Problem for TV Receivers and DVRs
Generic problem for all TV Receivers and DVRs
TV has no sound all of a sudden
TV has no sound.Can not get sound and have used two remotes so remote not likely problem.Picture perfect
Comments:
Jun 30, 2008
- Answer to questions:
TV not on mute or SAP.
Shut it off for 48 h no change problem still there.
Happens on all inputs.
mavasu
mavasu@comcast.net
Solution #1
posted on Jun 26, 2008
Rank: Guru
Rating: 89%, 454 votes
what kind of tv is having the problem and where is the sound source coming from? Does this happen on all inputs such as cable, dvd player, etc?
It's not muted or on SAP correct? Try resetting it by unplugging it, depending on the type of the tv, this may take up to 8 hours to fully discharge and reset it. Please answer my questions so I can further provide information to help you fix this
Comments:
Jul 01, 2008
- basically your audio circuitry has failed then, and I wouldn't
recommend replacing it unless you really want to or depending on the
size of the tv for sure.
Getting a new tv is better worth the money
Solution #2
posted on Jun 30, 2008
Rank: Wiz
Rating: 76%, 199 votes
IC901 (TDA4935) blown due to excessive supply voltage, capacitors C619, C623, C810, C600, C601, C859 defective. Also verify R822.
if u hve a proper technical experience .dry solder ur board n check the above ics and capacitors.replace the ic if faulty or replace if any capacitors r bulged.otherwise get some repairman to repair ur board.it will cost negligible.nothing to worry.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Solution #3
Rank: Guru
Rating: 86%, 232 votes
may i know model no.
Comments:
Jun 30, 2008
- What it sounds like is wiring inside to the speakers got disconnected. Does the TV have a jack for headphones or external speakers? If so, then I would connect something to see if you get sound.
If you do, then its defintiely just the speakers within the TV. This would probably not be an expensive repair, but you should be able to get estimates from a repair shop. If ther is an external jack that works, you could just attach a set of speakers to it.Jun 30, 2008
- hope this works
Thanks for using Fixya...plz do keep us updated
Popular Solutions for TV Receivers and DVRs
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
1 Solution
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video...
1 Solution
Questions and Unsolved Problems for TV Receivers and DVRs
I need to buy a good quality TV receiver (on air telecasted TV channels) How does this product...
(More)
I need to buy a good quality TV receiver (on air telecasted TV channels) How does this product woreks? need a powerful Tv receiver to buy.
thankx
Hitachi digital recorder not responding says AUX on front tried turning on and off
I have 3 Philips freeview boxes (DTR 220) All have the same fault; Rescan & I have all...
(More)
I have 3 Philips freeview boxes (DTR 220) All have the same fault; Rescan & I have all channels, turn box off or if left overnight then most channels disappear, rescan & back to square one, seems they will find channnels ok but not store them, other TV with built in freeview is fine. Any ideas.
I have a newly installed Verizon Converter Box that when you shut off with Remote it clicks on and...
(More)
I have a newly installed Verizon Converter Box that when you shut off with Remote it clicks on and off. It's in my bedroom and the clicking kept me awake much of the night.
