Question about HP Deskjet 2360 InkJet Printer
Printer How do I get printer back from offline?
  • 3 Answers
Kbreiten,
Simply get into the Start Menu then find on the Printers and Faxes, then right click on it. It will will appear on the next lines delete printer model you wanted to delete and it will disappear and become offline.
Franklin Cas
Posted on Jul 17, 2008
How do i get my printer back on line?
NOT SURE IF THIS LINK WILL HELP YOU OUT....
Click the "Start" button and then click "Devices and Printers." Right-click the printerand select "See What's Printing" to display the print spooler window. Click "Printer" and select "Use Printer Offline" to remove the check mark. The printer should come online at this time.
How to Bring an Offline Printer Online ' Chron.com
smallbusiness.chron.com/bring-offline-printer-online-54836.html How do get my printer back on line Google Search
Dec 12, 2016 | PRINTER Office Equipment & Supplies
Says printer offline
"Offline" means it can't connect to the printer. Check all the wires from computer to printer, unplug and re-plug. Unplug printer from wall, wait 30 seconds, plug back in. Make sure printer is on.
Oct 16, 2014 | Sharp MX-2300N Color Copier
Printer offline wont print cant get back online
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
Printer offline
Depends on your OS you need find "printer and faxes" or "printer options on the hardware.
  • Open the Start menu and click on the "Devices and Printers" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. The status of the printer will be shown as either "Printer: Ready" or "Printer: Offline."
  • Click on "Printer: Offline" and the Printer menu will appear. Click on "Printer" in the menu bar and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 12, 2013 | Office Equipment & Supplies
My printer bkeeps showing offline & won't print. I've used the troubleshooter & it says the printer is turned off but it's not. I've tried turning it off & back on, unplugging & replugging...
Sometimes a printer will go to work offline and not realize its still offline when you turn printer back on.
If you can see a printer icon in your tray (bottom right) then double click it and you see a windows similar to the one screen shot below and click on "printer" menu and uncheck "use printer offline".
If that still doesn't work then delete the job in the queue and try to print again.btthr_0.jpg
Mar 05, 2011 | HP PSC 1210v All-In-One InkJet Printer
My HP deskjet D4260 is offline. I have tried everything to resolve this but cannot find a way of etting it back online. Please help
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
    Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Mar 02, 2011 | HP Deskjet D4260 Printer
Offline printer
unplug the USB lead and plug it back in...if no response try another USB port, if still no response use a different lead or put a gentle bend in the one you have to make the connection tighter....make sure the printer is on of course
Aug 02, 2009 | HP DeskJet F380 All-In-One Printer
Why does the printer stays offline and how to get it back online?
Go to 'Control Panel" then "Printerrs & Faxes" In the selection of items, right click on the offending printer on in the drop menu select "Use Printer Online". This should get you printer back.
May 31, 2009 | Lexmark X3350 All-In-One InkJet Printer
HP Printer D7260 Printer error
i do not have areason for why the printer continuously goes offline but there is a way to put it temporarily back online. Go to printers in the control panel. right click on d7260 and click on use printer online. This only seems to work for one or two docs before you have to repeat the process.
Nov 16, 2008 | HP Photosmart D7260 Printer
HP Deskjet 2360 InkJet Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
