Question about RCA D52W19 52" Rear Projection Television
Tv turning itself off
The tv will turn on for about a minute or two then it will shut itself off. The picture and sound are fine when it is on. When you hold down the power button it gives a flash code of one blink and then nine blinks. Any ideas?
  • 1 more comment
  • Rob Dawson Jun 26, 2008
    Just pressing the button does nothing.
    The model full model # is d52w19byx1
  • vdelisi Jul 04, 2008
    Press the power button once and the TV comes on for about 10 seconds then shuts off. The power button is not lit at all when off.
  • RCA Master
  • 8,617 Answers
Without holding the power button down, What does the power light do when you press power just once? Please respond to this same post so I will have your model number available.
Posted on Jun 26, 2008
  • Sonny Berry
    Sonny Berry Jun 26, 2008
    Sounds like its a problem with the signal board, as if it was power related the led would flash when just pressing the power button once.
WD-62526 shuts off
The power supply is failing. Your TV is able to start but the power supply can't continue operating and shuts down.
Dec 12, 2013 | Mitsubishi Televison & Video
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
52 in sony tv plasma i turn it on an it comes on
Sounds like the lamp is burning out, hopefully it's a replacable type.
Mar 29, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
RCA TV, model number 32V550T. No picture but sound is fine.
hiya
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
rik
Feb 24, 2009 | RCA 32V550T 32" TV
TV turned off itself
Can you still turn it on?
If so, does it stay on with sound?
If the sound is ok and the picture is blue (even when changing channels, inputs, etc.) the lamp may have gone out.
Can you see the TV menu when you press the menu button on the remote or TV?
Jan 07, 2009 | Sony KP-51HW40 51" Rear Projection...
T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Cause
Location
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
Detected
Symptoms
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
stopped.
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Dec 03, 2007 | Sony KV-36XBR400 36" TV
TV turns itself off after a few seconds, no picture at all
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Nov 11, 2007 | Sylvania SST4322 32" TV
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
