Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have an old Sony hlv-660hf VCR; worked perfectly for my recording needs until I hooked it up to my SHARP aquos LC-32D62U 1080p HDTV. The image on playback started flicking in a very regular fashion: 2 second image, 2 second black screen; 2 second image, 2 second black screen, etc... I tried everything with the connections, even got a NEW vcr, hooked it up, same problem even though i tried different hook-ups, ie. s-video, regular, etc.. It leads me to think the problem is with the TV or connections; fact that it is 1080p? Am totally slumped, can anyone help me?? I have this same flickering problem with the VCR connect to Sharp AQUOS LC37D62U. have tried several VCRs - several cables - same problem.
Called service - suggested I keep trying different VCRs - not practical
you do not have my exact model in you list to choose from
  • Anonymous Jul 16, 2008
    Had the same problem with the screen going black every couple of seconds while playing a vhs tape. Tried the solution posted below and it fixed the problem. Thanks!
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Posted on Jul 09, 2008
Sharp aquos lenovo sl410 hdmi cable
I would look for a newer driver from lenovo. Has 8.1 got a fix?
Jan 19, 2014 | Lenovo ThinkPad SL Series SL410 (2842F7U)...
Sharp AQUOS 52" 1080p 120Hz Flat-Panel LCD HDTV
Press the menu button and scroll over to the setup sub category. Scroll down to reset and press enter. Select yes and then enter. Select yes again and press enter. The television will turn itself off and then back on.
If that basic reset doesn't work call 877-332-7867 to be walked through the no sound troubleshooting up to an INIT. I cannot put the steps for an INIT into print because any wrong move could erase everything from your television.
Dec 26, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Hooking up pc through hdmi - red flickering image
The format from the PC needs to be an HDTV format: 480i, 480p, 720p, 1080i or 1080p. Other formats will generally not work. You may need to get the latest drivers from your video card manufactures website to correct the problem. I hope this was helpful, best wishes.
Apr 18, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Dec 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Flicker
I have the same problem when going to dark scenes from a bright scene or during channel changes. Sharp sent a tech under warranty and he installed new software to no avail. He called sharp tech support and they suggested turning on opc. The TV works fine but you must adjust sharpness and contrast to achieve an acceptable picture. I paid $868.00 for the set a Sam's club and will buy an extended warranty. I will not buy another sharp. My 40" sony works perfectly.
Oct 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Aquos Screen Image Too Big.
I had the same problem, but it looked like my son pressed the view mode button on the remote. I set it back to Dot by Dot and it looks perfect again. Try it out.
Sep 13, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Well I do not know either machine but suspect if the video is old either your video's output is too rough for the TV because:-
It has some age related problem of wear.
The output signal is not quite correct in quality.
There may be a security signal applied on its recording material.
These are some of the issues, videos are very sloppy (by todays standard) but could get away with it with analogue TV's because of wider design variables inherent in that system.
Modern TV,s are less hardware more software driven and as such are critical about errors going to a blank screen as a way of escape an issue they can't resolve (mummy mummy!).
The video may need checking for mechanical or electronic issues, a favourite being power supplies which can generate noise from defective components that disturbe other equipment, or mechanical alignment which changes through wear and time.
You could try conversion to hdmi signal though cheap converters are limited in their method of doing this but might show you if it would work.
Cheap versions are about £10 but have no level controls (contrast, brightness or colour to trim for best picture)
Hope this helps............
Apr 27, 2017 | Televison & Video
Call of duty 4 1080p
First off, Sony doesn't make Aquos they make Brava. Sharp makes Aquos. Secondly, I am unable to uncheck 720p how do I do  this?
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
1,152 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
