Question about Kenmore 54701 Dehumidifier
Will not take moisture out of room.
Unit runs and acts like compressor kicks on but no water is being expelled though hose.
  • 6 more comments
  • RNPCHGO Jul 30, 2008
    MY KENMORE DEHUMIDIFIER MODEL 54701 RUNS CONSTANTLY BUT NOT A DROP OF WATER IS IN THE BUCKET AND THE BASEMENT IS VERY DAMP. IT'S 4 YRS OLD SO DO I HAUL IT TO THE DUMP OR IS THERE HOPE ?
  • brad 08 Aug 03, 2008
    unit runs thru cycle but there is never any water in bucket and filter is clean
  • Anonymous Aug 05, 2008
    I have the same problem. Dehumidifier is 4 years old. Runs, but it is not dehumidifying the air. If it is the refrigerant system, it is under warranty for 5 years. Unfortunately, you have to pay Sears $65 to diagnose the problem first!! Is it really worth fixing?
  • Andrea0808 Aug 20, 2008
    I have the same problem ... the unit runs but does not pull any moisture out of the room. I have cleaned the filter and am going to try cleaning the coils ... but there is a vent in front of the coils. I guess I'll try to remove that also.
  • HJ-KS Sep 06, 2008
    The unit is 3 years old, had warranty repair before 1 year old. It was noisy after that and probably didn't work properly even then. I never had the time/energy to load it back up to take to Sears Repair Center. My basement is damp. Help!
  • jellyby Mar 14, 2009
    I took it back to Sears twice for high noise and vibration and they decided to replace rather than fix it. The third one has the same problem PLUS it doesn't remove much moisture from the basement. I installed a humidistat and originally it could reduce humidity to 35%. Now it doesn't go below 55%.
  • diamondpony7 Apr 20, 2009
    my dehumidifier runs and runs and no water is taken out of the air and the bucket is dry. It is only 3 years old.
    where is the filter? I cleaned the coil and this made no difference.
    any suggestions
  • Anonymous May 11, 2009
    My husband found one set of the coils are rusty on our dehumidifier. The filter is clean. The unit comes on but either does not remove humidity from the room or the coils freeze up.
    Novelist:
  • 121 Answers
If your dehumidifier has a filter make sure you clean it with warm water and mild detergent. Manufacturers recommend that you do this every 2 weeks. The main issue is most likely your coil is dirty. Usually you can remove the front cover and brush the coils off wth a small brush. If your dehumidifier didnt come with one you an clean it with a toothbrush. Good luck and let me know how it goes. Thanks - Tech101
Posted on Jun 26, 2008
  • Justin Jul 11, 2008
    Have you had any luck with the solution that I gave you? If not please let me know. If you did find it helpful I ask you to please reconsider the thanks for trying rating. Thanks - Tech101
MY WHIRLPOOL DEHUMIDIFIER MODEL AD50GEUSW IS NOT PRODUCING WATER ANYMORE
This is like a mini refrigerator. Even though you can hear the compressor operating, there may not be enough Freon to cause the moisture to condense.
Sep 05, 2012 | Dehumidifiers
Tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 | Dehumidifiers
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Model BHD 651-C Serial 611TA000375 Problem: Unit comes on, fan operates but compressor is not kicking in. While the fan operates it is not pulling any moisture out of the air. Controls indicate that...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 09, 2011 | Comfort-Aire BHD-651 Dehumidifier
Need a repair shop in the baltimore area to look at my dehumidifier runs but wont pull water
It's cold outside. If the temperature is too low, the cold coils will just frost up and you won't get much water 'pulled'.
Check to see if the cold coils actually are getting cold when the unit is running and the control is set to cause the compressor to work-not just the fan.
If the coils are cold and full of frost or ice, the room is too cold for the dehumidifier to work. You'll have to raise the temperature of the room or wait for warmer weather.
If the coils never get cold, the compressor might be bad or the unit might have lost its freon.
I wonder, though, if it's just too cool and dry right now for a dehumidifier to be pulling more moisture out of the air.
Hope this helps!
Jan 01, 2011 | Haier Dehumidifiers
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Unit runs but will not puu moisture from air....possibly the compressor has kicked off due to control problems. Model HD456E Haier 45 pint dehumidifier
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 02, 2010 | Haier HD656E Dehumidifier
My Danby DDR586R dehumidifier shouts hot air, it was shooting cool air before, what can the problem be?
Here is Danby's official response to a similar question on their FAQ page for Dehumidifiers:
https://www.danby.com/faqs.php?cat=12
Q) When the dehumidifier is operating, is it normal for the expelled air to be quite warm? We find that the dehumidifier is warming up the room noticeably (a finished basement).
A) The warm air that is being expelled from your dehumidifier is normal. When the unit is dehumidifying the compressor is working which causes the compressor to become quite hot. In order to avoid having the compressor overheat, air is drawn by the compressor at a rapid rate and the heat is then transferred to the air which must be expelled from the unit. The warm air will stop shortly after the unit has reached the desired humidity. This warm air should not change your room temperature by more than a degree or two.
May 07, 2009 | Dehumidifiers
The compressor does not seem to start or kick in.
need help to set date/month/year/ and time on my polaroid i830 digital camera
Apr 05, 2009 | Haier HDN455 45 Pint Dehumidifier...
Kenmore 54701 Dehumidifier Logo
746 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
