Error code on hotpoint wmd740 washing machine f:05
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
57 varieties
  • 1653 Answers
SOURCE: Hotpoint WF840 W machine still full of water error code F 05.
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
  • 197 Answers
SOURCE: Hi I have a hotpoint washing machine model wt761
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Posted on Oct 25, 2009
  • 53 Answers
SOURCE: error code F-05 for hotpoint aquarious washing
your pump/filter/outlet hose is blocked. clean it all out with the power off.
Posted on Oct 30, 2009
barkencoa
  • 3463 Answers
SOURCE: f-01 error hotpoint WMD960P
Error code F01 is indicating ashort circuit motor triac.
Check connections on motor the motor plug and then control module.
Please rate my solution.
Thanks.
Posted on Nov 18, 2009
Hotpoint wmd740 ultima wont rinse and key symbol is stuck also foreign langue has appeared .
unplug the unit for 5 minutes then plug back in.
let me know what happens.
Jan 08, 2018 | Hotpoint Washing Machines
Hotpoint wmd740 won't spin
hi lee its worth taking motor brushes out and checking if very short could well be problem should be good inch long when new should work say 10mm or over
Dec 12, 2013 | Hotpoint Washing Machines
Siemens washing machine error code e61
Some brands where technical information is not always available or hard to obtain are Bosch,Siemens,Indesit,Hotpoint,LG,Samsung..
Here you can Download Instruction manual For your washing Machine (Enter you Product code to Download Example: WXS1040/05 )
https://portal.bsh-partner.com/portal%28bD1kZSZjPTAwOQ==%29/PORTALFRAME.HTM
Hope This help you out.
Sep 29, 2012 | Siemens Washing Machines
Hotpoint aquarius fault code f 05
  • F05 - Pressure switch jammed on full
  • Thing to do check pump is not blocked and clear it then reset machine by unplugging for 5 mins and plug back in if still gets error F 05 then you need a repair call out. hope this helps.
Jan 08, 2012 | Hotpoint Washing Machines
My Hotpoint wt640 has an error code F-05, what does this mea and what should i do??
My Hotpoint wt640 has an error code F-05, what does this mean and what should i do??
Feb 21, 2011 | Hotpoint Washing Machines
Error Code F-05
Error code F05 denotes pressure switch jammed on full.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit back and test.
Thgankyou.
Feb 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Dec 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error code f 05
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump. The fault is associated with drain out (pump blocked or restricted in some way). Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Sep 17, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
493 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
