Question about RCA Televison & Video
Replacing a rca hdtv tuner broken off - RCA Televison & Video
  • RCA Master
  • 8,617 Answers
Whats the model number of your RCA, and what are you needing help with/ Locating a replacement tuner ? Please respond to this post with your model number and what youre needing help with and I will assist you.
Posted on Jun 26, 2008
I have an RCA HDTV 52" Rear Projection tv.. do
No they do not have digital tuners inside them. They are meant to be monitors to converter boxes, cable boxes, and satellite television receivers.
Jul 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I just need to replace tuner on R.C.A. model D52W15 part # 264658
you can get replacement tuners at the following link. Call or leave a email with what youre needing.
http://servicemanuals.vstore.ca/
Jun 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The piece were the cable is connected to is broken
Must replace the tuner call union electronics they probably have it
Jan 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Patgirl
The part is called and "F" connector. It can be purchased but it also muist be soldered in place. This is not a trivial task. The F connector is part of the tuner. For a set of this size, it may be easier to replace the tuner rather than fool around with a repair attempt. Depending upon how it was broken, the PC board inside the tuner may be broken as well requiring tuner replacement anyway.
Dan
Nov 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rca d52wi5 tv tuner replacement
i have noticed that the new tuners are missing a few pins. i believe that it will work. what is the exact make and model of the set there is a tiny printing of the model above the model # i has d52w15...yx....something. you need this to cross reference the tuner. let me know and i will cross ref it
Jun 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help me
If you are decent with soldering iron you can repair it yourself. Remove the back, and remove the signal board from the unit. Unsolder the Tuner from the board( If I've lost you already, call a TV shop for repair) Remove the shields on the tuner and inspect for damage to the tuner itself. If the board is in good shape, replace the RF connector with RCA # 215543. you'l have to unsolder the old ends connector ( the wire thats still there broken ) from the board, then attach the new end, and solder to the board. Then using high heat, solder the Connector to the tuner housing. Replace tuner on board, hook everything back up, and you should be in business.
Jun 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cable connector broken
You can buy replacement antenna jacks for this. What you have to do is remove the tuner and it's shields, then unsolder the little tab off the board of the tuner which is what remains when they break off. Then you can resolder the new jack in place and the center pin back to the board of the tuner.
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
RF Tuner
the tuner for this unit is a rca 264658 componet is nh101
Dec 10, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Chassis blowup
Are you talking about your IF connector on tuner?you have to unsolder tuner then carefully open to reattach IF connector,if tuner is cracked then replace tuner.also you can go to www.repair world for more help.I seen where replacement broad wasnt alot to replace.
Jun 27, 2007 | RCA HD52W59 HDTV Projection Television
Broken cable connector
the easies and cheapest way is to use the audio video input. pulg the cable into your vcr & use the vcr to change channel. the other way is to replace the tuner, typically tuners sell for around $75.00 to $100.00.
Oct 29, 2006 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
62 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
