Question about Kenwood VR-505 Receiver
VR 505 left channel not functioning
I tried everything and fear I've got a soundboard problem. The left channel does not put any sound out. What can I do?
    President:
  • 624 Answers
Does this problem occur when you use all of the different sources of the receiver, or does it only happen when you use just the CD input or just the DVD input or just the Tuner input?
If it happens on every different source, you have eliminated those sources as your problem and the RCA cables of those sources.
If it only happens on , lets say for example, the CD input, then you most likely have a problem with that CD player or RCA cable. Not always, but most of the time. It could still be a broken solder connection or something else in the receiver.
If you have tried using another known good speaker on that channel and also used known good speaker wires, and that channel coming from the receiver is still not putting any sound out, you do have a problem in the receiver.
The problem you have in the receiver could be many different things causing this same problem.
Here is a list of some of those possibilities, every single one of these things can cause the exact problem you are having but finding out which one requires some good electronic troubleshooting skills:
1. A bad speaker relay.
2. A shorted muting transistor.
3. A broken solder connection.
4. A bad amplifier IC
5. A bad switching IC
6. A shorted capacitor in one of several different circuits.
7. A defective IC on the digital board.
The list could go on for a while.
I hope that you find it is a bad speaker or speaker wire, but without putting it on a test bench and troubleshooting it, there is just no way to say for sure what is causing it.
I hope you found this information helpful, and if so a good rating would be a great way to say thanks. Just so you know, a "thanks for trying" rating actually is a bad rating for the experts here on FixYa!
If you would like any more help, just ask. If you have any other car and home audio questions, just click the "Ask me" icon below my picture if you would like me to answer your question.
I have been repairing car and home audio equipment for over 17 years.
Dave
Posted on Jun 26, 2008
How to return sound to reciever
All devices must support ARC. Audio Return Channel. Tv, Hdmi cable & receiver
May 13, 2014 | Kenwood VR-505 Receiver
I can't get my rear left speaker to work for my LG LHT854
you bought it new ... every new prodycts should come with warranty therefore best advice take it down to where ever you bought it from
May 30, 2017 | LG LHT854 Theater System
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
How can i connect my kenwood vr-505 to my t.v only
I assume you mean you want TV-related sound to play through the Kenwood.
It's in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-505-Receivers-manual/id/480ag214/t/2/
I personally would recommend minimum TV involvement in sound and minimum receiver involvement in video, but that's just me.
You might want to ponder why you would need audio from a TV in the first place if it originates elsewhere like a Cable Box. The fewer hops and interconnects a given signal takes on the way from the source to your ears, the better (and cheaper, too, as optical or HDMI cable is expensive). You COULD skip the TV entirely. Many don't even HAVE audio (monitors, for example). The receiver only NEEDS a basic composite video output to the TV so you can use the TV for setup and control. You COULD run vanilla stereo audio to the TV from the Cable Box for watching Oprah.
I run all of my best DIGITAL audio directly from the sources to my VSX and the best DIGITAL video directly from the sources to the TV.
Mar 25, 2011 | Kenwood VR-505 Receiver
I have a kenwood sorround sound and the remote will not work. The remote unit is RC-R0511.
I had the same issue on my VR-505 and here is how I fixed it. I found the fix on a different site and kudos to Plazman30 for posting it!
[Link: mysite.verizon.net]
J
Jan 14, 2010 | Kenwood VR-505 Receiver
Hello I am trying to hook up a dvd player to my kenwood vr 505 that has been in storage for a while. How do you hook up a HD tv and dvd. Does it go out from the receiver to the tv, and does the dvd go...
If you are using HDMI cables for HD then you will need to connect this from your dvd player to you tv. Then connect your dvd player to you amp using either fiberoptic cable or co-axil (orange) this will transfer your dolby digital signal. Then connect other stuff like video / freeview etc to the yellow red and white on amp, you may need a scart to phono cable. Then connect monitor out from you amp to the yellow on your tv .This way when you select the source on the amp the picture will change also. If you search the web for vr-505 manual there are some sites offering it.
Nov 27, 2009 | Kenwood VR-505 Receiver
Yeah...the left channel not working...
If you know how to check electronic components, have good soldering skills, and have the proper equipment then disassembling and checking it out would be the right thing to do.
But if you have no experience with this kind of stuff you really should take it to a service center and let a professional look at it. I have seen on many occasions when people who disassemble their equipment and attempt to repair it, but have no experience at this sort of thing end up causing more problems than they started with.
It is also dangerous, you can be shocked by the electricity or cause a fire. And if you do no understand the terms it would be very difficult for you to understand what to look at.
Your friend who said it was the soundboard is wrong, there is no board in those Kenwood's called a "soundboard", so I would not be so quick to listen to him about opening it up.
Jun 26, 2008 | Kenwood VR-505 Receiver
Kenwood VR 505 low sound in center channel
if the cables are ok and the speaker are ok also beside good setting you will have a problem of the output stage in your receiver.
May 06, 2008 | Kenwood VR-505 Receiver
Kenwood VR-505 Receiver Logo
91 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
