Question about Whirlpool Microwave Ovens
Whirlpool Velos Microwave showing "Error F7 HV SMPS Feedback" error. What does that mean?
  • Whirlpool Master
  • 9,086 Answers
F7 means that the control panel is not getting feedback from the Switched Mode Power Supply (high-voltage inverter).
This could be due to a problem with the inverter or the control unit / circuit board, but it appears to be the latter in most cases.
We repair microwave control boards for customers nationwide with our guaranteed $39.95 service.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful.
You may reply back with your brand and model number if you'd like us to look into this further, or feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 29, 2008
Code f 7
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. It should cover an F7 error code.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This may help:
F7 Error Code On Microwave Ovens With Inverter Board
MODELS: GH9177XL, GH9185XL, MH9180XL, MH7155XMS, & KHHS178L for example
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Whirlpool Microwave Ovens
F7 error on Velos microwave
The controller is not getting the correct feedback signal from the SMPS (switched-mode power supply AKA inverter).
It may be a problem with the inverter, magnetron, magnetron thermostat, controller, or thew wiring that connects them.
You can see a YouTube video
here that shows you how to remove the
controller assembly from a typical over the range microwave in less than 5
minutes.
You can find see the parts list with helpful exploded
views and download manuals for it here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=XXX&siteCd=WHRCOM&userType=Consumer
NOTE: You must change the XXX in the URL above to your
exact model number with suffix (but no dashes) as shown on the tag in the
cooking cavity or on of the oven. Then copy & paste it into your browser\'s address box.
You can buy part from
the Pros here
, our favorite supplier.
We\'re happy
to help you with free advice and we\'d appreciate your thoughtful rating
of our answer.
Feb 10, 2013 | Microwave Ovens
Whirlpool GH5184XPS Microwave Oven F7 error, trips circuit breaker
Check the high voltage capacitor, it normally shorts, "discharge with screwdriver" unhook one side and set meter to ohms. Check high voltage diode tied into one side of the capacitor, "unhook from chassis ground" set meter to ohms and check for short, sometimes cracks, "must be replaced" If the diode is open meter does not have enough forward bias to check.
Apr 01, 2012 | Whirlpool Microwave Ovens
F7 call for service
Hi, the F7 = HV SMPS feedback error. Most of the time this is a costly microprocessor board issue but can be something as simple as a loose or broken wire.
If it is in fact new you should contact Whirlpool for warranty service. Anything you would do as a consumer will void the warranty.
Apr 02, 2011 | Whirlpool GMH5205XVB Microwave Oven
Error code F7
Hi drk2676,
This error code F7 means that you have a function key stuck on ERC. You can solve this issue by replacing control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Feb 01, 2011 | Whirlpool GH6177XPS Microwave Oven
KitchenAid KHMS 2050 SSS, doesn't heat up and indicates "Error Code F7, VH SMPS feedback, call for service"
Hi asoleyma,
This error code F7 from a Ktchenaid oven means that the function key is stuck on ERC. This can be fixed by having the control board (also called ERC or clock) be replaced.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Jan 30, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have a Whirlpool Velos Microwave/convection over the range microwave. It is 2.5 years old. Tonight, after putting the fan on the unit is now indicating an Error message "F2H1-Hood Keys Stuck- the...
Sounds like the pads that you push on the touch panel are stuck, will probably have to replace the whole touch panel. On units installed over the oven, they typically plug into an outlet in the cabinet above the microwave. if not, try flipping your circuit breakers until you find the one that shuts off the Microwave.
Aug 24, 2017 | Microwave Ovens
My new Whirlpool Microwave oven is now showing an F7 on the screen and will only turn on for 3 seconds. What should I do?
Hi and welcome to FixYa, I am Kelly.
The F7 = HV SMPS feedback error. Most of the time this is a costly microprocessor board issue but can be something as simple as a loose or broken wire.
If it is in fact new you should contact Whirlpool for warranty service. Anything you would do as a consumer will void the warranty. First make sure your microwave is registerd via this link where it says "Register your product" http://www.whirlpool.com/custserv/index.jsp
Then using that same link you can schedule service or find out where your nearest carry in service center is.
Online Service Scheduling:
https://www.whirlpool.com/service/error.jsp?country=US&lang=en&brand=WP
CONTACT WHIRLPOOL
(866) 698-2538
Mon-Fri: 8am - 10pm (EDT)
Sat: 12pm - 5pm (EDT)
email: http://www.whirlpool.com/custserv/email_form.jsp
If the unit is second hand or out of warranty please include the model number in your next response.
Thanks for choosing FixYa,
Kelly
Dec 21, 2010 | Whirlpool Microwave Ovens
Microwave Ovens Logo
662 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
