Question about Toshiba Computers & Internet
Windows will not start, even in Safe Mode. Repair wizard said I have a corrupt registry. Can I recover without losing my data?
  • bgale2 Jun 26, 2008
    I am running Vista
  • William Fyler May 11, 2010
    Hi bgale2
    Please let me know what version windows are you using so I can help anwser this for you.
    Thank You
    Bill
    Problem Solver:
  • 10 Answers
Hello Begale2
Thanks for getting back with information:
I have put together steps on what can be done now one is for system restore and the other pc restore in vista. System restore is the most common one in Vista used by popular demand it seems at times. I hope you have the Vista installation DVD because you will need this to do it.
First you will want to get into you bios and change your boot order so the DVD starts first. Then once the DVD starts access WinRE from the Windows Vista installation DVD is easy. Once it boots up you will be asked for your information.
Make sure that your information is correct and click next. WARNING Whatever you do, do not click the Install Now link or you will end up re-installing Vista. You will want to, click the Repair Your Computer link found in the lower left corner of the screen.
Then you will see a screen asking you to select the OS installation that you want to repair. Your screen may be a blank operating system list if the OS resides on a disk array that Windows does not have a built-in driver for. But, you are given the chance to provide WinRE with a device driver before continuing.
So, if your target operating system is not listed, don't give up hope nothing is lost. Even if the operating systems are not listed, you can still click next and gain access to WinRE.
When you click Next, Windows takes you to the main WinRE screen. There, WinRE gives you a lot more options than the Windows Recovery Console does. You still have the option of accessing a Command Prompt window, you will notice a majority of the restrictions that were present in the Windows Recovery Console have been removed.
Only the Command Prompt environment existed in the Windows Recovery Console. The Command Prompt is one of several options that are available in WinRE.
How to use Startup Repair
In WinRE, it sounds like you are going to be using the Startup Repair option. This option is that if Windows won't boot properly, you can boot WinRE and then choose Startup Repair to perform a series of tests. Startup Repair will then attempt to automatically correct the boot problem.
How to use System Restore
Windows is designed to create system restore points that allow you to roll back the configuration to a previous state should something go wrong? However, some configuration changes can result in a catastrophic failure that leaves a system unbootable. The System Restore option allows you to roll back the operating system's configuration to a prior state, even if the system is unbootable.
When using WinRE System Restore option, remember this: It has one shortcoming. When you perform a system restore through Windows, you have the option of undoing the restore if it does not accomplish what you had in mind. However, when you perform a system restore through WinRE, you are performing an offline system restore, and undoing it is not an option.
Windows Complete PC Restore
Occasionally, you may run into a problem with Windows Vista that you simply cannot fix. In that situation, use the Windows Complete PC Restore option to restore a backup. .Using the Windows Complete PC Restore feature, though, you can restore a backup without having to install Windows first.
I hope this helps and gets your system back up there running and if I can be of any further help let me know als let me now how you make out with it.
Bill
Posted on Jun 27, 2008
    Problem Solver:
  • 6 Answers
YOU CAN DO one thing that when you install any windows and format earlier windows and and do not format your data
Posted on Jun 26, 2008
How to repair corrupt emails in MS Outlook 2010 ?
Hi
You can do this using inbox repair tool or scanpst.exe provided by Microsoft free of cost. If this tool is unable to repair PST file then you can use any third party tool like SysTools Outlook PST Repair tool or PCVITA PST Repair tool.
Aug 12, 2014 | Microsoft Outlook 2010 - Windows
\windows\system32\winload.exe missing or corrupt 0xc000000f
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
Jan 16, 2013 | Acer Aspire 5610-4648 Notebook
How can i recover a corrupted word document (.docx) file?
If you cannot find any of your Word, Excel, PPT or other Office files on your Mac, you might have met file loss situation. But don't lose your hope. Here comes an amazing solutions for Mac deleted Recovery to help.uFlysoft Mac Data Recovery Tool can help you to recover the lost files on your Mac, It is a professional Mac data recovery software which is powerful enough to retrieve unsaved, corrupted and deleted Word files easily.
Nov 03, 2010 | Microsoft Computers & Internet
Did a full recovery on windows xp home edition.
Freeware for data recovery Best freeware for data recoveryWhen computer data loss happens, like deletion, careless format, it actually means losing data. Data recovery is generally means a consumption of time and money. Ever through there are lots of freeware for data recovery, most of the freeware can only recover deleted files. These freeware for data recovery are can do nothing when the data is lost due to format, partition loss, system crash.
Luckily, EASEUS launched the first full-featured freeware for data recovery: EASEUS Data Recovery Wizard Free Edition. This freeware for data recovery is designed to recover data from all kinds of data loss problems. This data recovery freeware is so potent that most commercial data recovery software can't do more than it. It is able to recover data from lost or deleted partitions and even recover your files after partitioning or crashed hard drives. The freeware works well with FAT12, FAT16, FAT32, NTFS/NTFS5 and EXT2/EXT3 file system.
How to use freeware for data recoverymain.gifThis freeware for data recovery is very easy to use. A wizard interface will guide you through the whole process of data recovery. There are three recovery modules on the main window of the freeware.
Deleted File Recovery: aims to recover deleted files even if emptied from Recycle Bin.
Complete Recovery: aims to recover lost files after format, or from RAW partition.
Partition Recovery: aims to recover lost file from lost/deleting/missing partitions or system crashes.
Takes complete recovery for example:
1. Click the "Complete Recovery" button on the main window of the data recovery freeware.
2. Choose the partition that was formatted and click "NEXT" to start searching on this partition.
free-complete-recovery-1.gif3. Press "NEXT" button. The freeware for data recovery will launch the "Building directory" procedure to searching the files. You will see file/folder tree very soon.
free-complete-recovery-5.gif4. After the lost files are found on this freeware for data recovery, you can preview it to check the file quality. Select the files you want recover to save them to a safe place.
free-complete-recovery-6.gif5. The lost files are back to your hard disk now.
The freeware for data recovery is the easiest and most powerful freeware for data recovery. Why not have a try, you have nothing to lose.
Check it out
Jul 28, 2010 | HP Compaq Presario SR1303wm PC Desktop
I have a Win XP desktop that has a corrupt system file
If you know what file it is, you can try booting with a recovery disk - you can download the UBCD boot ISO for example - and copy it back.
Or, if you can enter at least Safe Mode, you can try running the SFC /SCANNOW command from the prompt.
Finally, ordinarily you can run a XP install on top of an existing installation without losing data. This is a last resort, though; some user personalization and info is bound to be lost.
Apr 16, 2010 | Microsoft Windows XP Home Edition
My toshiba L500 wont boot up when i turn it on it starts to load files then stops and tries to repair the problem but it does not
There are so many reasons boot up; i.e if system files corrupted by virus or hard disk index tables corruption or hdd partions corruption.
So as a initial trouble shooting try to do following things to resolve problem.
Option 1:
1. Power ON your computer and Press F8 key to have Windows boot menu option
2. Select "Safe Mode with Command Prompt" and Press Enter
3. When command prompt loaded then type follwing command and press enter
chkdsk /r c:
(If this command is not working in "safe mode with command prompt" then start computer with Bootable CD and Press "R" key when first time asked. It will open recovery console and type this "chkdsk /r "command again to repair disk.)
This command will scan your hdd and repair disk errors.
Option 2 :
To repair your windows without losing your data.
Start Computer with bootable CD
Press R when it is asked to press.
It will repair windows.
Note : Please read Status Bar and screen messages /nstructions carfully (while Booting computer thru Bootable CD)
Mar 28, 2010 | Toshiba Satellite L505ES5015 NoteBook
\windows\system32\config\system missing or corrupt
You can do a refresh of your Windows OS, if you have Windows XP. You need to boot to your XP CD and do a repair. This will only restore the Windows OS files and you will not lose your personal data.
This should help. please rate my response.
Feb 17, 2009 | Gateway MX6440 Notebook
Acer aspire one not booting
your laptop has been turned off without shutting down. all your laptops registries are probably messed up. the easiest way to do is to reformat your computer or restore it to factory settings. unless you have some important files that you cant afford to lose.
Feb 07, 2009 | Acer Aspire One A150-1006 Notebook
Cannot use windows problem number c0000218
That Blue Screen of Death you cite is a registry hive file error.
Since you state you don't have any HP discs, you have only two things you can do.
(a) This is the less involved way to go and preferable because it's destructive. Attempt to start your PC in Safe Mode. That is, when you reboot and see the HP logo, start hitting the F8 key to bring up the Windows Startup menu. Select Safe Mode. When you get to the Login screen, login with the Administrator account, and I hope you remember the Administrator password when you do this if you set one up. Assuming you make it to the desktop, go to Start --> Programs --> Accessories --> System Tools --> System Restore. Run the wizard to revert your system back to a time before the problem started. Don't be afraid to go back farther than you need to because your data files will not be affected. The only things that will be affected are program installations, registry changes and driver changes. Let the wizard do it's thing and follow the prompts and you should be fine. If this doesn't work...
(b) For this one, you're going to need to move files. For that, you'll need a Windows CD. If you have an extra one around so you can boot to the Recovery Console, you'll be fine. Assuming you find one, then just follow the steps on this page --> Recovering HIVE Files. That will get Windows back to functional status, but you will have to reinstall your programs because even though they're there, you're recovering to a pristine version of that registry file that doesn't include any non-Windows software, so Windows can't use it.
Good luck, and post back with how it goes.
Jan 04, 2009 | HP Compaq nc6000 Notebook
Computers & Internet Logo
127 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
