Question about Dell E193FPC 19" TFT LCD Flat Panel Monitor
Dell E193FPC connected dell monitor to XP cpu...monitor powers up and shows a display for just a few seconds and then goes blank.... if you turn the power off and then on again, it does the same thing....help!
  • FFXIMoogle Dec 22, 2008
    I have the same type of problem. My tower is just fine, tried out a monitor that works just fine ( stuck using that one now) I wanted my 19" back so I can give back this monitor. It does the self-test without any issues, but when I try to start the computer it goes blank andany buttons on the monitor pushed says its in safe mode push any key or move the mouse. Yet nothng changes.
  • RC Nut Apr 01, 2009
    I have a simillar problem with my E193FPc.
    When i turn the computer on, the screen seems ok.
    It flashes on and off during start up, which I think is normal.
    When the windows "XPpro" Desktop comes up, the monitor goes into sleep mode. If I turn the monitor off then on again, it will display the desktop for a couple of seconds, then go to sleep.
    It's seems like an energy star circuit problem.
    Any help?
Looks like your inverter board is broken.
Similar problem as Neovo F-417 (same chassis) , Look for 715L1283-4 inverter board
Try http://lcdpartsandrepair.com/e193fpc-inverter-power.html
Posted on Jul 02, 2008
MY MONITORIAL LEAGUE AND 3 SECONDS LATER GO BELOW ARE BLACK BEING OR CONNECTED TO THE COMPUTER WHICH IT CANNOT BE HELPS ME TO THE PROBLEM I AM NOT IN CONDITIONS TO CHANGE OF MONITOR NOW AND ADORE THIS WAY OBLIGED THE MODEL DELL E193FPC
Posted on Jun 13, 2009
On my Dell E193fpc monitor, the background lighting goes off after a few seconds. The actual Screen-image is still there (can be seen in bright sunlight). How can I get the backlighting to work proper
This sounds as though there might be a problem with the inverter (this is a component that supplies a high voltage for a tube(s) that illuminate the screen.
As there are high voltages on inverters, this is really a job for a repair shop.
Dec 11, 2013 | Dell E193FPC 19" TFT LCD Flat Panel...
Today I received a faulty Monitor Dell E773c, the problem is that the Monitor get On and the power LED is Green and after remove VGA Cable from CPU it get Orange, But no Display (The Screen is Blank)
To get monitor work for you, you should connect the VGA cable to CPU. When you remove the VGA cable, monitor has got nothing to display so it goes in stand by mode with orange LED on.
Sep 15, 2013 | Dell Computers & Internet
Dell E193FPC 19" monitor display
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Replacement board: http://www.lcdrepair.us
Apr 30, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
LCD display failure
First place to check will be the power supply section, look for bad caps with bulging top first, post back what you see so we can guide you more, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Inverter/pwr: http://www.lcdrepair.us/e193fpc-inverter-power.html
Feb 17, 2010 | Relisys RLT1720 17" LCD Monitor
Blank Monitor on my DELL
Your display is having problems with the Inverter that generates high voltage to lit the lamp.
This issue is explained (including how to fix it) here:
http://josepino.com/?howto-repair-dell
Good luck
May 07, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Blank monitor
Luckily I'm not in it for the money so here's your answer. (Sorry drumbanger.)
When it goes black, look at your power button. Is it still green? If so, the backlight display is bad. If the power light has turned orange, you're most likely looking at a power/inverter problem. Sadly, if you don't have another monitor that you can swap parts out with, you're looking at a new monitor. But with the economy on the downslide, replacements keep getting cheaper! Research online and you'll find some fantastic deals! Rate me if you find this helpful.
Feb 14, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Dell e193FPc monitor
The backlight or inverter may be bad. With the monitor on and the room dark, hold a flashlight very close and shine it on the screen . If you can see the normal display the monitor is OK but the backlight or the inverter which provides proper voltage to the backlight has gone bad.
Nov 10, 2008 | Dell E193FP 19" Flat Panel LCD Monitor
Dell E193FPC 19" TFT LCD Flat Panel Monitor Logo
1,825 people viewed this question
Alun Cox
