Hard drive failing?
Hey, I think my hard drive may be going bad.
It takes a very long time to load xp and vista and freezes sometimes. When it freezes the HD Led comes on.
  • 13,433 Answers
You may have alot of problems installed or your hard drive needs to be defragmented.
yes it also may be failing, but before replaceing it either clean up your pc also defrag the hard drive.
how to defrag
http://support.microsoft.com/kb/314848
if that doesn't help try reinstalling windows and starting from a clean plate.
Posted on Jun 26, 2008
Dell inspiron 1521 error code 2000-0146.. computer keeps freezing before it even loads up the window....
Hi eodnd119,
That's not a good error code. That is telling you your hard drive is bad.
You likely have a drive where sectors are going bad - sometimes they may be readable, sometimes not. But it's just a matter of time before the drive fails completely.
Replace the hard drive.
Good Luck,
Mark
Dec 08, 2009 | Dell Computers & Internet
Windows xp home will freeze on the compaq logo when hd 640gb
leave the drive disconnected until you have booted up.
You could change the BIOS to tell it not to look for external boot devices to overcome this also.
All it is, is that the computer can see files on the drive that it thinks may be an operating system and it is trying to boot from that drive until it fails and then loads windows normally.
Sep 07, 2009 | Western Digital My Book Essential Edition...
Sata drive is not recognized by os during new install
When installing XP or Vista you get the option to load third party drivers for unknown devices. I think it's F6 just after the start of any version of Windows, once you press this you will have to supply the drivers for the Windows installation. This will make Windows recognise the hdd from then on.
Aug 18, 2009 | Gateway MT6821 Notebook
Laptop not booting up after XP install
Can you press f10 to get to the HP recovery screens?
May 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Laptop blue screens when trying to reinstall vista
The problem might be with the bad sectors on a hard drive. You should run Scan Disk on a partition where you were trying to install Windows Vista.
Jan 16, 2009 | Dell InspironTM 1501 Notebook
System Crash or Freeze
XP home edition should be very stable when install properly.. I suggest you scan for PC invalid registry.. below link might be able to help on this issue.
http://etech.maiila.com/repair-kernel-32-errors-and-fix-dll-file-error-messages
Good Luck!
Nov 05, 2008 | Microsoft Windows XP Home Edition
Toshiba satellite screen blank
This could be that the hard drive has failed, and could also be the reason for the initial crash. Run a drive test in the bios or set up. If the test fails in any area then the hard drive is bad and will need replaced. If it passes, then reformat the drive and reinstall XP.
Jul 29, 2008 | Toshiba Satellite A100-S8111TD Notebook
Hey there, I have an Acer 5570Z that was running MS Vista from new. Well like many others i know i also am not happy with it. So i removed the HD, Removed any recoverable files etc. I then formated the HD...
hi,
are you familiar with the hard / cd rom drive dip switch jumpers? sometimes you have to change those around a few times for windows to submit, theyre the tiny black little pieces of plastic things next to the ribbon cable or power cables on the back of the drives, they pull straight out with needle nose or tweezers. if you look on the drives you will see a diagram for them, the hard drive usually is master , cd drives slaves, and cable select mode I think that setting means that you can then change the drive config via bios, but not 100% sure. Maybe try plugging two hard drives in and one master one slave, like that to unravel your problem. also Im hearing in order to go back to xp you have to do it microsofts way exactly via internet or something.
good luck!
J
Jul 12, 2008 | Computers & Internet
Hard Drive Failing?
It may be a virus or spyware. You can go HERE and run Trend Micro's Housecall on your PC. It's free.
You should also perform regular system cleanups and defrags on your pc.
Jun 25, 2008 | Computers & Internet
Video Card Problems
You need to run the recovery and allow Windows Vista to rule the roost. If you do not want to do that then you need to get a different hard drive,(preferrably a new one) And load XP on to it. Your laptop is designed to run Vista and the drive is coded to do so. After so many updates on XP it will pick up on your recovery partition because of SP3 update. No way around it unless you switch drives. I don't think you have permissions to delete the partition with Recovery on it. Get a different hard drive.
Jun 16, 2008 | Acer Aspire 5315 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
