Question about Whirlpool Dryers
Whirlpool gold ultimate care 2 dryer(10 years old) will not start. nothing visibly blocking door latch. what could the problem be?
  • 525 Answers
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://www.repairclinic.com/0088_8_1.asp#Level1_8
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 26, 2008
Model # SM 8280867 How old is this model?
6 - 10 years in 2012
Whirlpool Washer Ultimate Care ii - Appliance Repair Forums www.applianceblog.com/.../32099-Whirlpool-Washer-Ultimate-Care-ii
  • LAST UPDATED: 2012-05-28
  • 6 POSTS
  • FIRST POST: 2012-05-28
Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
Jan 27, 2016 | Washing Machines
My 10 year old electric dryer (Whirlpool Gold Ultimate Care II) is making a squealing, rattling noise. It still heats up, but something sounds loose. I wondering if I should get it fix or replace it.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 19, 2011 | LG DLG2524 Gas Dryer
Whirlpool Ultimate Care clothes dryer heater does not come on
First verify you have 220 volts of power at the terminal block on the rear of the dryer.
If power is OK use your volt meter set for continuity and check the door switch. With the door closed it should get a reading.
Finally,remove the rear panel from the dryer and check the thermal fuse located on the left of the main exhaust duct. It is about 1 and 1/2 inches long by 1/2 inch wide and white in color.
Remove the 2 wires and check for continuity with the meter.
No continuity is a bad fuse.
It is replaceable,not re-settable.
Sep 03, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool GOld Ultimate Care II electric dryer is not drying well any longer. It is 5 years old and a load must be run 2-3 times to get it to dry. Please help.
it could be your heating element but if you use dryer sheets take your lint trap out and see how well water will run thru it it may need to be washed in hot soapy water hope this helps
Dec 13, 2009 | LG DLG2524 Gas Dryer
Lost power after opening door during cycle.
Try and flip the breaker to off again and push lightly then on , when a breaker trips somtimes just flipping it on it wont catch a latch inside the breaker to actually flip it on.
Oct 29, 2009 | Dryers
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Latch on door won't close.
THe door wasn't closed right.  When I pushed the corner closed and it was lined up correctly, it latched.
Dec 05, 2008 | Magic Chef CDB6100 Built-in Dishwasher
Dryers Logo
211 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
