powered off) claims that it reset the BIOS settings, it still asks for the BIOS password and won't accept anything. I am going crazy and have wasted a lot of time in this.
I think this is a scam by the Toshiba company. My laptop is pretty much a dead weight now. I am so frustrated.
Posted on Apr 16, 2010
  • stocknsurf Apr 16, 2010
How do you replace an inverter board on a Toshiba A215-S5818
have a look at this video it will show you how to open up the LCD screen and from there you can replace the inverter board
https://www.youtube.com/watch?v=zz9zdlktONM
Feb 28, 2015 | Toshiba Satellite A215-S5818 Notebook
I have a satellite A215 - s5818 It started with it just shutting down all of a sudden . reboot and it may work for a while and it would shut down again . Now I can hear it power up but no display on...
his is sound as though your power adapter is not charging your laptop battery and the battery is trying to preserve what power it has left to power up the screen as you demand but there is no voltage to do so.
1. you will need another power supply adapter from what you have describe here and or a battery replacement.
if you can possibly get an equivalent power adapter for your unit and connect it to see if you get power up then you need to replace the power adapter.
I hope this helps. Have a great day!
Oct 05, 2010 | Toshiba Satellite A215-S5818 Notebook
I cant bypass the bios password
i would phone up the toshiba helpline on : 0870 843 0333
Mar 31, 2010 | Toshiba Satellite A215-S5822 Laptop
My Toshiba A215-S5818 Shows up enter password
The problem can be due to incorrect power on password prompt. This problem is noticed with some older BIOS versions. The system is looking for a non-existing power-on password.
The only solution for this is to send the system back to Toshiba. They will repair this problem free of cost.
Mar 10, 2010 | Toshiba Satellite A215-S5822 Laptop
Need to know adout the fan
The fan should work off of the bios
Mar 13, 2009 | Toshiba Satellite A215-S5818 Notebook
A215 S5818 doesnt boot at all...
Hi there.
Remove the battery and try it on AC power only.
Post back with the results please.
Good luck and thanks for using Fixya!!!
Feb 19, 2009 | Toshiba Satellite A215-S5818 Notebook
Toshiba Satellite A215-S5818 boot then it goes off
hi
there I think you have picked up a virus which has secured your operating system.
even safe mode cannot be run it for u to retrieve your data.
give your machine a fresh installation. get and install a data recovery program and run fornated recovery for your data. if you have a recovery disk for your computer, you can use it for the reinstallation.
thanks
Nov 26, 2008 | Toshiba Satellite A215-S5818 Notebook
Reset
It will be on the main board of laptop. You need to open the base and keyboard of laptop. Careful
May 21, 2008 | Toshiba Satellite A215-S5822 Laptop
I think there is a power on password on it. Please reset it from motherboard. I Think u need to open it. and reset. Take Professionals help if you are not aware of technical details. Else this will damage Motherboard and you no longer you wil be able to use it. Please rate and ngive me feedback
Mar 22, 2008 | Toshiba Satellite A215-S5822 Laptop
Computers & Internet Logo
10,992 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
