Question about Gateway Computers & Internet
I have an older Gateway pc with Bios version 4w4boxo.15a.0017.p12. I added a 512mb of RAM, and when I attempt to boot up I get an error message that says; Error Code 0232: Extended RAM failed at offset: 1B. What do I need to do to fix the situation ? Thanksin advance... Ed
    Novelist:
  • 148 Answers
I am trying to remember that computer but in most Gateway computers you have to have equal values of ram in the two ports and both must be occupied . I/e two 256 mb.Good luck... Be mucho blessed...Mark
Posted on Jun 26, 2008
NTLDR compressed on a Compaq Presario SR105CL cant enter bios to set to boot
Step 1:
Which operating system ?
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT.32 New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. b> Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer. If you are attempting to BOOT from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt. If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt. Press any key to boot from the CD
Mar 10, 2013 | Compaq Presario sr1055cl PC Desktop
Installed 1gig rdram computer wont turn on , only orange light... when i took out 512mb and put back the 256mb + 512mb(upgrade) it works.. but how do i install the other 512mb with out it not working......
Hi. It is recommended that you use a balanced memory total. Just like the wheels of the car. They all must be of the same capacity. But what you can try to swap the locations of where you put the cards in. If you still have problems then just use the 2 pieces of 512mb. Cheers!
Feb 13, 2011 | Gateway 700 X PC Desktop
My pc was working fine with 128 + 256 ram. few days ago it didnt boot.it was restarting automatically. then i removed 256 ram and it booted normally.means pc works normally with 128 ram but not with 256...
i guess u have 2 different RAM cards in the RAM slots....
the main issue is both dont work together...the primary reason is compatibility....or one of the RAM cards have worn out...
u must use exactly similar kind of RAMs in both slots....
i suggest u use one 512 MB if your motherboard supports....
RAM technology has advanced so mush that you wont get RAMs for old PCs (motherboards)....so u decide...
pls revert back...and kindly leave a feedback and rating for this solution...it will help me move to Guru" here from Expert at Fixya....
regards...
Sep 29, 2010 | Gigabyte GA-8I845GV Motherboard
Added 1Gb RAM DDR2 533 PC2 4300 CL5 but recognizes only 512Mb
the is a BIOS problem. you can still google search the BIOS updater. OR have a look on windows how much it is being detected.
Jan 27, 2010 | Foxconn P4M800P7MA-RS2 Motherboard
Added more ram but it's not working Compaq E500
what did you mean not working ?? didnt see the new Ram memory ?/ or didnt boot at all ....anyway ...when adding new ram memory ..first thing you do is to remove the Bios battery for to let bios on defaults and let it be able to read the new added unit ....second ...be sure the new added ram is compatible and in the same frequency ,then remove the battery like I said and in the last ...reinstall the operating system ....always look at the boot to see if the ram memory that is displayed is the same value with the one you know that actually is installed on the slots...it should work if this was just an option to make it faster ...and not a wild guess cause it use to have issues and didnt boot before...
Sep 10, 2009 | Compaq Armada E500 Notebook
Adding ram do I need BIOS update see detailed question
I don't think that this will work! I think 512 is the maximum for it. May be it'll just improve speed a little but it's always risky to update BIOS on older PCs. And this 512 sticks will cost you a lot. I think you better think to buy a new PC. Good Luck!
Apr 17, 2009 | Compaq Presario 7588 PC Desktop
Getting POST Error "Beep" message (3 Long); on a Gateway 500SE Desk Top with an Intel (Nimitz 4000792) P4 1.8Ghz CPU . Can't run machine to ascertain BIOS; thus to determine that manufacture's unique POST...
Dear Frind i think your second ram 512MB Have PC400 Buss Speed, I think also *********** board doesn't support PC400 buss Ram, Please try Ram with PC266 Or PC333 Buss speed. Best Regards sumon
Mar 20, 2009 | Computers & Internet
BIOS "Phlash" Error
pls run an earlier version of windows xp i.e. sp1 as earlier processor and motherboard may run xp sp 3 but it will not provide 100% compatibility
Jun 23, 2008 | E-Machines eMachines Desktop PC
Memory issues acer t180 ud360a, no boot up with all (4) ram slots filled...
i had same problem with mine, i have the acer aspire ast180-ud360a, dont put the same memory next to each other, u have to stagger it, so it looks like
------------> [1gb] [512mb] [1gb] [512mb] <--- correct setup
and not like
------------> [1gb][1gb][512mb][512mb] <--- incorrect setup
Nov 25, 2007 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
102 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
