Question about ViewSonic P220f 22" CRT Monitor
VGA Narrow AT system turn on, the default VGA screen is narrow and folded over in the middle of the screen. The edges are compressed. Once the system gets up and moves to the graphics driver, the display is fine.
  • jbouknight Jun 27, 2008
    This is not an adjustment problem ... it looks more like a horizontal sync/drive problem. The picture is curved on both sides and folded over in the middle.
  • jbouknight Jun 30, 2008
    I just replaced the graphics card with a new NVidia 7800GS ACP, goes right in the slot the old NVidia GEForce Ultra went, but the problem did not go away.
    There are some simple games, that appear to want to go back to a DOS based graphics mode, that when they switch the monitor (you can here the relay click), the result is the narrowed, compressed and folded over picture on the screen. The software still works, knows about there the cursor is, but the picture is screwed up.
    I guess that's why I'm looking at it being a monitor problem.
    On the P220F, I have not been able to find a menu item for resetting to factory default settings.
  • 1,183 Answers
its a monitor, problem. If taking the monitor did not fix the issue. The settings have to adjusted by opening it up and the setting adjusted on the gun.
When the monitor is disconnected from the computer, how are the images look.
Do tell me how does the screen look , when you go into the system infromation screen ie system BIOS. tab Delete key about 5 times to enter system setup or F2 key depending upon the system you have. Also let me know when you bought this monitor . There would be serial number at the back of it
proton
Posted on Jul 01, 2008
  • 1,879 Answers
Greetings,
Replace the monitor. Get a nice LCD.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
  • 4,234 Answers
The problem you are having is within the pincushion circuit inside the monitor. This circuit can be frequency sensitive which would explain why some displays appear to work. This is not a problem that is likely to be resolved remotely nor by a novice user. There are high voltages present inside these monitors that can hurt and individual. Please have this monitor serviced or replaced. I will look up your model to see if there are common failures that could show up this way.
Dan
Posted on Jun 30, 2008
  • 105 Answers
I think there is a memory recall button in your main menu just try that so that you can go to the default level.
  • jithin antony Jun 30, 2008
    also try to check it on other cpu's.thank you
    President:
  • 2,712 Answers
You need to replace the horizontal/vertical amps on the main board. If you are getting a vertical line on the screen, then the horizontal amps need replacement and vice versa.... this is not a fix that can be accomplished by the uninitiated, and I would sincerely recommend you getting in touch with a qualified pro or authorized serviced center.
If your machine is out of warranty, why not try the Repair Service box on the left of this dialogue box? Just put in your Zip code, and you should find a list of service centers in your area. Simply mention that you were referred by Fixya, and you should get a decent discount :)
Hope that helps....Unfortunately, this is the limitation with this kind of long distance evaluation, in that we cannot actually physically inspect your device and repair it, and sometimes the only recourse is to take it to a service center for repairs..
Posted on Jun 28, 2008
    Scholar:
  • 68 Answers
Possible, its not a display adjustment issue nor firmware/update issue. It has something to do with your graphics card with my own experience on this. Well you can try resetting your monitor to its defualt or factory settings { this wont harm your monitor } then try to unplug and replug your graphic card on your motherboard , check cables  { just to make sure } and Turn your system off and  check what will happen . If this aint a help then let us try a different video/graphic card on just use your on-board card and check if it' have the same prob. If NO then its a hardware issue.  - yes you can try to update it or just simply unistall its driver and reinstall it back . This is what i did when my monitor acted the same way as yours.
"HONESTLY, Til now i didnt know what resolved my prob as i tried everything at the same time and "kaboom" it worked.. haha..well i have a new graphic card and  that stressful and annoying experience didnt happen again." -- trial and error
Hope this help and just leme know if theres anything that i can do for you.
Cheers
    Brigadier General:
  • 3,614 Answers
Adjusting the Screen Image
Beginning with the Main Menu shown below, use the buttons on the frontcontrol panel to adjust the OnView® controls which display on the screen.
hope this idea/info helps, for further assistance let us know..
micro
Posted on Jun 27, 2008
    Champion:
  • 217 Answers
Does it do the same thing when used with other computers?
    Guru:
  • 859 Answers
You need to use the button on the monitor itself to navigate thee menus, which can be a bit tricky to get used to at first, you want to find the menu item "Reset Monitor" it sometimes adds "to factory defaults".
This should resolve your problem, you can also do this more easily if you press the pause key at the time it first starts up and you see the logo or screen with text on it.
There is no other method, you can't do this from within the desktop environment or by updating any drivers. It just a monitor reset problem.
As I pointed out getting the hang of navigating your onscreen adjustments with the button on the bottom of your monitor is difficult to be kind and a real pain to be honest. Even we techs struggle with those buttons.
Regards,
Worldvet
    Genius:
  • 2,035 Answers
Please unplug the motioner from the main for 30 minutes and replug back and see if get the same image ,if yes please change the pincushion setting on the monitor , Please try connecting the monitor to different computer and see, this will give you better idea if the monitor or the drivers problem........................................
    Master:
  • 638 Answers
Just update the drivers of your video card.then see.
rate the solution if helped.thank u for using fixya.
    President:
  • 357 Answers
Hi there
This problem is caused by something on the inside of the monitor, you cannot sort this out yourself, you would have to take it to someone who knows how to fix monitors, this will probably cost you more than what the monitor is worth, i would suggest that either you invest in a Flatron LCD Monitor or just wait for the monitor to switch over to the graphics card.
  • 6,487 Answers
Try adjusting the display of your screen and restart it agin to check if the settings are save if not I will suggest you to update the driver fo your Video card to make sure there's no problem with..
Hope that helps...........
  • Mark Gil
    Mark Gil Jun 27, 2008
    You can also make sure that your video card is using the driver from the installation cd...
  • 58 Answers
Hello try this , click on the opion botton in your screan then try to adjust your screan size again , and thank you for using fixya
  • adham said
    adham said Jun 27, 2008
    hi try to update the vega dreiver , and thank you for using fixya
    Brigadier General:
  • 6,966 Answers
To my understanding the only reason that your monitor would display "...narrow and folded over in the middle of the screen. The edges are compressed..." would be when the monitor's default settings are not identical to what the video card's default settings would be. Chances are your video card would be outputting something like 800 X 600 (or even 640 X 400) @ 60Hz (during POST) but the default of your monitor is something like 1600 x 1200 @ 85 Hz. Since nothing can be done with the video card's POST/default settings, you probably can try lowering your monitor's initial settings using it's built-in "Timing Modes".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 26, 2008
  • Louie  Role
    Louie Role Jun 27, 2008
    Hi again,
    Based on your additional inputs, it sounds like a hardware problem then. Curving on both sides is a pincushion problem and often would be a resistor, capacitor or diode in the horizontal section. In some instances, it could be a shorted diode limiter pair on the yoke. If however, you likewise have an issue with the vertical, then it could possibly be a low B+ (most likely). On some Viewsonics, the circuitry that auto-detects the Timing Mode do get faulty. Problems could stem from low +5, filter capacitor in the +5 rail, cold solder or bulged capacitors.
    This would require familiarity with electronic components and circuitry, use of a DVM and a soldering iron as well as access to a service manual (*) or at the very least a schematic diagram with voltage readings. Should you be uncomfortable venturing a DIY, perhaps your best bet would be to seek the services of a qualified professional.
    Novelist:
  • 121 Answers
During this period of the system turning on you can adjust the screen size and to fit properly at the monitor. Once you do this next time you restart the PC the screen will stay the same and will not need to be readjusted at startup. Here is a link to the manual for your monitor that will show you how to adjust your screen settings.
Viewsonic P220F Manual
Hope this helps. If you found it helpful please rate this solution when you get a chance. Thanks - Tech101
Why Vertical lines in the middle of the screen ??
This could be your graphic card is aging or the Hard Drive or even the monitor saying goodbye. Troubleshoot with another monitor, you will be able to narrow it down more. Good luck!!!
Apr 28, 2014 | Acer AL1717 17" LCD Monitor
My laptop screen got wet now it has a dul screen and a dark area
I always start with seeing if when connecting an external monitor to the Laptops VGA output is the same or different to what you see when just via the Laptops screen. Reason is so that can narrow down to JUST Laptop screen or graphics chip, maybe even OR connection at cable either end, Motherboad or Screen.
Is the Laptop turning on alright i.e. no frying, I assume it has dried out from when it got wet. localised to screen only or possibly inside of Laptop....Lights up with power, fan spins hard drive spins, right? If so try an external monitor.
Feb 20, 2013 | Proview PL913S 19" Flat Panel LCD Monitor
Power light on flashing but no screen
Hello.
There is either a problem with your monitor, VGA cable or PC's video connector. Try another PC or another monitor to narrow down your problem.
If another monitor works, swap the VGA cable on your old monitor.
If another monitor doesn't work, your video connector is faulty.
Hope this helps.
May 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
I have a Viewsonic Monitor vs11349 and it will not connect with my acer PC...it comes up "no display". The monitor has a DVI that I need to use a VGA adapter. SHouldn't it work?
Did you try the setting on the monitor to use the DVI port instead of VGA port. Should also try it on another PC to narrow down the problem. Try VGA to VGA cable also.
Apr 06, 2010 | ViewSonic VX2245WM LCD Monitor
Screen is blak, has power
That either means it is not getting the signal from the PC or there is a problem in the monitor. You should try this monitor on another PC first, also check or try another VGA cable. Just need to narrow down the problem to either PC or the Monitor.
Apr 01, 2010 | Videoseven V7 R19WPS 19" LCD Monitor
Monitor screen display stretched center but squashed/narrow edges
On the monitor itself, I am guessing this is a desktop? There are buttons for adjustment. Look for the menu button around the bezel of the monitor and press it. Scroll through the settings for the default setting and press that. Once the default settings are made for the monitor, then you can go to the graphics settings available through windows to get the resolution straightened out.
Mar 26, 2010 | Computers & Internet
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Dell monitor
Tantong's description is correct -- press on side tabs and pry apart the face while working from the middle of the sides to the top. Once the sides are separated, remove the top, and remove the bottom last.
Photo of removed front faceplate
Photo of monitor side (with face plate removed)
Feb 07, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
ViewSonic P220f 22" CRT Monitor Logo
91 people viewed this question
Top ViewSonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
